Commit f42fb075 authored by hhakim's avatar hhakim
Custom the faust_torch cpp test.
Adds two arguments:
- Argument 1 to specify if the test is executed on a Faust with SPARSE, DENSE, or MIXED factors Faust.
- Argument 2 to specify the number of multiplications to measure the cumulative time (for each test cases: pure faust, tensor converted faust, tensor faust without the time of conversion).
parent 7869d1e1
...@@ -18,8 +18,22 @@ int main(int argc, char** argv) ...@@ -18,8 +18,22 @@ int main(int argc, char** argv)
max_nfacts = static_cast<unsigned int>(std::rand()*(float)max_nfacts/RAND_MAX)+min_nfacts; max_nfacts = static_cast<unsigned int>(std::rand()*(float)max_nfacts/RAND_MAX)+min_nfacts;
RandFaustType rt = MIXED; RandFaustType rt = MIXED;
if(argc > 1) if(argc > 1)
rt = SPARSE; {
string arg(argv[1]);
if(! arg.compare("dense") || ! arg.compare("DENSE"))
rt = DENSE;
else if(! arg.compare("sparse") || ! arg.compare("SPARSE"))
rt = SPARSE;
else
cerr << "WARNING: invalid argument: must be sparse or dense (switch to mixed types)." << endl;
int nsamples;
if(argc > 2)
nsamples = std::atoi(argv[2]);
auto F = TransformHelper<FPP,Cpu>::randFaust(rt, min_nfacts, max_nfacts, min_size, max_size, .4f); auto F = TransformHelper<FPP,Cpu>::randFaust(rt, min_nfacts, max_nfacts, min_size, max_size, .4f);
F->display();
vector<MatGeneric<FPP,Cpu>*> facs; vector<MatGeneric<FPP,Cpu>*> facs;
for(auto it = F->begin();it != F->end();it++) for(auto it = F->begin();it != F->end();it++)
...@@ -34,23 +48,26 @@ int main(int argc, char** argv) ...@@ -34,23 +48,26 @@ int main(int argc, char** argv)
tensor_chain_mul(facs, out); tensor_chain_mul(facs, out);
cout << "faust toarray through tensor_matmul:" << out.norm() << endl; cout << "faust toarray through tensor_matmul:" << out.norm() << endl;
auto M = Faust::MatDense<FPP,Cpu>::randMat(F->getNbCol(), F->getNbRow()); auto M = Faust::MatDense<FPP,Cpu>::randMat(F->getNbCol(), F->getNbRow());
/** Measure time of nsamples F*M (pure Faust) */
auto start = std::chrono::system_clock::now(); auto start = std::chrono::system_clock::now();
out = F->multiply(*M); for(int i=0;i<nsamples;i++) out = F->multiply(*M);
auto end = std::chrono::system_clock::now(); auto end = std::chrono::system_clock::now();
cout << "norm F*M:" << out.norm() << endl;
time_pure_faust = end-start; time_pure_faust = end-start;
/** Measure time of nsamples F*M (Faust-torch) */
start = std::chrono::system_clock::now(); start = std::chrono::system_clock::now();
tensor_chain_mul(facs, out, M); for(int i=0;i<nsamples;i++) tensor_chain_mul(facs, out, M);
end = std::chrono::system_clock::now(); end = std::chrono::system_clock::now();
cout << "norm tensor(F)*tensor(M):" << out.norm() << endl;
time_faust_torch = end-start; time_faust_torch = end-start;
start = std::chrono::system_clock::now(); cout << "norm tensor(F)*tensor(M):" << out.norm() << endl;
/** Measure time of nsamples F*M (Faust-torch without accounting matrix-to-tensor conversion time) */
Tensor tM; Tensor tM;
faust_MatDense_to_torch_Tensor(*M, tM); faust_MatDense_to_torch_Tensor(*M, tM);
t = tensor_chain_mul(tl, &tM); start = std::chrono::system_clock::now();
for(int i=0;i<nsamples;i++) t = tensor_chain_mul(tl, &tM);
cout << "norm tensor(F)*tensor(M) (2):" << torch::norm(t.flatten()) << endl;
time_faust_torch_without_conversion = end-start; time_faust_torch_without_conversion = end-start;
cout << "time F*M (pure Faust):" << time_pure_faust.count() << " secs." << endl; cout << "time F*M (pure Faust):" << time_pure_faust.count() << " secs." << endl;
cout << "time tensor(F)*tensor(M) (Faust torch):" << time_faust_torch.count() << " secs." << endl; cout << "time tensor(F)*tensor(M) (Faust torch):" << time_faust_torch.count() << " secs." << endl;
cout << "time tensor(F)*tensor(M) (Faust torch without time to convert to Tensors):" << time_faust_torch_without_conversion.count() << " secs." << endl; cout << "time tensor(F)*tensor(M) (Faust torch without time to convert to Tensors):" << time_faust_torch_without_conversion.count() << " secs." << endl;
