Commit d0d2276c authored by hhakim's avatar hhakim
Replace the use_csr (boolean) parameter by the new factor_format...
Replace the use_csr (boolean) parameter by the new factor_format (:='dense'|'sparse'|'dynamic') parameter everywhere it applies in the pyfaust package.
It allows to use in palm4msa and hierarchical functions the dynamic output format of prox implemented in the previous commit.
parent 2ed2239c
Loading
