Commit d1857042 authored by hhakim's avatar hhakim
Fix pyfaust.dft and matfaust.dft doc.
parent a1f9d480
%> @brief Constructs a Faust F implementing the Discrete Fourier Transform (DFT) order n. %> @brief Constructs a Faust F implementing the Discrete Fourier Transform (DFT) of order n.
%> The factorization algorithm used is Cooley-Tukey (FFT). %> The factorization algorithm used is Cooley-Tukey (FFT).
%> The factorization corresponds to the butterfly structure of the Cooley-Tukey %> The factorization corresponds to the butterfly structure of the Cooley-Tukey
%> FFT algorithm. The resulting Faust is complex and has (log2(n)+1) sparse %> FFT algorithm. The resulting Faust is complex and has (log2(n)+1) sparse
%> factors whose the log2(n) first has 2 nonzeros per row and per column. The %> factors. The log2(n) first has 2 nonzeros per row and per column. The
%> last factor is a bit-reversal permutation matrix. %> last factor is a bit-reversal permutation matrix.
%> @b Usage %> @b Usage
...@@ -3256,12 +3256,12 @@ def wht(n, normed=True, dev="cpu", dtype='double'): ...@@ -3256,12 +3256,12 @@ def wht(n, normed=True, dev="cpu", dtype='double'):
def dft(n, normed=True, dev='cpu', diag_opt=False): def dft(n, normed=True, dev='cpu', diag_opt=False):
Constructs a Faust F implementing the Discrete Fourier Transform (DFT) order n. Constructs a Faust F implementing the Discrete Fourier Transform (DFT) of order n.
The factorization corresponds to the butterfly structure of the The factorization corresponds to the butterfly structure of the
Cooley-Tukey FFT algorithm. Cooley-Tukey FFT algorithm.
The resulting Faust is complex and has (log2(n)+1) sparse factors The resulting Faust is complex and has (log2(n)+1) sparse factors.
whose the log2(n) first has 2 nonzeros per row and per column. The log2(n) first has 2 nonzeros per row and per column.
The last factor is a bit-reversal permutation matrix. The last factor is a bit-reversal permutation matrix.
Args: Args:
...@@ -3296,8 +3296,7 @@ def dft(n, normed=True, dev='cpu', diag_opt=False): ...@@ -3296,8 +3296,7 @@ def dft(n, normed=True, dev='cpu', diag_opt=False):
>>> dft(1024, normed=True) # is equiv. to next call >>> dft(1024, normed=True) # is equiv. to next call
>>> dft(1024, normed=False).normalize() # which is less optimized though >>> dft(1024, normed=False).normalize() # which is less optimized though
<b>See also:</b> pyfaust.tools.bitrev, pyfaust.wht, pyfaust.dct, <b>See also:</b> pyfaust.tools.bitrev, pyfaust.wht, pyfaust.dct, pyfaust.dst, scipy.fft.fft, pyfaust.fact.butterfly, pyfaust.rand_butterfly.
log2n = np.floor(np.log2(n)) log2n = np.floor(np.log2(n))
if(n > 2**log2n): raise ValueError("n must be a power of 2.") if(n > 2**log2n): raise ValueError("n must be a power of 2.")
