Commit d87df8fc authored by hhakim's avatar hhakim
Add SVD alternative analytical solution for rank-1 approximation.
parent 6cfb1e53
......@@ -138,6 +138,7 @@ namespace Faust
template<typename FPP>
class MatDense<FPP,Cpu> : public MatGeneric<FPP,Cpu>
using EigDenseMat = Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>;
friend class MatSparse<FPP,Cpu>;
friend class MatBSR<FPP, Cpu>;
......@@ -523,6 +524,9 @@ namespace Faust
void best_low_rank(const int &r, MatDense<FPP,Cpu> &bestX, MatDense<FPP, Cpu> &bestY) const;
void best_low_rank2(MatDense<FPP,Cpu> &bestX, MatDense<FPP, Cpu> &bestY) const;
void best_low_rank3(MatDense<FPP,Cpu> &bestX, MatDense<FPP, Cpu> &bestY) const;
void solveNullspaceQR(MatDense<FPP, Cpu>& X) const;
void initJacobiSVD(Eigen::JacobiSVD<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>>& svd);
......@@ -1437,6 +1437,57 @@ void MatDense<FPP, Cpu>::best_low_rank2(MatDense<FPP,Cpu> &bestX, MatDense<FPP,
bestY.adjoint();
void MatDense<FPP, Cpu>::solveNullspaceQR(MatDense<FPP, Cpu>& X) const
//TODO: X should be a vector
auto qr = mat.transpose().colPivHouseholderQr();
EigDenseMat Q = qr.householderQ();
X.mat = Q.col(mat.rows()-1);
void MatDense<FPP, Cpu>::best_low_rank3(MatDense<FPP,Cpu> &bestX, MatDense<FPP, Cpu> &bestY) const
// NOTE: this function is another try to do faster than best_low_rank in the particular case of nrows == 2
assert(this->getNbRow() == 2);
MatDense<FPP, Cpu> AtA;
MatDense<FPP, Cpu> tAA;
bestX.resize(this->getNbRow(), 1);
bestY.resize(this->getNbCol(), 1);
gemm(*this, *this, AtA, FPP(1.0), FPP(0.0), 'N', 'H');
auto singular_vec = [](const MatDense<FPP, Cpu>& A, MatDense<FPP, Cpu>& vec, FPP& lambda)
FPP a = 1, b, c;
b = - A(0, 0) - A(1, 1);
c = A(0, 0) * A(1, 1);
FPP delta = b * b - 4 * a * c;
// FPP lambda1 = (- b - std::sqrt(delta)) / 2 / a;
// FPP lambda2 = (- b + std::sqrt(delta)) / 2 / a;
FPP lambda1 = (- b - std::sqrt(delta)) / a;
FPP lambda2 = (- b + std::sqrt(delta)) / a;
FPP abs_lambda1 = std::abs(lambda1);
FPP abs_lambda2 = std::abs(lambda2);
lambda = abs_lambda1 > abs_lambda2? abs_lambda1:abs_lambda2;
MatDense<FPP, Cpu> A_minus_lambdaI(2, 2);
MatDense<FPP, Cpu> lambdaI(2, 2);
lambdaI.setEyes();
lambdaI.scalarMultiply(lambda);
A_minus_lambdaI.mat = A.mat - lambdaI.mat;
A_minus_lambdaI.solveNullspaceQR(vec);
// std::cout << "lambda: " << lambda << std::endl;
// std::cout << "vec: " << vec.mat << std::endl;
FPP lambda;
// left singular vector
singular_vec(AtA, bestX, lambda);
MatDense<FPP, Cpu> bestX2, bestY2;
// right singular vector
bestX.mat *= sqrt(lambda);
bestY.mat = bestX.mat.householderQr().solve(mat);
bestY.adjoint();
void MatDense<FPP, Cpu>::approx_rank1(MatDense<FPP,Cpu> &bestX, MatDense<FPP, Cpu> &bestY) const
