Commit e73f33bd authored by hhakim's avatar hhakim
Update C++ svdtj: remove the last permutation factor from eigtj. Fix pyfaust...
Update C++ svdtj: remove the last permutation factor from eigtj. Fix pyfaust pyrex svdtj (passing explicitely the array in column major order -- fortran array). Update sligthly the doc.
parent c036de0a
Loading
Checking pipeline status
Loading
