Commit cd539411 authored by hhakim's avatar hhakim
Minor changes.
- Update changelog with git commit sha1 prefixes to keep correspondence with old svn revisions.
- Rename version_log.txt to CHANGELOG.md.
parent 3f3f06b2
# FAuST Toolbox -- Flexible Approximate Multi-Layer Sparse Transform
**NOTE**: below this line are old changelog messages from the previous svn repository (in each start of line is displayed the svn revision and in parenthesis the corresponding git SHA1 prefix obtained after migration from svn to git).
- version 1121 (ce24328c): debut compatibility with complex dans le wrapper Matlab
- version 1116 (cfcdaa01):
* debut compatibility with complex
* test unitaire
- version 1115 (c6fbde76): Faust with MatGeneric
* wrapper matlab OK
* wrapper python Ok (but not tested on VM)
- version 1105 (ec5c6afe):
* MATLAB wrapper (debut compatibility Faust::MatGeneric)
- version 1104 (322254ff):
* avoid memory leak due to std::vector<Faust::MatGeneric*>, solution: create virtual destructor for abstract class Faust::MatGeneric
- version 1103 (5310d86d):
* test MATFILE marche
- version 1100 (ce26754e):
* début [trunk] merge avec branch Faust_mat_generic: les faust sont une liste de matrice generique, pas forcement des matrice creuses
* wrapper matlab HS
* wrapper python HS
- version 1096 (90f982ed):
* wrapper matlab OK
* wrapper python OK
######## FAuST Toolbox ##########
######## Flexible Approximate Multi-Layer Sparse Transform ##########
version 1121 : debut compatibility with complex dans le wrapper Matlab
version 1116 : debut compatibility with complex
-> test unitaire
version 1115 : Faust with MatGeneric
-> wrapper matlab OK
-> wrapper python Ok (but not tested on VM)
version 1105 :
-> MATLAB wrapper (debut compatibility Faust::MatGeneric)
version 1104 :
-> avoid memory leak due to std::vector<Faust::MatGeneric*>, solution: create virtual destructor for abstract class Faust::MatGeneric
version 1103 :
-> test MATFILE marche
version 1100 :
début [trunk] **** merge avec branch Faust_mat_generic **** : les faust sont une liste de matrice generique, pas forcement des matrice creuses
-> wrapper matlab HS
-> wrapper python HS
version 1096 :
-> wrapper python OK
