Commit e13abb8f authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
add faust_prox
parent c5f4e80a
#ifndef FAUST_PROX_H
#define FAUST_PROX_H
#include "faust_MatDense.h"
#include "faust_constant.h"
#include "faust_exception.h"
#include "faust_Vect.h"
namespace Faust {
template<typename FPP>
bool partial_sort_comp (const std::pair<int, FPP>& pair1, const std::pair<int, FPP>& pair2);
void sort_idx(const std::vector<FPP> &v, std::vector<int>& idx, int s);
void prox_sp(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
void prox_sp_pos(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
void prox_spcol(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
void prox_splin(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
void prox_spcol_normfree(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
void prox_splin_normfree(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
void prox_splincol(Faust::MatDense<FPP,Cpu> &M,faust_unsigned_int k);
void prox_normcol(Faust::MatDense<FPP,Cpu> & M,FPP s);
void prox_normlin(Faust::MatDense<FPP,Cpu> & M,FPP s);
void prox_supp(Faust::MatDense<FPP,Cpu> & M, const Faust::MatDense<FPP,Cpu> & supp);
void prox_blkdiag(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k);
#include "faust_prox.hpp"
#endif
......@@ -9,13 +9,13 @@
// const char * interface_prox_name="prox : ";
inline bool partial_sort_comp (const std::pair<int, FPP>& pair1, const std::pair<int, FPP>& pair2)
inline bool Faust::partial_sort_comp (const std::pair<int, FPP>& pair1, const std::pair<int, FPP>& pair2)
return fabs(pair1.second) > fabs(pair2.second);
void Faust::sort_idx(const std::vector<FPP> &v, std::vector<int>& idx, int s)
std::vector<std::pair<int, FPP> > vec_pair(v.size());
for (int i=0 ; i<v.size() ; i++)
......@@ -28,7 +28,7 @@ void sort_idx(const std::vector<FPP> &v, std::vector<int>& idx, int s)
void Faust::prox_sp(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
const faust_unsigned_int dim1 = M.getNbRow();
const faust_unsigned_int dim2 = M.getNbCol();
......@@ -55,7 +55,7 @@ void prox_sp(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
void Faust::prox_spcol(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
prox_spcol_normfree(M,k);
M.normalize();
......@@ -64,7 +64,7 @@ void prox_spcol(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
void Faust::prox_spcol_normfree(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
......@@ -96,7 +96,7 @@ void prox_spcol_normfree(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
void Faust::prox_splin_normfree(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
......@@ -127,7 +127,7 @@ void prox_splin_normfree(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
void Faust::prox_splin(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
prox_splin_normfree(M,k);
M.normalize();
......@@ -136,7 +136,7 @@ void prox_splin(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
void Faust::prox_splincol(Faust::MatDense<FPP,Cpu> &M,faust_unsigned_int k)
Faust::MatDense<FPP,Cpu> Mspcol = M;
Faust::MatDense<FPP,Cpu> Msplin = M;
......@@ -162,7 +162,7 @@ void prox_splincol(Faust::MatDense<FPP,Cpu> &M,faust_unsigned_int k)
void Faust::prox_normcol(Faust::MatDense<FPP,Cpu> & M,FPP s)
......@@ -204,7 +204,7 @@ void prox_normcol(Faust::MatDense<FPP,Cpu> & M,FPP s)
void Faust::prox_normlin(Faust::MatDense<FPP,Cpu> & M,FPP s)
M.transpose();
prox_normcol(M,s);
......@@ -213,7 +213,7 @@ void prox_normlin(Faust::MatDense<FPP,Cpu> & M,FPP s)
void Faust::prox_sp_pos(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
FPP*const ptr_data = M.getData();
//treshold de la matrice
......@@ -229,7 +229,7 @@ void prox_sp_pos(Faust::MatDense<FPP,Cpu> & M,faust_unsigned_int k)
// M needs to be square and k must divide dimension of M
void prox_blkdiag(Faust::MatDense<FPP,Cpu> & M,int k)
void Faust::prox_blkdiag(Faust::MatDense<FPP,Cpu> & M,int k)
faust_unsigned_int i,j;
faust_unsigned_int Msize = M.getNbRow();
......@@ -270,7 +270,7 @@ void prox_blkdiag(Faust::MatDense<FPP,Cpu> & M,int k)
void prox_supp(Faust::MatDense<FPP,Cpu> & M,const Faust::MatDense<FPP,Cpu> & supp)
void Faust::prox_supp(Faust::MatDense<FPP,Cpu> & M,const Faust::MatDense<FPP,Cpu> & supp)
if ( (supp.getNbRow() != M.getNbRow()) || (supp.getNbCol() != M.getNbCol()) )
#ifndef PROX_H
#define PROX_H
#include "prox.hpp"
#endif
