GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
dedcff69
dedcff69
1 year ago
hhakim
Downloads
Patches
Update poly docstring examples (#332).
83f90190
Branches containing commit
Tags containing commit
Pipeline
#968691
passed
1 year ago
Stage: test
Stage: pkg_purepy
Stage: pkg
Stage: pkg_test
2
2 changed files
.gitlab-ci.yml
+1
-1
1 addition, 1 deletion
.gitlab-ci.yml
wrapper/python/pyfaust/poly.py
+24
-24
24 additions, 24 deletions
25 additions
25 deletions
.gitlab-ci.yml
dedcff69
@@ -166,7 +166,7 @@ ctest_nightly_win10:
build_FaustWin/Testing
# cmake configure, build, ctest logs
.install_pyfaust_release_and_update
variables
JOB_PYTHON
python3.12'
variables
JOB_PYTHON
python3.12'
# see #332, why not python3.12
before_script
before_script
if [[ ! -d 'build' ]]; then mkdir build;fi; cd build
cmake -DBUILD_WRAPPER_PYTHON=ON -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..
This diff is collapsed.
24
24
dedcff69
@@ -121,10 +121,10 @@ def basis(L, K, basis_name, dev='cpu', T0=None, **kwargs):
K
3
K
3
F
basis
L
K
chebyshev
F
basis
L
K
chebyshev
F
F
Faust
size
200
x50
density
0.06
72
nnz_sum
6
72
4
factor
s
Faust
size
200
x50
density
0.06
99
nnz_sum
6
99
4
factor
s
FACTOR
double
SPARSE
size
200
x150
density
0.009
3333
nnz
2
74
FACTOR
double
SPARSE
size
200
x150
density
0.009
4
3333
nnz
2
83
FACTOR
double
SPARSE
size
150
x100
density
0.01
49
333
nnz
2
24
FACTOR
double
SPARSE
size
150
x100
density
0.01
55
333
nnz
2
33
FACTOR
2
double
SPARSE
size
100
x50
density
0.02
48
nnz
24
FACTOR
2
double
SPARSE
size
100
x50
density
0.02
66
nnz
33
FACTOR
3
double
SPARSE
size
50
x50
density
0.02
nnz
50
FACTOR
3
double
SPARSE
size
50
x50
density
0.02
nnz
50
identity
matrix
flag
identity
matrix
flag
@@ -133,11 +133,11 @@ def basis(L, K, basis_name, dev='cpu', T0=None, **kwargs):
G
next
F
G
next
F
G
G
Faust
size
250
x50
density
0.0
7968
nnz_sum
996
5
factor
s
Faust
size
250
x50
density
0.0
8256
nnz_sum
1032
5
factor
s
FACTOR
double
SPARSE
size
250
x200
density
0.006
48
nnz
3
24
FACTOR
double
SPARSE
size
250
x200
density
0.006
66
nnz
3
33
FACTOR
double
SPARSE
size
200
x150
density
0.009
3333
nnz
2
74
FACTOR
double
SPARSE
size
200
x150
density
0.009
4
3333
nnz
2
83
FACTOR
2
double
SPARSE
size
150
x100
density
0.01
49
333
nnz
2
24
FACTOR
2
double
SPARSE
size
150
x100
density
0.01
55
333
nnz
2
33
FACTOR
3
double
SPARSE
size
100
x50
density
0.02
48
nnz
24
FACTOR
3
double
SPARSE
size
100
x50
density
0.02
66
nnz
33
FACTOR
4
double
SPARSE
size
50
x50
density
0.02
nnz
50
FACTOR
4
double
SPARSE
size
50
x50
density
0.02
nnz
50
identity
matrix
flag
identity
matrix
flag
@@ -150,10 +150,10 @@ def basis(L, K, basis_name, dev='cpu', T0=None, **kwargs):
F2
basis
L
K
chebyshev
T0
random
50
2
3
format
csr
F2
basis
L
K
chebyshev
T0
random
50
2
3
format
csr
F2
F2
Faust
size
200
x2
density
1.
68
nnz_sum
6
72
4
factor
s
Faust
size
200
x2
density
1.
