Commit d89545d6 authored by hhakim's avatar hhakim
Correct macos SZIP lib path (more standard).
parent dbe56ccd
...@@ -20,7 +20,7 @@ variables: ...@@ -20,7 +20,7 @@ variables:
MACOS_HDF5_SLIB_PATH: '/opt/local/lib/libhdf5.a' MACOS_HDF5_SLIB_PATH: '/opt/local/lib/libhdf5.a'
MACOS_ZLIB_SLIB_PATH: '/opt/local/lib/libz.a' MACOS_ZLIB_SLIB_PATH: '/opt/local/lib/libz.a'
MACOS_MATIO_SLIB_PATH: '/usr/local/lib/libmatio.a' MACOS_MATIO_SLIB_PATH: '/usr/local/lib/libmatio.a'
MACOS_SZIP_SLIB_PATH: '/usr/local/lib/szip.a' MACOS_SZIP_SLIB_PATH: '/opt/local/lib/libsz.a'
.ctest_template: &ctest_script .ctest_template: &ctest_script
script: script:
