Commit 442b4695 authored by Thomas Moulard's avatar Thomas Moulard
Fix debian/changelog.
Git-Dch: ignore
parent ca60abf0
...@@ -5,7 +5,7 @@ visp (2.8.0-3) unstable; urgency=low ...@@ -5,7 +5,7 @@ visp (2.8.0-3) unstable; urgency=low
* Fix minor bugs remaining in 2.8.0-2 * Fix minor bugs remaining in 2.8.0-2
* Relax build-dependency on libcoin to allow easy backporting * Relax build-dependency on libcoin to allow easy backporting
* Add patch to fix portability issue in vpLex.c (see #723803) * Add patch to fix portability issue in vpLex.c (see #723803)
* Allow the test suite to fail on ia64 for now (close: #723803) * Allow the test suite to fail on ia64 for now (Closes: #723803)
* Build against libogre-1.9-dev while allowing 1.8 or later versions to ease backporting. * Build against libogre-1.9-dev while allowing 1.8 or later versions to ease backporting.
-- Thomas Moulard <thomas.moulard@gmail.com> Tue, 17 Sep 2013 15:14:16 +0900 -- Thomas Moulard <thomas.moulard@gmail.com> Tue, 17 Sep 2013 15:14:16 +0900
