Commit c9e4f396 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
debug cmakelist
parent 442002db
...@@ -193,7 +193,7 @@ option(BUILD_MATLAB_MEX_FILES "Enable building Matlab MEX files." ON) ...@@ -193,7 +193,7 @@ option(BUILD_MATLAB_MEX_FILES "Enable building Matlab MEX files." ON)
option(BUILD_OPENBLAS "Using openBLAS for matrix and vector computations" OFF) option(BUILD_OPENBLAS "Using openBLAS for matrix and vector computations" OFF)
# different type of files # different type of files
option(BUILD_READ_XML_FILE "Using xml configuration to read xml files" OFF) option(BUILD_READ_XML_FILE "Using xml configuration to read xml files" OFF)
option(BUILD_READ_MAT_FILE "Using matio library to read mat files" ON) option(BUILD_READ_MAT_FILE "Using matio library to read mat files" OFF)
#CMAKE_DEPENDENT_OPTION #CMAKE_DEPENDENT_OPTION
###### Different option of configuration ###### ###### Different option of configuration ######
