## Packaging your code
The first step of an integration process is being able to install the project with
its dependencies. In Python it is done using a *setup.py* script written with
with its dependencies. In Python it is done using a *setup.py* script written
*setuptools*.
with *setuptools*.
The script simply calls *setuptools.setup* function with the package description
: package directory, name, description, author, license, version, dependencies,
description: package directory, name, description, author, license, version,
supported Python versions, . . .
dependencies, supported Python versions, . . .
### Usage
### Usage
This *setup.py* script is the entry point for installing and releasing your code.
... | @@ -16,6 +16,8 @@ python setup.py <command> [opts] |
python setup.py install
# Install the package in a way that lets you edit the sources
python setup.py develop
# Build the package in a *build* directory
python setup.py build
# Upload your last revision to *PyPi* repository
python setup.py upload
... | @@ -54,7 +56,8 @@ setup( |
Depending on your needs, you can specify the version with ==, <, != operators.
Depending on your needs, you can specify the version with `==`, `<`, `!=`, ...
operators.
#### Note
#### Note
... | @@ -85,8 +88,8 @@ Versioning should help users follow features addition and know when |
incompatible changes have been introduced. Semantic Versioning gives you simple
rules for changing your version numbers.
From [http://semver.org/](http://semver.org/) summary : Given a version number MAJOR.MINOR.PATCH,
increment the :
MAJOR.MINOR.PATCH, increment the :
1. MAJOR version when you make incompatible API changes,
2. MINOR version when you add functionality in a backwards-compatible
manner, and
manner, and
