Commit f088404c authored by hhakim's avatar hhakim
Add doc for shape argument of pyfaust.proj classes.
parent afae7624
...@@ -231,6 +231,7 @@ class sp(proj_gen): ...@@ -231,6 +231,7 @@ class sp(proj_gen):
Args: Args:
shape: shape of the input array.
k: the number of nonzeros of the projection image. k: the number of nonzeros of the projection image.
normalized: True to normalize the projection image according to its Frobenius norm. normalized: True to normalize the projection image according to its Frobenius norm.
pos: True to skip negative values (replaced by zero) of the matrix to project. pos: True to skip negative values (replaced by zero) of the matrix to project.
...@@ -272,6 +273,7 @@ class splin(proj_gen): ...@@ -272,6 +273,7 @@ class splin(proj_gen):
def __init__(self, shape, k, normalized=True, pos=False): def __init__(self, shape, k, normalized=True, pos=False):
Args: Args:
...@@ -313,6 +315,7 @@ class spcol(proj_gen): ...@@ -313,6 +315,7 @@ class spcol(proj_gen):
Args: Args:
S: the support matrix. S: the support matrix.
...@@ -377,6 +380,7 @@ class splincol(proj_gen): ...@@ -377,6 +380,7 @@ class splincol(proj_gen):
Args: Args:
k: the integer sparsity (number of nonzeros) targeted per-row and k: the integer sparsity (number of nonzeros) targeted per-row and
per-column. per-column.
...@@ -670,6 +674,7 @@ class skperm(proj_gen): ...@@ -670,6 +674,7 @@ class skperm(proj_gen):
Projector constructor. Projector constructor.
Args: Args:
...@@ -681,7 +686,7 @@ class skperm(proj_gen): ...@@ -681,7 +686,7 @@ class skperm(proj_gen):
class triu_sp(proj_gen): class triu_sp(proj_gen):
Functor for the TRIU SP projector. Functor for the TRIU_SP projector.
A, the image matrix, is such that the lower triangular part is 0 and \f$ \| A \|_0 = k, \| A\|_F = 1 \f$ (if normalized == True). A, the image matrix, is such that the lower triangular part is 0 and \f$ \| A \|_0 = k, \| A\|_F = 1 \f$ (if normalized == True).
...@@ -716,6 +721,7 @@ class triu_sp(proj_gen): ...@@ -716,6 +721,7 @@ class triu_sp(proj_gen):
Args: Args:
...@@ -726,7 +732,7 @@ class triu_sp(proj_gen): ...@@ -726,7 +732,7 @@ class triu_sp(proj_gen):
class tril_sp(proj_gen): class tril_sp(proj_gen):
Functor for the TRIL SP projector. Functor for the TRIL_SP projector.
A, the image matrix, is such that the upper triangular part is 0 and \f$ \| A \|_0 = k, \| A\|_F = 1 \f$ (if normalized == True). A, the image matrix, is such that the upper triangular part is 0 and \f$ \| A \|_0 = k, \| A\|_F = 1 \f$ (if normalized == True).
...@@ -761,6 +767,7 @@ class tril_sp(proj_gen): ...@@ -761,6 +767,7 @@ class tril_sp(proj_gen):
Args: Args:
...@@ -804,6 +811,7 @@ class symm_sp(proj_gen): ...@@ -804,6 +811,7 @@ class symm_sp(proj_gen):
Args: Args:
