Commit e87c8dfb authored by hhakim's avatar hhakim
Remove from pkg post-install scripts the matlab userpath startup.m edition to avoid redundancy.
parent e489ae2b
Pipeline #833953 skipped
...@@ -8,15 +8,40 @@ function dirname_noerr ...@@ -8,15 +8,40 @@ function dirname_noerr
function inject_matlab_code_to_update_path function inject_matlab_code_to_update_path
# each line must contains the word faust (for filtering of old install lines)
FILE=$1 FILE=$1
echo "matfaust_path = which('matfaust.version')" >> "$FILE" echo "matfaust_path = which('matfaust.version');" >> "$FILE"
echo "if(isempty(matfaust_path))" >> "$FILE" echo "if(isempty(matfaust_path))" >> "$FILE"
echo "addpath('"$FAUST_MATLAB_WRAPPER_PATH"')" >> "$FILE" echo "addpath('"$FAUST_MATLAB_WRAPPER_PATH"')" >> "$FILE"
echo "addpath(['"$FAUST_MATLAB_WRAPPER_PATH"' '/mex'])" >> "$FILE" echo "addpath(['"$FAUST_MATLAB_WRAPPER_PATH"' '/mex'])" >> "$FILE"
echo "addpath(['"$FAUST_MATLAB_WRAPPER_PATH"' '/tools'])" >> "$FILE" echo "addpath(['"$FAUST_MATLAB_WRAPPER_PATH"' '/tools'])" >> "$FILE"
echo "addpath(['"$FAUST_MATLAB_WRAPPER_PATH"' '/data'])" >> "$FILE" echo "addpath(['"$FAUST_MATLAB_WRAPPER_PATH"' '/data'])" >> "$FILE"
echo "matfaust.enable_gpu_mod('silent', true)" >> "$FILE" echo "matfaust.enable_gpu_mod('silent', true);end" >> "$FILE"
echo end >> "$FILE" }
funtion inject_matlab_code_to_update_user_paths
# try edit startup.m of all users (only when files exist)
for USER_DIR in /home/*
do
USER=${USER_DIR##*/}
for USR_STARTUP_FILE in $USER_DIR/Documents/MATLAB/startup.m $USER_DIR/matlab/startup.m
do
#if [[ ! "${USR_STARTUP_FILE}" = "${STARTUP_FILE}" ]]
#then
if [[ -r "$USR_STARTUP_FILE" ]]
then
grep -i -v faust "$USR_STARTUP_FILE" > "${USR_STARTUP_FILE}.tmp" 2>/dev/null && mv "${USR_STARTUP_FILE}.tmp" "$USR_STARTUP_FILE"
#echo "addpath(genpath('"$FAUST_MATLAB_WRAPPER_PATH"'))" >> "$USR_STARTUP_FILE"
inject_matlab_code_to_update_path "$USR_STARTUP_FILE"
chown $USER "$USR_STARTUP_FILE"
RET2=$(($?+$RET2))
fi
#fi
done
done
MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(which matlab 2>/dev/null))) MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(which matlab 2>/dev/null)))
...@@ -42,25 +67,8 @@ else ...@@ -42,25 +67,8 @@ else
echo "oldpwd = pwd; startup_path = fullfile(matlabroot, 'toolbox', 'local'); cd(startup_path); startup; cd(oldpwd)" >> $MATLABRC echo "oldpwd = pwd; startup_path = fullfile(matlabroot, 'toolbox', 'local'); cd(startup_path); startup; cd(oldpwd)" >> $MATLABRC
RET1=$? RET1=$?
RET2=0 RET2=0
# try edit startup.m of all users (only when files exist) # disable because it's too intrusive and maybe redundant
for USER_DIR in /home/* # inject_matlab_code_to_update_user_paths
do
do
#then
then
RET2=$(($?+$RET2))
fi
#fi
done
done
[[ $RET1 = 0 && $RET2 = 0 ]] && echo -e "\033[1mNOTICE\033[0m: Faust matlab setup is complete." || echo "ERROR: something went wrong in matlab startup script editing." [[ $RET1 = 0 && $RET2 = 0 ]] && echo -e "\033[1mNOTICE\033[0m: Faust matlab setup is complete." || echo "ERROR: something went wrong in matlab startup script editing."
else else
echo "ERROR: Faust matlab wrapper path isn't valid." echo "ERROR: Faust matlab wrapper path isn't valid."
