Commit fe35bbd8 authored by Youn Cadoret's avatar Youn Cadoret
IUAINFRA-47 add javadoc + TU
parent b98ad8eb
1 merge request!3Feature/iuainfra 31
......@@ -3,6 +3,7 @@ package net.ihe.gazelle.app.accesstokenproviderapi.application;
import org.junit.jupiter.api.Test;
import java.io.File;
import java.io.IOException;
import java.util.logging.Logger;
import static org.junit.jupiter.api.Assertions.assertNotNull;
......@@ -10,13 +11,14 @@ class DummyAuthzServerSoapuiTest {
private static final String SUBJECT = "aamrein";
private static final String AUDIENCE = "audience";
private String resourcesFile = new File("src/test/resources/audience.properties").getPath();
* get access token with an Audience path defined
@Test
public void getAccessTokenWithPathAudienceTest() {
public void getAccessTokenWithPathAudienceTest() throws IOException {
String resourcesFile = new File("src/test/resources/audience.properties").getCanonicalPath();
DummyAuthzServerSoapui dummyAuthzServer = new DummyAuthzServerSoapui();
assertNotNull(dummyAuthzServer.getAccessToken(SUBJECT, AUDIENCE, null, null, resourcesFile));
