Commit 74937090 authored by Wylem Bars's avatar Wylem Bars
Merge remote-tracking branch 'remotes/origin/develop' into feature/IUAINFRA-52
parents dd2100c6 ea2095ae
1 merge request!2Feature/iuainfra 52
with 301 additions and 67 deletions
......@@ -11,6 +11,9 @@ import net.ihe.gazelle.sb.iua.business.TokenType;
import java.time.Duration;
* Dummy soapui authorization server
public class DummyAuthzServerSoapui implements DummyAuthzServer {
private static final GazelleLogger LOGGER = GazelleLoggerFactory.getInstance().getLogger(DummyAuthzServerSoapui.class);
......@@ -25,7 +28,14 @@ public class DummyAuthzServerSoapui implements DummyAuthzServer {
* Default constructor for the class.
public DummyAuthzServerSoapui() {
audienceSecretRetriever = new AudienceSecretRetrieverForSoapui();
//Empty
* Constructor with the path for the class.
public DummyAuthzServerSoapui(String path) {
audienceSecretRetriever = new AudienceSecretRetrieverForSoapui(path);
......@@ -45,37 +55,18 @@ public class DummyAuthzServerSoapui implements DummyAuthzServer {
//todo purposeOfUse and resourceId are not yet implemented
TokenGenerator tokenGenerator = new TokenGenerator();
tokenGenerator.setAudienceSecretRetriever(audienceSecretRetriever);
return getTokenGenerator(userId, audienceId, tokenGenerator);
* getAccessToken
* @param userId
* @param audienceId
* @param purposeOfUse
* @param resourceId
* @param propertiesFilePath
* @return
public byte[] getAccessToken(String userId, String audienceId, String purposeOfUse, String resourceId, String propertiesFilePath) {
tokenGenerator.setAudienceSecretRetriever(new AudienceSecretRetrieverForSoapui(propertiesFilePath));
tokenGenerator.setAudienceSecretRetriever(this.audienceSecretRetriever);
* getAccessTokenRequest
* get the access token
* @param userId
* @param audienceId
* @return
* @param userId String parameter
* @param audienceId String parameter
* @return AccessTokenRequest Element
public AccessTokenRequest getAccessTokenRequest(String userId, String audienceId){
AccessTokenRequest accessTokenRequest = new AccessTokenRequest(ISSUER, userId, audienceId, DURATION, TOKEN_TYPE);
......@@ -85,12 +76,12 @@ public class DummyAuthzServerSoapui implements DummyAuthzServer {
* getTokenGenerator
* get the generated token
* @param userId
* @param audienceId
* @param tokenGenerator
* @return
* @param userId String element
* @param audienceId String element
* @param tokenGenerator TokenGenerator object
* @return The token as byte
public byte[] getTokenGenerator(String userId, String audienceId, TokenGenerator tokenGenerator){
byte[] token = null;
......@@ -15,13 +15,15 @@ import net.ihe.gazelle.sb.jwtstandardblock.business.jwt.JSONWebSignature;
import net.ihe.gazelle.sb.jwtstandardblock.business.jwt.JSONWebToken;
import net.ihe.gazelle.sb.jwtstandardblock.business.jwt.JSONWebTokenClaimSet;
import javax.inject.Inject;
import java.nio.charset.StandardCharsets;
import java.time.ZoneId;
import java.time.ZonedDateTime;
import java.util.UUID;
* Class to generate the token
public class TokenGenerator {
private static final String ALGORITHM = "HS256";
......@@ -31,11 +33,23 @@ public class TokenGenerator {
private AudienceSecretRetriever audienceSecretRetriever;
@Inject
* Set an audience secret
* @param audienceSecretRetriever AudienceSecretRetriever element
public void setAudienceSecretRetriever(AudienceSecretRetriever audienceSecretRetriever) {
this.audienceSecretRetriever = audienceSecretRetriever;
* Encode the IUA token
* @param accessTokenRequest AccessTokenRequest element
* @return The EncodedIUAToken
* @throws EncodingException
* @throws TokenRequestException
public EncodedIUAToken generateAccessToken(AccessTokenRequest accessTokenRequest) throws EncodingException, TokenRequestException {
if (accessTokenRequest.getSignature() == null) {
throw new TokenRequestException("Missing signature information");
package net.ihe.gazelle.app.accesstokenproviderapi.application;
* Class to manage token request exception
public class TokenRequestException extends Exception {
package net.ihe.gazelle.app.accesstokenproviderapi.application.exception;
* Class to manage unsupported algorithm exception
public class UnsupportedAlgorithmException extends Exception {
* Constructs a new exception with null as its detail message. The cause is not initialized, and may subsequently be initialized by a call to
* {@link Throwable#initCause(Throwable)}.
public UnsupportedAlgorithmException() {
* Constructs a new exception with the specified detail message. The cause is not initialized, and may subsequently be initialized by a call to
* @param message the detail message. Can be retrieved by a later call of {@link Throwable#getMessage()} method.
public UnsupportedAlgorithmException(String message) {
super(message);
* Constructs a new exception with the specified detail message and cause. Note that the detail/TransactionRecordingDAO message associated with
* cause is not automatically incorporated in this exception's detail message.