7475
nnz_sum
6
99
4
factor
s
FACTOR
double
SPARSE
size
200
x150
density
0.009
3333
nnz
2
74
FACTOR
double
SPARSE
size
200
x150
density
0.009
4
3333
nnz
2
83
FACTOR
double
SPARSE
size
150
x100
density
0.01
49
333
nnz
2
24
FACTOR
double
SPARSE
size
150
x100
density
0.01
55
333
nnz
2
33
FACTOR
2
double
SPARSE
size
100
x50
density
0.02
48
nnz
24
FACTOR
2
double
SPARSE
size
100
x50
density
0.02
66
nnz
33
FACTOR
3
double
SPARSE
size
50
x2
density
0.5
nnz
50
FACTOR
3
double
SPARSE
size
50
x2
density
0.5
nnz
50
@@ -216,11 +216,11 @@ def poly(coeffs, basis='chebyshev', L=None, X=None, dev='cpu', out=None,
coeffs
np
array
5
2
3
coeffs
np
array
5
2
3
G
poly
coeffs
chebyshev
L
G
poly
coeffs
chebyshev
L
G
G
Faust
size
50
x50
density
0.3
488
nnz_sum
8
72
5
factor
s
Faust
size
50
x50
density
0.3
596
nnz_sum
8
99
5
factor
s
FACTOR
double
SPARSE
size
50
x200
density
0.02
nnz
200
FACTOR
double
SPARSE
size
50
x200
density
0.02
nnz
200
FACTOR
double
SPARSE
size
200
x150
density
0.009
3333
nnz
2
74
FACTOR
double
SPARSE
size
200
x150
density
0.009
4
3333
nnz
2
83
FACTOR
2
double
SPARSE
size
150
x100
density
0.01
49
333
nnz
2
24
FACTOR
2
double
SPARSE
size
150
x100
density
0.01
55
333
nnz
2
33
FACTOR
3
double
SPARSE
size
100
x50
density
0.02
48
nnz
24
FACTOR
3
double
SPARSE
size
100
x50
density
0.02
66
nnz
33
FACTOR
4
double
SPARSE
size
50
x50
density
0.02
nnz
50
FACTOR
4
double
SPARSE
size
50
x50
density
0.02
nnz
50
identity
matrix
flag
identity
matrix
flag
@@ -231,11 +231,11 @@ def poly(coeffs, basis='chebyshev', L=None, X=None, dev='cpu', out=None,
coeffs
np
array
5
2
3
coeffs
np
array
5
2
3
G
poly
coeffs
F
G
poly
coeffs
F
G
G
Faust
size
50
x50
density
0.3
488
nnz_sum
8
72
5
factor
s
Faust
size
50
x50
density
0.3
596
nnz_sum
8
99
5
factor
s
FACTOR
double
SPARSE
size
50
x200
density
0.02
nnz
200
FACTOR
double
SPARSE
size
50
x200
density
0.02
nnz
200
FACTOR
double
SPARSE
size
200
x150
density
0.009
3333
nnz
2
74
FACTOR
double
SPARSE
size
200
x150
density
0.009
4
3333
nnz
2
83
FACTOR
2
double
SPARSE
size
150
x100
density
0.01
49
333
nnz
2
24
FACTOR
2
double
SPARSE
size
150
x100
density
0.01
55
333
nnz
2
33
FACTOR
3
double
SPARSE
size
100
x50
density
0.02
48
nnz
24
FACTOR
3
double
SPARSE
size
100
x50
density
0.02
66
nnz
33
FACTOR
4
double
SPARSE
size
50
x50
density
0.02
nnz
50
FACTOR
4
double
SPARSE
size
50
x50
density
0.02
nnz
50
identity
matrix
flag
identity
matrix
flag
@@ -601,9 +601,9 @@ def expm_multiply(A, B, t, K=10, tradeoff='time', dev='cpu', **kwargs):
t
np
linspace
start
5
stop
0.1
num
3
endpoint
True
t
np
linspace
start
5
stop
0.1
num
3
endpoint
True
y
fexpm_multiply
L
x
t
y
fexpm_multiply
L
x
t
y
y
array
0.12706927
0.2
4591891
0.24529726
0.35223879
0.7409274
array
0.12706927
0.2
1111065
0.36636184
0.41736344
0.78517596
0.13190047
0.2
6391877
0.2890644
0.38977573
0.75815737
0.13190047
0.2
4040598
0.36636184
0.4324354
0.78517596
0.13691536
0.2
8256865
0.33890501
0.43252159
0.77600955
0.13691536
0.2
7376655
0.36636184
0.44805164
0.78517596
if not isinstance(A, csr_matrix):
Loading
Save comment
