Commit bdb5e5d4 authored by hhakim's avatar hhakim
Update matfaust.fact.butterfly to optionally pass one permutation to the mex code.
parent 87d55588
...@@ -28,14 +28,21 @@ function F = butterfly(M, varargin) ...@@ -28,14 +28,21 @@ function F = butterfly(M, varargin)
import matfaust.Faust import matfaust.Faust
nargin = length(varargin); nargin = length(varargin);
type = 'right'; type = 'right';
perm = [];
if(nargin > 0) if(nargin > 0)
for i=1:nargin for i=1:2:nargin
switch(varargin{i}) switch(varargin{i})
case 'type' case 'type'
if(nargin < i+1 || ~ any(strcmp(varargin{i+1}, {'right', 'left', 'bbtree'}))) if(nargin < i+1 || ~ any(strcmp(varargin{i+1}, {'right', 'left', 'bbtree'})))
error('keyword argument ''type'' must be followed by ''left'' or ''right'' or ''bbtree''') error('keyword argument ''type'' must be followed by ''left'' or ''right'' or ''bbtree''')
else else
type = varargin{i+1}; type = varargin{i+1};
case 'perm'
if(nargin < i+1 || ~ strcmp(varargin{i+1}, 'default_8') && ~ is_array_of_indices(varargin{i+1}, M) && ~ is_cell_arrays_of_indices(varargin{i+1}, M))
error('keyword argument ''perm'' must be followed by ''default_8'', an array of permutation indices or a cell array of arrays of permutation indices')
else
perm = varargin{i+1};
end end
end end
end end
...@@ -48,14 +55,32 @@ function F = butterfly(M, varargin) ...@@ -48,14 +55,32 @@ function F = butterfly(M, varargin)
type = 2; type = 2;
end end
if(strcmp(class(M), 'single')) if(strcmp(class(M), 'single'))
core_obj = mexButterflyRealFloat(M, type); core_obj = mexButterflyRealFloat(M, type, perm);
F = Faust(core_obj, isreal(M), 'cpu', 'float'); F = Faust(core_obj, isreal(M), 'cpu', 'float');
else else
if(isreal(M)) if(isreal(M))
core_obj = mexButterflyReal(M, type); core_obj = mexButterflyReal(M, type, perm);
else else
core_obj = mexButterflyCplx(M, type); core_obj = mexButterflyCplx(M, type, perm);
end end
F = Faust(core_obj, isreal(M)); F = Faust(core_obj, isreal(M));
end end
end end
function b = is_array_of_indices(value, M)
s = size(M,2);
b = ismatrix(value) && isnumeric(value) && isreal(value);
b = b && all(value <= s);
b = b && all(value > 0);
b = b && length(value) == s;
function b = is_cell_arrays_of_indices(value, M)
b = iscell(value);
for i=1:length(value)
b = b && is_array_of_indices(value{i}, M);
if ~ b
break
