Commit d850c29f authored by testcdash Nicolas Bellot's avatar testcdash Nicolas Bellot Committed by hhakim
No commit message
No commit message
parent ed202fff
...@@ -45,7 +45,7 @@ if(UNIX) ...@@ -45,7 +45,7 @@ if(UNIX)
endif() endif()
elseif(WIN32) elseif(WIN32)
# MODIF ALALAL # MODIF ALALAL
#set(LDD_MEX_FLAGS "-L${FAUST_BIN_DIR}" "-l${FAUST_TARGET}") set(LDD_MEX_FLAGS "-L${FAUST_BIN_DIR}" "-l${FAUST_TARGET}")
endif() endif()
if(UNIX) if(UNIX)
...@@ -60,11 +60,10 @@ elseif(WIN32) ...@@ -60,11 +60,10 @@ elseif(WIN32)
add_custom_target(MEXFILE_TARGET_LIST_TARGET DEPENDS ${MEXFILE_TARGET_LIST}) add_custom_target(MEXFILE_TARGET_LIST_TARGET DEPENDS ${MEXFILE_TARGET_LIST})
add_custom_target(MEXOBJ_FILES_TARGET DEPENDS ${MEXOBJ_FILES}) add_custom_target(MEXOBJ_FILES_TARGET DEPENDS ${MEXOBJ_FILES})
add_dependencies(MEXFILE_TARGET_LIST_TARGET MEXOBJ_FILES_TARGET) add_dependencies(MEXFILE_TARGET_LIST_TARGET MEXOBJ_FILES_TARGET)
######## file(GLOB CPP_SRC_FILES "${FAUST_EXCEPTION_SRC_DIR}/*.cpp" "${FAUST_MATRIX_SRC_DIR}/*.cpp" "${FAUST_FAUSTCORE_SRC_DIR}/*.cpp" "${FAUST_PALM4MSA_SRC_DIR}/*.cpp" "${FAUST_MEXINTERFACETOOLS_SRC_DIR}/*.cpp") ######## file(GLOB CPP_SRC_FILES "${FAUST_EXCEPTION_SRC_DIR}/*.cpp" "${FAUST_MATRIX_SRC_DIR}/*.cpp" "${FAUST_FAUSTCORE_SRC_DIR}/*.cpp" "${FAUST_PALM4MSA_SRC_DIR}/*.cpp" "${FAUST_MEXINTERFACETOOLS_SRC_DIR}/*.cpp")
endif() endif()
foreach(mex_target ${MEXFILE_TARGET_LIST}) foreach(mex_target ${MEXFILE_TARGET_LIST})
if(WIN32) if(WIN32)
add_custom_target(${mex_target} DEPENDS ${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp ${mex_target}.${MEX_EXT} MEXOBJ_FILES_TARGET ) add_custom_target(${mex_target} DEPENDS ${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp ${mex_target}.${MEX_EXT} MEXOBJ_FILES_TARGET )
...@@ -96,15 +95,19 @@ foreach(mex_target ${MEXFILE_TARGET_LIST}) ...@@ -96,15 +95,19 @@ foreach(mex_target ${MEXFILE_TARGET_LIST})
endif(APPLE) endif(APPLE)
file(GLOB OBJ_MEXTOOLS_FILES "${FAUST_TMPMEX_DIR}/*.${MEXOBJ_EXT}")
add_custom_command(OUTPUT ${mex_target}.${MEX_EXT} add_custom_command(OUTPUT ${mex_target}.${MEX_EXT}
COMMAND ${MATLAB_ROOT}/bin/mex COMMAND ${MATLAB_ROOT}/bin/mex
ARGS "-v" "-largeArrayDims" "${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp" "${FAUST_TMPMEX_DIR}/*.${MEXOBJ_EXT}" ARGS "-v" "-largeArrayDims" "${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp" ${OBJ_MEXTOOLS_FILES}
${CMAKE_CXX_FLAGS_LIST} ${CMAKE_CXX_FLAGS_LIST}
DEPENDS ${MEXOBJ_FILES} DEPENDS ${MEXOBJ_FILES}
COMMENT "Creating mex function ${mex_target}.${MEX_EXT}") COMMENT "Creating mex function ${mex_target}.${MEX_EXT}"
#message(STATUS "ALALALALALAAL \"${FAUST_TMPMEX_DIR}/\\*.${MEXOBJ_EXT}\" ")
else() else()
message(FATAL_ERROR "Unable to compile mex functions")
message(FATAL_ERROR "Unable to compile mex functions for this platform")
endif() endif()
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/${mex_target}.m ${FAUST_MATLAB_MEX_BIN_DIR}/${mex_target}.m COPYONLY) configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/${mex_target}.m ${FAUST_MATLAB_MEX_BIN_DIR}/${mex_target}.m COPYONLY)
install(FILES ${FAUST_MATLAB_MEX_BIN_DIR}/${mex_target}.m DESTINATION ${FAUST_MATLAB_MEX_INSTALL_DIR}) install(FILES ${FAUST_MATLAB_MEX_BIN_DIR}/${mex_target}.m DESTINATION ${FAUST_MATLAB_MEX_INSTALL_DIR})
