Commit eee2ef1e authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
test xcode
parent 2a33a7f6
...@@ -602,7 +602,7 @@ else (BUILD_USE_GPU) ...@@ -602,7 +602,7 @@ else (BUILD_USE_GPU)
if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") ) if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") )
message (STATUS "------------------------------------------ ") message (STATUS "------------------------------------------ ")
message (STATUS "APPLE AND Xcode ${FAUST_ALGORITHM_TARGET} ${FAUST_ALGORITHM_BIN_DIR}") message (STATUS "APPLE AND Xcode ${FAUST_ALGORITHM_TARGET} ${FAUST_ALGORITHM_BIN_DIR}")
#add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> ) add_library(${FAUST_TARGET} STATIC ${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> )
else () else ()
add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> ) add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> )
endif() endif()
...@@ -640,11 +640,7 @@ else() ...@@ -640,11 +640,7 @@ else()
target_link_libraries(${FAUST_TARGET} ) target_link_libraries(${FAUST_TARGET} )
endif(BUILD_OPENBLAS) endif(BUILD_OPENBLAS)
if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") ) install(TARGETS ${FAUST_TARGET} DESTINATION ${FAUST_INSTALL_LIB})
#install(TARGETS ${FAUST_TARGET} DESTINATION ${FAUST_INSTALL_LIB})
else()
endif()
...@@ -13,7 +13,7 @@ if(BUILD_OPENBLAS) ...@@ -13,7 +13,7 @@ if(BUILD_OPENBLAS)
endif() endif()
add_library(${FAUST_ALGORITHM_TARGET} ${CPP_FILES}) #add_library(${FAUST_ALGORITHM_TARGET} ${CPP_FILES})
else () else ()
add_library(${FAUST_ALGORITHM_TARGET} OBJECT ${CPP_FILES}) add_library(${FAUST_ALGORITHM_TARGET} OBJECT ${CPP_FILES})
endif() endif()
...@@ -48,8 +48,7 @@ configure_file(${FAUST_SRC_LINEAR_OPERATOR_DIR}/faust_constant.h.in ${FAUST_SRC_ ...@@ -48,8 +48,7 @@ configure_file(${FAUST_SRC_LINEAR_OPERATOR_DIR}/faust_constant.h.in ${FAUST_SRC_
#add_library(${FAUST_MATRIX_TARGET} OBJECT ${CPP_FILES}) #add_library(${FAUST_MATRIX_TARGET} OBJECT ${CPP_FILES})
#add_library(${FAUST_LINEAR_OPERATOR_TARGET} ${CPP_FILES} ${HPP_FILES}) add_library(${FAUST_LINEAR_OPERATOR_TARGET} ${CPP_FILES} ${HPP_FILES})
add_library(${FAUST_TARGET} STATIC ${CPP_FILES} ${HPP_FILES}) $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> )
else () else ()
add_library(${FAUST_LINEAR_OPERATOR_TARGET} OBJECT ${CPP_FILES} ${HPP_FILES}) add_library(${FAUST_LINEAR_OPERATOR_TARGET} OBJECT ${CPP_FILES} ${HPP_FILES})
endif() endif()
