Commit c69eb410 authored by hhakim's avatar hhakim
Remove the memory address of Matrix output (as it was before).
The reason is the need of reproducibility in examples. It should be
replaced by a function which gets the address of a particular factor in
a Faust.
parent 1a1e1ef0
Loading
