Commit e7f021c9 authored by testcdash Nicolas Bellot's avatar testcdash Nicolas Bellot Committed by hhakim
add openblas 4 windows
parent f540b915
...@@ -10,30 +10,53 @@ if ( (OPENBLAS_LIB_FILE) AND (OPENBLAS_INC_DIR) ) ...@@ -10,30 +10,53 @@ if ( (OPENBLAS_LIB_FILE) AND (OPENBLAS_INC_DIR) )
message(STATUS "OpenBlas include is installed here : ${OPENBLAS_INC_DIR}") message(STATUS "OpenBlas include is installed here : ${OPENBLAS_INC_DIR}")
else ( (OPENBLAS_LIB_FILE) AND (OPENBLAS_INC_DIR) ) else ( (OPENBLAS_LIB_FILE) AND (OPENBLAS_INC_DIR) )
if(UNIX) if(UNIX)
#exec_program("wget -P ${CMAKE_SOURCE_DIR}/externals/unix/tarLibs http://github.com/xianyi/OpenBLAS/archive/v0.2.18.tar.gz")
message(STATUS "------------------------------------------------") message(STATUS "------------------------------------------------")
message(STATUS "------------ OPENBLAS LIB INSTALLATION ---------") message(STATUS "------------ OPENBLAS LIB INSTALLATION ---------")
set(OPENBLAS_LIB_NAME "v0.2.18.tar.gz") set(OPENBLAS_LIB_NAME "v0.2.18.tar.gz")
exec_program("tar xzf ${CMAKE_SOURCE_DIR}/externals/unix/tarLibs/${OPENBLAS_LIB_NAME} -C ${CMAKE_SOURCE_DIR}/externals/unix") exec_program("tar xzf ${CMAKE_SOURCE_DIR}/externals/unix/tarLibs/${OPENBLAS_LIB_NAME} -C ${CMAKE_SOURCE_DIR}/externals/unix")
exec_program("rm -r ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS") exec_program("rm -r ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS")
exec_program("rm -r ${CMAKE_SOURCE_DIR}/externals/unix/OpenBLAS") exec_program("rm -r ${CMAKE_SOURCE_DIR}/externals/unix/OpenBLAS")
exec_program("mv ${CMAKE_SOURCE_DIR}/externals/unix/OpenBLAS* ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS") exec_program("mv ${CMAKE_SOURCE_DIR}/externals/unix/OpenBLAS* ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS")
exec_program("cd ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS && make --quiet TARGET=NEHALEM && make install PREFIX='${CMAKE_SOURCE_DIR}/externals/unix/OpenBLAS'") exec_program("cd ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS && make --quiet TARGET=NEHALEM && make install PREFIX='${CMAKE_SOURCE_DIR}/externals/unix/OpenBLAS'")
add_include_path(INCLUDE_PATH_LIST_TMP_OPENBLAS "${PROJECT_SOURCE_DIR}/externals/unix/OpenBLAS")
add_library_path(LIBRARY_PATH_LIST_TMP_OPENBLAS "${PROJECT_SOURCE_DIR}/externals/unix/OpenBLAS")
#exec_program(" ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS") #exec_program(" ${CMAKE_SOURCE_DIR}/externals/unix/sdk_OpenBLAS")
elseif(WIN32) elseif(WIN32)
set(OPENBLAS_LIB_NAME "OpenBLAS-0.2.19")
set (OPENBLAS_LIB_FILE "${CMAKE_SOURCE_DIR}/externals/win/zipLibs/${OPENBLAS_LIB_NAME}/lib")
set (OPENBLAS_INC_DIR "${CMAKE_SOURCE_DIR}/externals/win/zipLibs/${OPENBLAS_LIB_NAME}")
add_include_path(INCLUDE_PATH_LIST_TMP_OPENBLAS ${OPENBLAS_INC_DIR})
add_library_path(LIBRARY_PATH_LIST_TMP_OPENBLAS ${OPENBLAS_LIB_FILE})
# Download openblas http://www.openblas.net/
# dezip
# https://github.com/xianyi/OpenBLAS/wiki/How-to-use-OpenBLAS-in-Microsoft-Visual-Studio
# section 2. CMake and Visual Studio
# do this from powershell so cmake can find visual studio
# install perl on system: padre-on-strawberry https://code.google.com/archive/p/padre-perl-ide/downloads
# make sure perl is in your path "perl -v".
#cmake -G "Visual Studio 14 Win64" .
