Commit dbecefbf authored by hhakim's avatar hhakim
Use clang to build the pyfaust wrapper on Linux instead of gcc.
Cf. issue #215.
parent e2b02c6e
...@@ -16,6 +16,12 @@ if(version == ''): ...@@ -16,6 +16,12 @@ if(version == ''):
# (not for packaging with a proper version) # (not for packaging with a proper version)
# it avoids error PEP440 # it avoids error PEP440
from sys import platform
if platform == "linux": # or platform == "darwin": # no need to specify we use clang on MacOS X because it's the default compiler
# compile with clang on Linux and MacOS X
from distutils import sysconfig
sysconfig.get_config_vars()['CC'] = 'clang'
PyFaust = Extension('_FaustCorePy', PyFaust = Extension('_FaustCorePy',
sources = @PY_EXT_SOURCES@, sources = @PY_EXT_SOURCES@,
...@@ -28,7 +34,6 @@ PyFaust = Extension('_FaustCorePy', ...@@ -28,7 +34,6 @@ PyFaust = Extension('_FaustCorePy',
extra_objects = @PYTHON_EXT_EXTRA_OBJECTS@ extra_objects = @PYTHON_EXT_EXTRA_OBJECTS@
setup( setup(
name = 'pyfaust@PYFAUST_PKG_SUFFIX@', name = 'pyfaust@PYFAUST_PKG_SUFFIX@',
version = version, # cf. header version = version, # cf. header
