Commit db91ef42 authored by hhakim's avatar hhakim
Refactor pkg_macos_release and pkg_macos ci jobs into a unique script.
parent 4fed8d59
...@@ -94,34 +94,10 @@ ctest_nightly_macos: ...@@ -94,34 +94,10 @@ ctest_nightly_macos:
pkg_macos: pkg_macos:
stage: pkg stage: pkg
script: script:
- export PYTHON_PATH=$(which python$NIX_PY_VER)
- SHA_START=$(echo $CI_COMMIT_SHA | sed -e 's/^\(.\{8\}\).*/\1/') - SHA_START=$(echo $CI_COMMIT_SHA | sed -e 's/^\(.\{8\}\).*/\1/')
- if [[ ! -d 'build' ]]; then mkdir build;fi; cd build - export FAUST_VERSION=$SHA_START
- 'cmake -DOpenMP_gomp_LIBRARY=/opt/local/lib/libomp/libgomp.dylib -DBUILD_WRAPPER_PYTHON=ON -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$SHA_START -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" -DEXPERIMENTAL_PKG=ON -DBUILD_MULTITHREAD=ON -DNOPY2=ON -DCMAKE_CXX_COMPILER=/opt/local/bin/clang++-mp-8.0 -DBUILD_FLOAT_PYX=ON ..' - export EXPERIMENTAL_PKG=ON
- make LANG=en_GB.UTF-8 - ./misc/continuous_integration/jobs/macosx/pkg_macos.sh
# to compile matlab wrappers use matlab libiomp5 but backup the clang lib first
#- sudo mv /opt/local/lib/libomp/libomp.dylib /opt/local/lib/libomp/libomp.dylib.bak
- sudo cp /opt/local/lib/libomp/libiomp5_matlab.dylib /opt/local/lib/libomp/libomp.dylib
- cmake -DBUILD_WRAPPER_MATLAB=ON ..
# restore clang libomp
#- sudo cp /opt/local/lib/libomp/libomp.dylib /opt/local/lib/libomp/libiomp5.dylib
- sudo cp /opt/local/lib/libomp/libomp_macports.dylib /opt/local/lib/libomp/libomp.dylib
# ensure the linking of libomp to the python wrapper shared lib is right (not overridden by matlab libomp)
- for f in wrapper/python/_FaustCorePy.cpython-*-darwin.so; do sudo install_name_tool -change @rpath/libiomp5.dylib /opt/local/lib/libomp/libomp.dylib $f;done
- sudo make install LANG=en_GB.UTF-8
#- 'sudo hdiutil create -volname Faust-$SHA_START-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust-$SHA_START -ov -format UDRW faust-$SHA_START'
- sudo pkgbuild --identifier fr.inria.faust --version $SHA_START --root /opt/local/faust-$SHA_START --install-location /opt/local/faust-$SHA_START --scripts . ./faust-$SHA_START.pkg
- for FILE in $(find /usr/local/lib ! -iname "libmatio*" -maxdepth 1 -mindepth 1); do filter_list+="--filter $(basename $FILE) "; done;
- sudo pkgbuild --identifier fr.inria.faust.matio --version 1.5.12 --root /usr/local/lib $filter_list --install-location /usr/local/lib ./matio-bin-1.5.12.pkg
- sudo pkgbuild --identifier fr.inria.faust.openmp --version 367070 --root /opt/local/lib/libomp --install-location /opt/local/lib/libomp ./libomp-367070.pkg
- productbuild --synthesize --package ./matio-bin-1.5.12.pkg --package libomp-367070.pkg --package faust-$SHA_START.pkg ./distribution.plist
- sed -e 's/\(.*pkg-ref id=.fr.inria.faust".*\)/\1<title>FAµST '$SHA_START'<\/title><license file="licenses.html"\/><readme file="installer_readme.html"\/>/' distribution.plist > tmp.plist; mv tmp.plist distribution.plist
- productbuild --distribution ./distribution.plist --package-path matio-bin-1.5.12.pkg --package-path libomp-367070.pkg --package-path faust-$SHA_START.pkg --resources doc ./faust-matio-omp-$SHA_START.pkg
- mv -f faust-matio-omp-$SHA_START.pkg faust-$SHA_START.pkg
# - if [[ -d $MACOS_PKG_STORE_PATH ]]; then sudo mv faust-$SHA_START.dmg faust-$SHA_START.pkg $MACOS_PKG_STORE_PATH; fi
#- if [[ -d $MACOS_PKG_STORE_PATH ]]; then sudo cp faust-$SHA_START.dmg faust-$SHA_START.pkg $MACOS_PKG_STORE_PATH; fi
- if [[ -d $MACOS_PKG_STORE_PATH ]]; then sudo cp faust-$SHA_START.pkg $MACOS_PKG_STORE_PATH; fi
artifacts: artifacts:
paths: paths:
- build/faust-${CI_COMMIT_SHA:0:8}.pkg - build/faust-${CI_COMMIT_SHA:0:8}.pkg
...@@ -219,38 +195,9 @@ pkg_linux: ...@@ -219,38 +195,9 @@ pkg_linux:
pkg_macos_release: pkg_macos_release:
script: script:
- export PYTHON_PATH=$(which python$NIX_PY_VER) - export FAUST_VERSION=$CI_COMMIT_TAG
- if [[ ! -d 'build' ]]; then mkdir build;fi; cd build - export EXPERIMENTAL_PKG=OFF
