Commit 2776f208 authored by POTTIER Francois's avatar POTTIER Francois
Indentation.
parent f1ec721f
...@@ -209,9 +209,9 @@ let is_solid s = ...@@ -209,9 +209,9 @@ let is_solid s =
match Lr1.incoming_symbol s with match Lr1.incoming_symbol s with
| None | None
| Some (Symbol.T _) -> | Some (Symbol.T _) ->
true true
| Some (Symbol.N _) -> | Some (Symbol.N _) ->
false false
(* [reduction_path_exists s w prod] tests whether the path determined by the (* [reduction_path_exists s w prod] tests whether the path determined by the
sequence of symbols [w] out of the state [s] exists in the automaton and sequence of symbols [w] out of the state [s] exists in the automaton and