#in visual studio : generate ALL_BUILD
#exec_program("wget -P ${CMAKE_SOURCE_DIR}/externals/win http://github.com/xianyi/OpenBLAS/archive/v0.2.18.tar.gz") #exec_program("wget -P ${CMAKE_SOURCE_DIR}/externals/win http://github.com/xianyi/OpenBLAS/archive/v0.2.18.tar.gz")
exec_program("tar jxf ${CMAKE_SOURCE_DIR}/externals/win/zipLibs/v0.2.18.tar.bz -C ${CMAKE_SOURCE_DIR}/externals/win") #exec_program("tar jxf ${CMAKE_SOURCE_DIR}/externals/win/zipLibs/v0.2.18.tar.bz -C ${CMAKE_SOURCE_DIR}/externals/win")
exec_program("mv ${CMAKE_SOURCE_DIR}/externals/win/sdk_openBlas* ${CMAKE_SOURCE_DIR}/externals/win/OpenBLAS") #exec_program("mv ${CMAKE_SOURCE_DIR}/externals/win/sdk_openBlas* ${CMAKE_SOURCE_DIR}/externals/win/OpenBLAS")
else(UNIX) else(UNIX)
message(WARNING "Unknown type of plateform for library OpenBlas") message(WARNING "Unknown type of plateform for library OpenBlas")
endif(UNIX) endif(UNIX)
#message(STATUS "INCLUDE_PATH_LIST_TMP2=${INCLUDE_PATH_LIST_TMP2}") #message(STATUS "INCLUDE_PATH_LIST_TMP2=${INCLUDE_PATH_LIST_TMP2}")
#message(STATUS "LIBRARY_PATH_LIST_TMP2=${LIBRARY_PATH_LIST_TMP2}") #message(STATUS "LIBRARY_PATH_LIST_TMP2=${LIBRARY_PATH_LIST_TMP2}")
...@@ -41,6 +64,9 @@ else ( (OPENBLAS_LIB_FILE) AND (OPENBLAS_INC_DIR) ) ...@@ -41,6 +64,9 @@ else ( (OPENBLAS_LIB_FILE) AND (OPENBLAS_INC_DIR) )
set(INCLUDE_PATH_LIST ${INCLUDE_PATH_LIST_TMP_OPENBLAS}) # CACHE PATH "List of include paths used as PATH parameter in find_path") set(INCLUDE_PATH_LIST ${INCLUDE_PATH_LIST_TMP_OPENBLAS}) # CACHE PATH "List of include paths used as PATH parameter in find_path")
set(LIBRARY_PATH_LIST ${LIBRARY_PATH_LIST_TMP_OPENBLAS}) # CACHE PATH "List of include paths used as PATH parameter in find_path") set(LIBRARY_PATH_LIST ${LIBRARY_PATH_LIST_TMP_OPENBLAS}) # CACHE PATH "List of include paths used as PATH parameter in find_path")
message(STATUS "INCLUDE_PATH_LIST=${INCLUDE_PATH_LIST}")
check_external_libraries(openblas OPENBLAS_LIB_FILE 0) check_external_libraries(openblas OPENBLAS_LIB_FILE 0)
check_external_includes("cblas.h" OPENBLAS_INC_DIR 0) check_external_includes("cblas.h" OPENBLAS_INC_DIR 0)