- 'cmake -DOpenMP_gomp_LIBRARY=/opt/local/lib/libomp/libgomp.dylib -DBUILD_WRAPPER_PYTHON=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DCMAKE_BUILD_TYPE=Release -DEXCLUDE_FAUST_LIB_INSTALL=ON -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" -DBUILD_MULTITHREAD=ON -DNOPY2=ON -DCMAKE_CXX_COMPILER=/opt/local/bin/clang++-mp-8.0 -DBUILD_FLOAT_PYX=ON -DBUILD_FLOAT_MEX=ON ..' - ./misc/continuous_integration/jobs/macosx/pkg_macos.sh
- otool -L wrapper/python/_FaustCorePy.cpython-*-darwin.so
- sudo rm -Rf /opt/local/faust # install dir
- 'sudo make install LANG=en_GB.UTF-8'
# ensure libomp path also in install path
- for f in wrapper/python/_FaustCorePy.cpython-*-darwin.so;do sudo install_name_tool -change @rpath/libiomp5.dylib /opt/local/lib/libomp/libomp.dylib $f;done
# - 'sudo hdiutil create -volname Faust-$CI_COMMIT_TAG-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust -ov -format UDRW faust-$CI_COMMIT_TAG'
- sudo pkgbuild --identifier fr.inria.faust --version $CI_COMMIT_TAG --root /opt/local/faust --install-location /opt/local/faust --scripts . ./faust-$CI_COMMIT_TAG.pkg
- productbuild --synthesize --package ./matio-bin-1.5.12.pkg --package libomp-367070.pkg --package faust-$CI_COMMIT_TAG.pkg ./distribution.plist
- sed -e 's/\(.*pkg-ref id=.fr.inria.faust".*\)/\1<title>FAµST '$CI_COMMIT_TAG'<\/title><license file="licenses.html"\/><readme file="installer_readme.html"\/>/' distribution.plist > tmp.plist; mv tmp.plist distribution.plist
- productbuild --distribution ./distribution.plist --package-path matio-bin-1.5.12.pkg --package-path libomp-367070.pkg --package-path faust-$CI_COMMIT_TAG.pkg --resources doc ./faust-matio-omp-$CI_COMMIT_TAG.pkg
- mv -f ./faust-matio-omp-$CI_COMMIT_TAG.pkg ./faust-$CI_COMMIT_TAG.pkg
#- if [[ -d $MACOS_PKG_STORE_PATH ]]; then sudo cp faust-$CI_COMMIT_TAG.dmg faust-$CI_COMMIT_TAG.pkg $MACOS_PKG_STORE_PATH; fi
- if [[ -d $MACOS_PKG_STORE_PATH ]]; then sudo cp faust-$CI_COMMIT_TAG.pkg $MACOS_PKG_STORE_PATH; fi
paths: paths:
- build/faust-${CI_COMMIT_TAG}.pkg - build/faust-${CI_COMMIT_TAG}.pkg
#!/usr/bin/bash
# Needed environment variables: FAUST_VERSION, NIX_PY_VER, DURL, DFILE, EXPERIMENTAL_PKG, MACOS_PKG_STORE_PATH (optional)
then
mkdir build
fi
cd build
cmake -DOpenMP_gomp_LIBRARY=/opt/local/lib/libomp/libgomp.dylib -DBUILD_WRAPPER_PYTHON=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_VERSION=$FAUST_VERSION -DCMAKE_BUILD_TYPE=Release -DEXCLUDE_FAUST_LIB_INSTALL=ON -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" -DBUILD_MULTITHREAD=ON -DNOPY2=ON -DCMAKE_CXX_COMPILER=/opt/local/bin/clang++-mp-8.0 -DBUILD_FLOAT_PYX=ON -DBUILD_FLOAT_MEX=ON -DEXPERIMENTAL_PKG=$EXPERIMENTAL_PKG ..
#TODO: why doing it two times?
#'sudo hdiutil create -volname Faust-$FAUST_VERSION-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust -ov -format UDRW faust-$FAUST_VERSION'
sudo pkgbuild --identifier fr.inria.faust --version $FAUST_VERSION --root /opt/local/faust --install-location /opt/local/faust --scripts . ./faust-$FAUST_VERSION.pkg
productbuild --synthesize --package ./matio-bin-1.5.12.pkg --package libomp-367070.pkg --package faust-$FAUST_VERSION.pkg ./distribution.plist
sed -e 's/\(.*pkg-ref id=.fr.inria.faust".*\)/\1<title>FAµST '$FAUST_VERSION'<\/title><license file="licenses.html"\/><readme file="installer_readme.html"\/>/' distribution.plist > tmp.plist; mv tmp.plist distribution.plist
productbuild --distribution ./distribution.plist --package-path matio-bin-1.5.12.pkg --package-path libomp-367070.pkg --package-path faust-$FAUST_VERSION.pkg --resources doc ./faust-matio-omp-$FAUST_VERSION.pkg
mv -f ./faust-matio-omp-$FAUST_VERSION.pkg ./faust-$FAUST_VERSION.pkg
#- if [[ -d $MACOS_PKG_STORE_PATH ]]; then sudo cp faust-$FAUST_VERSION.dmg faust-$FAUST_VERSION.pkg $MACOS_PKG_STORE_PATH; fi
if [[ -d "$MACOS_PKG_STORE_PATH" ]]; then sudo cp faust-$FAUST_VERSION.pkg $MACOS_PKG_STORE_PATH; fi
