Commit cb2d2247 authored by hhakim's avatar hhakim
Fix in NSIS installer the expfiltered directory present in matlab folder after install.
parent 3c2cf22c
Pipeline #834188 skipped
...@@ -121,6 +121,9 @@ Section "" ; no component so name not needed ...@@ -121,6 +121,9 @@ Section "" ; no component so name not needed
File /nonfatal /r /x old_matlab @PROJECT_BINARY_DIR@\wrapper\matlab\*.m @PROJECT_BINARY_DIR@\wrapper\matlab\*.@MEX_EXT@ @PROJECT_BINARY_DIR@\wrapper\matlab\*.mat File /nonfatal /r /x old_matlab @PROJECT_BINARY_DIR@\wrapper\matlab\*.m @PROJECT_BINARY_DIR@\wrapper\matlab\*.@MEX_EXT@ @PROJECT_BINARY_DIR@\wrapper\matlab\*.mat
; nonfatal useful in case of data *.mat not used/present (because they are downloaded at installation) ; nonfatal useful in case of data *.mat not used/present (because they are downloaded at installation)
; workaround to the installation of a directory that shouldn't be installed (because normally excluded by CMake. I think it happens only on Windows)
; TODO: fix this issue directly in CMake (if possible)
RMDir /r "$INSTDIR\matlab\expfiltered"
; check the python version matches python major.minor version used to build the the wrapper shared library ; check the python version matches python major.minor version used to build the the wrapper shared library
Exec "python --version | python -c $\"import re; ver = input(); exit(0) if re.match('Python @WIN_PY_VER@', ver) else exit(1)$\"" Exec "python --version | python -c $\"import re; ver = input(); exit(0) if re.match('Python @WIN_PY_VER@', ver) else exit(1)$\""
