GitLab
Explore
Primary navigation
Search or go to…
GettingStartedWithModernCpp
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Formations
Cpp
9056422b
9056422b
6 years ago
GILLES Sebastien
Downloads
Patches
Exercice 39 solution now compiles...
68026796
Branches containing commit
Tags containing commit
TP/4-Templates/Solution/exercice39.cpp
+3
-4
3 additions, 4 deletions
3 additions
4 deletions
3
4
9056422b
@@ -184,9 +184,9 @@ IntT operator*(const PowerOfTwoApprox<IntT>& approx, IntT coefficient)
bool
is_overflow
false
bool
is_overflow
false
// static_cast for the sake of `short` case: short + short -> int!
IntT
ret
static_cast
IntT
times_power_of_2
IntT
is_overflow
IntT
ret
static_cast
IntT
times_power_of_2
is_overflow
approx
Numerator
coefficient
approx
Numerator
coefficient
approx
Exponent
approx
Exponent
if
is_overflow
if
is_overflow
@@ -438,7 +438,6 @@ void TestDisplaySum<IntT>::Display(int Nbits, double value1, IntT coefficient1,
// Ugly trick to circumvent the fact we can't add a new argument to operator* to get the value of `overflow`
// boolean. Fortunately we'll see a bit later how to deal properly with this.
bool
is_overflow
false
if
approx
std
numeric_limits
IntT
max
if
approx
std
numeric_limits
IntT
max
is_overflow
true
is_overflow
true
This diff is collapsed.
Loading
Save comment