* @param cause the cause. Can be retrieved by a lter call to {@link Throwable#getCause()}. A null value is permitted, and indicates that the
* cause is nonexistent or unknown.
public UnsupportedAlgorithmException(String message, Throwable cause) {
super(message, cause);
* Constructs a new exception with the specified detail message, cause, suppression enabled or disabled, and writable stack trace enabled or
* disabled.
* that the cause is nonexistent or unknown.
public UnsupportedAlgorithmException(Throwable cause) {
super(cause);
* disabled.
* @param enableSuppression whether or not suppression is enabled or disabled
* @param writableStackTrace whether or not the stack trace should be writable
public UnsupportedAlgorithmException(String message, Throwable cause, boolean enableSuppression, boolean writableStackTrace) {
super(message, cause, enableSuppression, writableStackTrace);
* Class to manage unsupported token exception
public class UnsupportedTokenTypeException extends Exception {
public UnsupportedTokenTypeException() {
public UnsupportedTokenTypeException(String message) {
super(message);
public UnsupportedTokenTypeException(String message, Throwable cause) {
* disabled.
public UnsupportedTokenTypeException(Throwable cause) {
super(cause);
* disabled.
public UnsupportedTokenTypeException(String message, Throwable cause, boolean enableSuppression, boolean writableStackTrace) {
<?xml version="1.0" encoding="UTF-8"?>
<con:soapui-project id="4527283c-83fc-419a-9fa3-d9c072053eac" activeEnvironment="Default" name="getToken" resourceRoot="" soapui-version="5.6.0" abortOnError="false" runType="SEQUENTIAL" xmlns:con="http://eviware.com/soapui/config"><con:settings/><con:testSuite id="a7dd34e8-2441-4bf8-b2bc-3ea43c3b0f42" name="getToken"><con:settings/><con:runType>SEQUENTIAL</con:runType><con:testCase id="f8ac5a96-e7e9-4a60-9e9c-84f80664db91" failOnError="true" failTestCaseOnErrors="true" keepSession="false" maxResults="0" name="getToken" searchProperties="true"><con:settings/><con:testStep type="groovy" name="exemple" id="c65c443d-1476-4c4a-b9e6-b63eac62939f"><con:settings/><con:config><script>import net.ihe.gazelle.app.accesstokenproviderapi.application.DummyAuthzServerSoapui
def server = new DummyAuthzServerSoapui();
def token = server.getAccessToken("aamrein", "audience", null, null);
log.info new String(token)</script></con:config></con:testStep><con:properties/></con:testCase><con:properties/></con:testSuite><con:properties/><con:wssContainer/><con:oAuth2ProfileContainer/><con:oAuth1ProfileContainer/><con:sensitiveInformation/></con:soapui-project>
\ No newline at end of file
def server = new DummyAuthzServerSoapui("/opt/simulators/audience.properties");
def token = server.getAccessToken("aamrein", "audience", null, null );
</script>
</con:config>
</con:testStep>
<con:properties/>
</con:testCase>
<con:properties/>
</con:testSuite>
<con:properties/>
<con:wssContainer/>
......@@ -5,17 +5,32 @@ import net.ihe.gazelle.app.audienceretriever.application.AudienceSecretRetriever
import java.util.HashMap;
import java.util.Map;
* Class to test the retriever of the audience secret
public class AudienceSecretRetrieverTestImpl implements AudienceSecretRetriever {
private Map<String, String> registry = new HashMap<>();
* Constructor
public AudienceSecretRetrieverTestImpl() {
* Add a new audience
* @param audience String element
* @param secret String element
public void addAudience(String audience, String secret){
registry.put(audience, secret);
* {@inheritDoc}
@Override
public String retrieveSecretForAudience(String audience) {
return registry.get(audience);
......@@ -3,17 +3,45 @@ package net.ihe.gazelle.app.accesstokenproviderapi.application;
import org.junit.jupiter.api.Test;
import static org.junit.jupiter.api.Assertions.assertNotNull;
import static org.junit.jupiter.api.Assertions.assertNull;
* Class to test the soapui authorization server
class DummyAuthzServerSoapuiTest {
private static final String SUBJECT = "aamrein";
private static final String AUDIENCE = "audience";
* get access token with an Audience path defined
@Test
public void test() {
public void getAccessTokenWithPathAudienceTest() {
DummyAuthzServerSoapui dummyAuthzServer = new DummyAuthzServerSoapui();
dummyAuthzServer.setAudienceSecretRetriever((String audience) -> "myBeautifulKeyWhichIsAJWTSecretSoSecret");
assertNotNull(dummyAuthzServer.getAccessToken(SUBJECT, AUDIENCE, null, null));
assertNotNull(dummyAuthzServer.getAccessToken(SUBJECT, AUDIENCE, null, null), "check that the access token is not null");
