Commit f2f70e82 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
external lib matio auto
parent aae7b18c
......@@ -31,19 +31,24 @@ message(STATUS "******* Check externals library ***********")
# Default path library (where the library is automatically install)
add_library_path(LIBRARY_PATH_LIST_TMP_DEFAULT "/opt/OpenBLAS"
"${PROJECT_SOURCE_DIR}/externals/unix/OpenBLAS"
"/usr/local" #pour matio
"/usr/local/lib" #pour matio
"${PROJECT_SOURCE_DIR}/externals/unix/matio/src/.libs" #pour matio
add_include_path(INCLUDE_PATH_LIST_TMP_DEFAULT "/opt/OpenBLAS"
"/usr/include/eigen3"
"${PROJECT_SOURCE_DIR}/externals/unix/eigen"
"${PROJECT_SOURCE_DIR}/externals/unix/matio/src" #pour matio
#set(LIBRARY_PATH_LIST ${LIBRARY_PATH_LIST_TMP_DEFAULT}) # CACHE PATH "List of library paths used as PATH parameter in find_library")
#set(INCLUDE_PATH_LIST ${INCLUDE_PATH_LIST_TMP_DEFAULT})# CACHE PATH "List of include paths used as PATH parameter in find_path")
#message(STATUS "DEFAULT LIBRARY_PATH_LIST=${LIBRARY_PATH_LIST}")
message(STATUS "DEFAULT INCLUDE_PATH_LIST=${INCLUDE_PATH_LIST}")
#message(STATUS "DEFAULT INCLUDE_PATH_LIST=${INCLUDE_PATH_LIST}")
######## EIGEN ##############
include(CMake/findEIGENLib.cmake)
......@@ -55,7 +60,10 @@ endif(FAUST_USE_OPENBLAS)
if (FAUST_USE_MEX)
include(CMake/findMatlab.cmake)
endif(FAUST_USE_MEX)
######## MATIO INCLUDE AND LIBRARY ##################
if (FAUST_USE_MATIO)
include(CMake/findMATIOLib.cmake)
endif(FAUST_USE_MATIO)
add_library_path(LIBRARY_PATH_LIST_TMP3 "$ENV{CUDADIR}" "$ENV{MATIODIR}" "$ENV{HDF5_ROOT_DIR}" "$ENV{OPENBLASDIR}" "/usr" "/usr/local" "/usr/local/lib" "/opt" "/opt/local" "/usr/lib/x86_64-linux-gnu/" "${PROJECT_SOURCE_DIR}/externals" )
......@@ -65,13 +73,12 @@ add_include_path(INCLUDE_PATH_LIST_TMP3 "$ENV{CUDADIR}" "$ENV{MATIODIR}" "$ENV{M
set(LIBRARY_PATH_LIST ${LIBRARY_PATH_LIST_TMP3}) # CACHE PATH "List of library paths used as PATH parameter in find_library")
set(INCLUDE_PATH_LIST ${INCLUDE_PATH_LIST_TMP3}) # CACHE PATH "List of include paths used as PATH parameter in find_path")
check_external_libraries(matio MATIO_LIB_FILE 0)
check_external_libraries(xml2 XML2_LIB_FILE 0)
check_external_libraries(hdf5 HDF5_LIB_FILE 0)
#LDFLAGS = -L$(CUDADIR)/lib64 -L$(MATIODIR)/lib -lpthread -lm -lcublas -lcudart -lcusparse -lstdc++ -lgfortran -lz -lmatio -lhdf5
check_external_includes("libxml/parser.h" XML_INC_DIR 0)
check_external_includes("matio.h" MATIO_INC_DIR 0)
......@@ -23,16 +23,16 @@
###### test if executable matlab is in the path ######
#if (FAUST_USE_MEX)
if(UNIX)
message(STATUS "MATLAB_DIR_TMP 1 = ${MATLAB_DIR_TMP}")
#message(STATUS "MATLAB_DIR_TMP 1 = ${MATLAB_DIR_TMP}")
exec_program("which matlab | xargs echo" OUTPUT_VARIABLE MATLAB_DIR_TMP)
message(STATUS "MATLAB_DIR_TMP 2 = ${MATLAB_DIR_TMP}")
#message(STATUS "MATLAB_DIR_TMP 2 = ${MATLAB_DIR_TMP}")
exec_program("readlink ${MATLAB_DIR_TMP}" OUTPUT_VARIABLE READLINK_TMP)
message(STATUS "READLINK_TMP = ${READLINK_TMP}")
#message(STATUS "READLINK_TMP = ${READLINK_TMP}")
if(${READLINK_TMP} MATCHES matlab)
set(MATLAB_DIR_TMP ${READLINK_TMP})
message(STATUS "MATLAB_DIR_TMP 3 = ${MATLAB_DIR_TMP}")
#message(STATUS "MATLAB_DIR_TMP 3 = ${MATLAB_DIR_TMP}")
endif()
message(STATUS "MATLAB_DIR_TMP 4 = ${MATLAB_DIR_TMP}")
#message(STATUS "MATLAB_DIR_TMP 4 = ${MATLAB_DIR_TMP}")
elseif(WIN32)
exec_program("where matlab.exe" OUTPUT_VARIABLE MATLAB_DIR_TMP)
......@@ -51,10 +51,10 @@ if( ${MATLAB_DIR_TMP} MATCHES "matlab")
endif()
set(MATLAB_ROOT ${MATLAB_ROOT} CACHE PATH "Matlab root directory")
message(STATUS "MATLAB_DIR_TMP ${MATLAB_DIR_TMP}")
message(STATUS "MATLAB_ROOT has been found : ${MATLAB_ROOT}")
#message(STATUS "MATLAB_DIR_TMP ${MATLAB_DIR_TMP}")
#message(STATUS "MATLAB_ROOT has been found : ${MATLAB_ROOT}") # example : "/usr/local/MATLAB/R2014b"
set(MATLAB_INCLUDE_DIR "${MATLAB_ROOT}/extern/include" CACHE INTERNAL "Matlab include directory")
set(MATLAB_ARCH_FILE "${FAUST_TMP_BUILD_DIR}/matlab_arch.txt")
......@@ -50,7 +50,6 @@ option(BUILD_TESTING "Build Tests" ON)
set(FAUST_USE_SINGLEPRECISION OFF CACHE BOOL "Using single precision instead of double precision for matrix and vector computations")
set(FAUST_USE_PROFILING OFF CACHE BOOL "Profiling the code")
set(FAUST_USE_OPENMP OFF CACHE BOOL "OpenMP Multithreading")
set(FAUST_USE_MATIO FF CACHE BOOL "Using matio library to read mat files")
set(FAUST_USE_XML OFF CACHE BOOL "Using xml configuration to read xml files")
set(FAUST_ISVERBOSE OFF CACHE BOOL "Display useful message for debugging")
set(FAUST_USE_GPU OFF CACHE BOOL "Using both CPU and GPU process")
......@@ -58,7 +57,7 @@ set(FAUST_GEN_DOC OFF CACHE BOOL "Generate html documentation with doxygen")
set(FAUST_USE_MEX ON CACHE BOOL "Generate Mexfiles")
set(FAUST_USE_OPENBLAS ON CACHE BOOL "Using openBLAS for matrix and vector computations")
set(FAUST_USE_MATIO ON CACHE BOOL "Using matio library to read mat files")
if (FAUST_USE_SINGLEPRECISION)
message(STATUS "**********SINGLEPRECISION ACTIF************")
