Commit 2f88542c authored by BESSON Frederic's avatar BESSON Frederic
Fix bugs in Nelson-Oppen
1- Purification non longer generates ill-typed terms
2- Equations are proved if types are convertible (instead of equal)
Note that purification is possibly too aggressive. It names every subterm.
Fixes #28
parent e965fca2
Tags 8.13+no
...@@ -78,9 +78,9 @@ clean : cleanaux ...@@ -78,9 +78,9 @@ clean : cleanaux
TESTSUITE = arith.v refl_bool.v no_test_lia.v no_test_lra.v TESTSUITE = arith.v refl_bool.v no_test_lia.v no_test_lra.v
ISSUES = issue_2.v issue_3.v issue_5.v issue_6.v issue_8.v issue_9.v issue_10.v \ ISSUES = cnf.v issue_2.v issue_3.v issue_5.v issue_6.v issue_8.v issue_9.v issue_10.v \
issue_11.v issue_12.v issue_13.v issue_14.v issue_15.v issue_16.v issue_19.v issue_20.v issue_21.v \ issue_11.v issue_12.v issue_13.v issue_14.v issue_15.v issue_16.v issue_19.v issue_20.v issue_21.v \
issue_22.v issue_23.v issue_cc.v issue_25.v cnf.v issue_22.v issue_23.v issue_cc.v issue_25.v issue_28.v
ALLTESTV = $(addprefix test-suite/,$(TESTSUITE)) $(addprefix issues/,$(ISSUES)) ALLTESTV = $(addprefix test-suite/,$(TESTSUITE)) $(addprefix issues/,$(ISSUES))
ALLTESTVO = $(ALLTESTV:.v=.vo) ALLTESTVO = $(ALLTESTV:.v=.vo)
Require Import Cdcl.Itauto. Require Import Cdcl.Itauto.
Require Import List. Require Import List.
Require Import cnf.
Goal forall A a a0 (r l l' : list A), (In a l' <-> In a l /\ ~ In a r) -> Goal forall A a a0 (r l l' : list A), (In a l' <-> In a l /\ ~ In a r) ->
~ (~ In a0 r) -> ~ (~ In a0 r) ->
From Coq Require Import ZArith Zify ZifyClasses ZifyBool ZifyInst Lia.
From mathcomp Require Import all_ssreflect all_algebra.
From mathcomp.zify Require Import zify.
Require Import Cdcl.NOlia.
Local Open Scope Z_scope.
(* arith on Z *)
Lemma foo_Z (x : Z) : 1 + x = x + 1.
Proof. lia. Qed.
(* eq + arith on Z *)
Lemma foo_f (f : Z -> Z) (x : Z) : f (1 + x) = f (x + 1).
Proof. smt. Qed.
Import Order.Theory.
Import GRing.Theory.
Local Open Scope ring_scope.
(* arith on int, thx to mczify's instances *)
Lemma foo_int (x : int) : 1 + x = x + 1.
Proof. lia. Qed.
Lemma foo_f_int (f : int -> int) (x : int) : f (1 + x) = f (x + 1).
Proof.
smt.
Qed.
...@@ -153,6 +153,19 @@ let declared_term thy env evd c a = ...@@ -153,6 +153,19 @@ let declared_term thy env evd c a =
| exception Not_found -> is_arity_op env evd thy c a 1 | exception Not_found -> is_arity_op env evd thy c a 1
match declared_term thy env evd c a with
| (c',a') ->
if debug then Feedback.msg_debug (Pp.(str "declared_term " ++
Printer.pr_econstr_env env evd (EConstr.mkApp(c,a)) ++
str "=>" ++
Printer.pr_econstr_env env evd (EConstr.mkApp(c',a')) ++
str "\n")) ; (c',a')
| exception e -> if debug then Feedback.msg_debug (Pp.(str "declared_term " ++
str "=>" ++ str (Printexc.to_string e) ++
str "\n")) ; raise e
let is_declared_type thy env evd typS = let is_declared_type thy env evd typS =
let typ = EConstr.mkApp(Lazy.force coq_TheoryType,[|thy;typS|]) in let typ = EConstr.mkApp(Lazy.force coq_TheoryType,[|thy;typS|]) in
try try
...@@ -182,12 +195,12 @@ let rec remember_term thy env evd senv t = ...@@ -182,12 +195,12 @@ let rec remember_term thy env evd senv t =
((EConstr.mkVar id, p), senv) ((EConstr.mkVar id, p), senv)
with Not_found -> ( with Not_found -> (
let c, a = decompose_app env evd t in let c, a = decompose_app env evd t in
let a, p = let c, a, p =
match declared_term thy env evd c a with match declared_term thy env evd c a with
| c, a -> (a, Arith) | c, a -> (c, a, Arith)
| exception Not_found -> | exception Not_found ->
if isVar evd c && a = [||] && is_declared_type thy env evd (Retyping.get_type_of env evd c) if isVar evd c && a = [||] && is_declared_type thy env evd (Retyping.get_type_of env evd c)
then (a, Arith) else (a, NonArith) then (c, a, Arith) else (c, a, NonArith)
in in
let a, senv = let a, senv =
Array.fold_right Array.fold_right
...@@ -356,7 +369,7 @@ let no_tacs thy tacl = ...@@ -356,7 +369,7 @@ let no_tacs thy tacl =
(EConstr.mkVar (Nameops.add_subscript name sub), typ)) (EConstr.mkVar (Nameops.add_subscript name sub), typ))
l) in l) in
let ll = let ll =
all_pairs (EConstr.eq_constr evd) vars in all_pairs (Reductionops.is_conv env evd) vars in
if debug if debug
then then
(Feedback.msg_debug Pp.(pr_enum (Printer.pr_econstr_env env evd) (List.map fst vars)); (Feedback.msg_debug Pp.(pr_enum (Printer.pr_econstr_env env evd) (List.map fst vars));