...@@ -2,15 +2,42 @@ ...@@ -2,15 +2,42 @@
FILE=$1 FILE=$1
function inject_matlab_code_to_update_user_paths
# set path in user startup script
#USR_STARTUP_FILE="$($MATLAB_BIN -nojvm -nodisplay -r "which startup;exit" | tail -n 2 | head -n 1)" # doesn't work into install script
# even if it works in a normal script #TODO: debug
# temporary solution (hard-coded paths)
for USR_HOME in /Users/*
do
USER=${USR_HOME##*/}
for USR_STARTUP_FILE in "$USR_HOME"/Documents/MATLAB/startup.m "$USR_HOME"/matlab/startup.m
do
#then
then
grep -i -v faust "$USR_STARTUP_FILE" > "${USR_STARTUP_FILE}.tmp" && mv "${USR_STARTUP_FILE}.tmp" "$USR_STARTUP_FILE"
fi
#fi
done
done
# find matlab root path from the accessible matlab in the PATH # find matlab root path from the accessible matlab in the PATH
...@@ -39,25 +66,6 @@ else ...@@ -39,25 +66,6 @@ else
inject_matlab_code_to_update_path $STARTUP_FILE inject_matlab_code_to_update_path $STARTUP_FILE
# add a line to force startup execution into matlabrc # add a line to force startup execution into matlabrc
# set path in user startup script # disable because it's too intrusive and maybe redundant
#USR_STARTUP_FILE="$($MATLAB_BIN -nojvm -nodisplay -r "which startup;exit" | tail -n 2 | head -n 1)" # doesn't work into install script # inject_matlab_code_to_update_user_paths
do
do
#then
then
fi
#fi
done
done
fi fi
...@@ -244,25 +244,26 @@ Function matlabFoundCb ...@@ -244,25 +244,26 @@ Function matlabFoundCb
FileOpen $1 "$R4\toolbox\local\startup.m" a FileOpen $1 "$R4\toolbox\local\startup.m" a
FileSeek $1 0 END ; do not erase start of file (but risk to add Faust path multiple times) FileSeek $1 0 END ; do not erase start of file (but risk to add Faust path multiple times)
;FileWrite $1 "$\r$\naddpath(genpath('$INSTDIR\matlab'));$\r$\nmatfaust.enable_gpu_mod('silent', true)" ;FileWrite $1 "$\r$\naddpath(genpath('$INSTDIR\matlab'));$\r$\nmatfaust.enable_gpu_mod('silent', true)"
FileWrite $1 "matfaust_path = which('matfaust.version');$\r$\nif(isempty(matfaust_path))" FileWrite $1 "matfaust_path = which('matfaust.version');$\r$\nif(isempty(matfaust_path));"
FileWrite $1 "$\r$\naddpath('$INSTDIR\matlab');$\r$\naddpath('$INSTDIR\matlab\mex');$\r$\naddpath('$INSTDIR\matlab\tools');$\r$\naddpath('$INSTDIR\matlab\data')$\r$\nmatfaust.enable_gpu_mod('silent', true)" FileWrite $1 "$\r$\naddpath('$INSTDIR\matlab');$\r$\naddpath('$INSTDIR\matlab\mex');$\r$\naddpath('$INSTDIR\matlab\tools');$\r$\naddpath('$INSTDIR\matlab\data')$\r$\nmatfaust.enable_gpu_mod('silent', true)"
FileWrite $1 "$\r$\nend" FileWrite $1 "$\r$\nend"
FileClose $1 FileClose $1
FileOpen $1 "$R4\toolbox\local\matlabrc.m" a FileOpen $1 "$R4\toolbox\local\matlabrc.m" a
FileWrite $1 "oldpwd = pwd; startup_path = fullfile(matlabroot, 'toolbox', 'local'); cd(startup_path); startup; cd(oldpwd)" FileWrite $1 "oldpwd = pwd; startup_path = fullfile(matlabroot, 'toolbox', 'local'); cd(startup_path); startup; cd(oldpwd);"
FileOpen $1 "$DOCUMENTS\MATLAB\startup.m" a # disable because it's redundant
IfErrors done ; FileOpen $1 "$DOCUMENTS\MATLAB\startup.m" a
FileSeek $1 0 END ; IfErrors done
;FileWrite $1 "$\r$\naddpath(genpath('$INSTDIR\matlab'));$\r$\nmatfaust.enable_gpu_mod('silent', true)" ; FileSeek $1 0 END
FileWrite $1 "matfaust_path = which('matfaust.version');$\r$\nif(isempty(matfaust_path))" ; ;FileWrite $1 "$\r$\naddpath(genpath('$INSTDIR\matlab'));$\r$\nmatfaust.enable_gpu_mod('silent', true)"
FileWrite $1 "$\r$\naddpath('$INSTDIR\matlab');$\r$\naddpath('$INSTDIR\matlab\mex');$\r$\naddpath('$INSTDIR\matlab\tools');$\r$\naddpath('$INSTDIR\matlab\data')$\r$\nmatfaust.enable_gpu_mod('silent', true);" ; FileWrite $1 "matfaust_path = which('matfaust.version');$\r$\nif(isempty(matfaust_path))"
FileWrite $1 "$\r$\nend" ; FileWrite $1 "$\r$\naddpath('$INSTDIR\matlab');$\r$\naddpath('$INSTDIR\matlab\mex');$\r$\naddpath('$INSTDIR\matlab\tools');$\r$\naddpath('$INSTDIR\matlab\data')$\r$\nmatfaust.enable_gpu_mod('silent', true);"
FileClose $1 ; FileWrite $1 "$\r$\nend"
done: ; FileClose $1
; done:
;MessageBox MB_OK '$R0$\n$\nFaust bound into $R4.' ;MessageBox MB_OK '$R0$\n$\nFaust bound into $R4.'
;MessageBox MB_YESNO 'Faust installed for $R4. Do you want to continue searching another version of Matlab to install Faust for ?' IDYES +2 ;MessageBox MB_YESNO 'Faust installed for $R4. Do you want to continue searching another version of Matlab to install Faust for ?' IDYES +2
