Commit ccbac495 authored by hhakim's avatar hhakim
Optimize matfaust Faust-matrix product when Matlab interleaved API is used...
Optimize matfaust Faust-matrix product when Matlab interleaved API is used (MATLAB_2017_API=OFF) by avoiding two copies (the input matrix and the output matrix).
parent af9b2a87
Tags 3.20.0
Pipeline #834048 skipped
...@@ -47,29 +47,52 @@ void faust_multiply(const mxArray **prhs, const int nrhs, mxArray **plhs, const ...@@ -47,29 +47,52 @@ void faust_multiply(const mxArray **prhs, const int nrhs, mxArray **plhs, const
if (typeid(Faust::TransformHelper<double,DEV>) == typeid(Faust::TransformHelper<SCALAR,DEV>) && mxIsComplex(inMatlabMatrix) ) if (typeid(Faust::TransformHelper<double,DEV>) == typeid(Faust::TransformHelper<SCALAR,DEV>) && mxIsComplex(inMatlabMatrix) )
mexErrMsgTxt("impossibile to multiply a real Faust with complex matrix"); mexErrMsgTxt("impossibile to multiply a real Faust with complex matrix");
#ifdef MX_HAS_INTERLEAVED_COMPLEX
newMxGetData(ptr_data, inMatlabMatrix);
#else
mxArray2Ptr(inMatlabMatrix, ptr_data); mxArray2Ptr(inMatlabMatrix, ptr_data);
#endif
if(nbColA == 1) if(nbColA == 1)
// applying the Faust to a vector // applying the Faust to a vector
SCALAR* ptr_out;
mwSize out_dims[2] = {nbRowB, 1};
plhs[0] = helperCreateNumMxArray<SCALAR>(out_dims);
core_ptr->multiply(ptr_data, ptr_out, transpose_flag);
#else
Faust::Vect<SCALAR,Cpu> A(nbRowA, ptr_data); Faust::Vect<SCALAR,Cpu> A(nbRowA, ptr_data);
Faust::Vect<SCALAR,Cpu> B(nbRowB); Faust::Vect<SCALAR,Cpu> B(nbRowB);
B = (*core_ptr).multiply(A, transpose_flag); B = (*core_ptr).multiply(A, transpose_flag);
plhs[0]=FaustVec2mxArray(B);
#endif
else else
{ // applying the Faust to a matrix { // applying the Faust to a matrix
SCALAR* ptr_out;
mwSize out_dims[2] = {nbRowB, nbColA};
newMxGetData(ptr_out, plhs[0]);
core_ptr->multiply(ptr_data, nbColA, ptr_out);
#else
Faust::MatDense<SCALAR,Cpu> A(ptr_data, nbRowA, nbColA); Faust::MatDense<SCALAR,Cpu> A(ptr_data, nbRowA, nbColA);
Faust::MatDense<SCALAR,Cpu> B(nbRowB, nbColA); Faust::MatDense<SCALAR,Cpu> B(nbRowB, nbColA);
plhs[0]=FaustMat2mxArray(B); plhs[0]=FaustMat2mxArray(B);
#endif
#ifndef MX_HAS_INTERLEAVED_COMPLEX
if(ptr_data) {delete [] ptr_data ; ptr_data = NULL;} if(ptr_data) {delete [] ptr_data ; ptr_data = NULL;}
#endif
