Commit f6a2e001 authored by hhakim's avatar hhakim
Doxygen doc: enable navigation side bar.
parent 26df6410
......@@ -749,7 +749,9 @@ ENUM_VALUES_PER_LINE = 4
# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
# probably better off using the HTML help feature.
GENERATE_TREEVIEW = NO
GENERATE_TREEVIEW = YES
FULL_SIDEBAR = YES
# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
# used to set the initial width (in pixels) of the frame in which the tree
......@@ -1640,6 +1642,3 @@ EXTENSION_MAPPING = .m=C++ #without that option-value, matlab inheritance i
#DOT_MULTI_TARGETS = NO
#GENERATE_LEGEND = YES
#DOT_CLEANUP = YES
