Commit cbfc66aa authored by hhakim's avatar hhakim
Fix SKPERM infinite loop (issue #248).
parent 5db6d40c
Pipeline #834064 skipped
......@@ -45,6 +45,7 @@
#include <iostream>
#include <type_traits>
#include <complex>
#include <cmath>
// const char * interface_prox_name="prox : ";
......@@ -559,7 +560,6 @@ void Faust::prox_skperm(Faust::MatDense<FPP, Cpu> & M_, const unsigned int k, co
parent.setConstant(-1);
visited.setZero();
slack.setConstant(inf);
// slack.setConstant(1e-10);
int unmatched_vertex = -1;
for(int v=0; v < size; v++)
......@@ -568,15 +568,15 @@ void Faust::prox_skperm(Faust::MatDense<FPP, Cpu> & M_, const unsigned int k, co
q.push(std::make_pair(0,v));
visited(0,v) = 1;
assert(visited(0,v) == 1);
while(true)
if(q.empty())
if(q.empty() || q.size() <= 0)
Real<FPP> delta = inf;
q = queue<pair<int,int>>();
Real<FPP> delta = INFINITY;//numeric_limits<Real<FPP>>::infinity();
for(int side=0;side<2;side++)
for(int vertex=0; vertex < size; vertex++)
......@@ -612,6 +612,8 @@ void Faust::prox_skperm(Faust::MatDense<FPP, Cpu> & M_, const unsigned int k, co
if(side == 1 && degree(side, vertex) < k)
unmatched_vertex = vertex;
if(unmatched_vertex < 0) // simulate python negative index
unmatched_vertex == degree.cols()+unmatched_vertex;
degree(1, unmatched_vertex) += 1;
break;
......@@ -641,12 +643,12 @@ void Faust::prox_skperm(Faust::MatDense<FPP, Cpu> & M_, const unsigned int k, co
Real<FPP> p_diff = weight(u) - potential(side, vertex) - potential(1 - side, u);
if(std::abs(p_diff) > eps)
if(side == 0 && ! visited(1 - side, u) && (p_diff) > 0 && (p_diff) < (slack(1-side, u)))
if(side == 0 && ! visited(1 - side, u) && p_diff > 0 && p_diff < (slack(1-side, u)))
slack(1, u) = p_diff;
parent(1, u) = vertex;
if(side == 1 && ! visited(1 - side, u) && (p_diff) < 0 && - (p_diff) < (slack(1-side, u)))
if(side == 1 && ! visited(1 - side, u) && p_diff < 0 && - p_diff < (slack(1-side, u)))
slack(0, u) = - p_diff;
parent(0, u) = vertex;
......@@ -670,7 +672,11 @@ void Faust::prox_skperm(Faust::MatDense<FPP, Cpu> & M_, const unsigned int k, co
while(true)
if(v < 0)
v = parent.cols()+v;
auto u = parent(1, v);
if(u < 0)
u = parent.cols()+u;
auto p = parent(0, u);
matching(u, v) = 1;
if(p == -1)