* get access token without an Audience path defined (we keep the default Audience path in this case)
@Test
public void getAccessTokenWithDefaultPathAudienceTest() {
* get access token with an invalid audience path provide
@Test
public void getAccessTokenWithBadPathAudienceTest() {
DummyAuthzServerSoapui dummyAuthzServer = new DummyAuthzServerSoapui("test.properties");
assertNull(dummyAuthzServer.getAccessToken(SUBJECT, AUDIENCE, null, null), "check that the access token is null");
......@@ -175,4 +175,54 @@ class TokenGeneratorTest {
@Test
public void generateAccessTokenEmptyAudienceTest() throws EncodingException, TokenRequestException {
AccessTokenRequest accessTokenRequest = new AccessTokenRequest(ISSUER, SUBJECT, "", DURATION, TOKEN_TYPE);
accessTokenRequest.setSignature(new SymmetricSignature(ALGORITHM, "secret"));
tokenGenerator.setAudienceSecretRetriever(AUDIENCE_RETRIEVER);
assertThrows(TokenRequestException.class, () -> tokenGenerator.generateAccessToken(accessTokenRequest), "Unsupported issuer");
@Test
public void generateAccessTokenEmptySecretTest() throws EncodingException, TokenRequestException {
AccessTokenRequest accessTokenRequest = new AccessTokenRequest(ISSUER, SUBJECT, "pouet", DURATION, TOKEN_TYPE);
tokenGenerator.setAudienceSecretRetriever(audience -> "");
@Test
public void generateAccessTokenNullSecretTest() throws EncodingException, TokenRequestException {
tokenGenerator.setAudienceSecretRetriever(audience -> null);
@Test
public void generateAccessTokenDurationNullTest() throws EncodingException, TokenRequestException {
AccessTokenRequest accessTokenRequest = new AccessTokenRequest(ISSUER, SUBJECT, "pouet", null, TOKEN_TYPE);
Put here your test resources.
audience:monpetitsecret
......@@ -15,14 +15,8 @@ public class AudienceSecretRetrieverForSoapui implements AudienceSecretRetriever
private static final GazelleLogger LOGGER = GazelleLoggerFactory.getInstance().getLogger(AudienceSecretRetrieverForSoapui.class);
private String propertiesFile = "/opt/simulators/audience.properties";
private String propertiesFile;
public AudienceSecretRetrieverForSoapui() {
//Empty Constructor
* Constructor allowing to configure the properties file path.
Put here classes from adapter layer :
Data transformers, adapters, presenters or DAO. Abstraction of external libraries for
application or business use.
Web-services point, sockets, database connection and pool, GUI, file system, framework,
external libraries.
Put here classes from application layer :
Use cases. Business elements applied in an application context or scenario.
Put here classes from business layer :
Business model, rules and constraints. Always true. Independent from the application.
package net.ihe.gazelle.app.audienceretriever.adapter;
* Class to test the retrieve of the audience secret
class AudienceSecretRetrieverForSoapuiTest {
* Test the property set in the retriever secret audience method
@Test
void retrieveSecretForAudienceWithPropertiesPathTest() {
AudienceSecretRetrieverForSoapui audienceSecretRetrieverForSoapui = new AudienceSecretRetrieverForSoapui("/opt/simulators/audience" +
".properties");
assertNull(audienceSecretRetrieverForSoapui.retrieveSecretForAudience("monpetitsecret"));
Put here test classes for adapter layer.
Put here test classes for application layer.
Put here test classes for business layer.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>net.ihe.gazelle</groupId>
......@@ -11,13 +12,9 @@
<url>http://gazelle.ihe.net</url>
<scm>
<connection>
scm:git:git@gitlab.inria.fr:gazelle/applications/test-execution/simulator/access-token-provider.git
</connection>
<url>scm:git:git@gitlab.inria.fr:gazelle/applications/test-execution/simulator/access-token-provider.git</url>
<developerConnection>
</developerConnection>
<connection>${git.project.url}</connection>
<url>${git.project.url}</url>
<developerConnection>${git.project.url}</developerConnection>
<tag>HEAD</tag>
</scm>
......@@ -31,6 +28,11 @@
<cvss.score.level.tolerate>8</cvss.score.level.tolerate>
<nexus.url>https://gazelle.ihe.net/nexus</nexus.url>
<nexus.path>/content/groups/public/</nexus.path>
<git.user.name>git</git.user.name>
<git.user.token>git</git.user.token>
<git.project.url>
scm:${git.user.name}:${git.user.token}@gitlab.inria.fr/gazelle/applications/test-execution/simulator/access-token-provider.git
</git.project.url>
</properties>
<repositories>
......@@ -201,4 +203,4 @@
<module>audience-retriever</module>
<module>dummy-authorization-server-service</module>
</modules>
</project>
</project>
