Commit bd9f0434 authored by hhakim's avatar hhakim
Update pyfaust install in virtual environment guide for Anaconda packages.
parent fb2d930d
\page install_pyfaust_in_venv Installing pyfaust in Python virtual environments \page install_pyfaust_in_venv Installing pyfaust in Python virtual environments (Python venv & Anaconda)
Python @PY3_VER@ ## SUMMARY
[1. Python @PY3_VER@](#python_venv)
[2. Anaconda](#anaconda)
\anchor python_venv
1. Python @PY3_VER@
First, you need to create your virtual environment into a directory reserved to pyfaust: First, you need to create your virtual environment into a directory reserved to pyfaust:
...@@ -37,13 +42,36 @@ As a result, you should see the version of pyfaust installed if all went properl ...@@ -37,13 +42,36 @@ As a result, you should see the version of pyfaust installed if all went properl
\note On Mac OS X you might need to install OpenMP for pyfaust to work, for further information please look at this [FAQ entry](https://faustgrp.gitlabpages.inria.fr/faust/last-doc/html/FAQ.html#py_four). \note On Mac OS X you might need to install OpenMP for pyfaust to work, for further information please look at this [FAQ entry](https://faustgrp.gitlabpages.inria.fr/faust/last-doc/html/FAQ.html#py_four).
Anaconda \anchor anaconda
======== 2. Anaconda
Within Anaconda you can also create a virtual environment and install pyfaust there. It's quite similar to the Python way described in the previous section. In that purpose you'll need to use the command conda-create. Please type the following commands in an Anaconda prompt or a shell prompt:
Create the virtual environment:
conda create -n pyfaust_venv python==3.9
Add conda-forge channel (it is necessary for pyfaust dependencies on Mac OS X and Windows):
conda config --add channels conda-forge
Load the virtual environment created earlier and install pyfaust:
conda activate pyfaust_venv
conda install -c pyfaust pyfaust
\note the -c flag specifies the channel from which to retrieve the pyfaust package.
Within Anaconda you can also create virtual environments and use pyfaust into it. It's quite similar to the Python way described in previous sections. For that purpose you'll use the command conda create. Try if it works:
Please rely on the documentation here: https://docs.conda.io/en/latest/ python -c "import pyfaust as pf; print(pf.rand(5,5))"
Faust size 5x5, density 5, nnz_sum 125, 5 factor(s):
- FACTOR 0 (double) SPARSE, size 5x5, density 1, nnz 25
- FACTOR 1 (double) SPARSE, size 5x5, density 1, nnz 25
- FACTOR 2 (double) SPARSE, size 5x5, density 1, nnz 25
- FACTOR 3 (double) SPARSE, size 5x5, density 1, nnz 25
- FACTOR 4 (double) SPARSE, size 5x5, density 1, nnz 25
Or for more details about this specific command please look here: [conda-create](https://docs.conda.io/projects/conda/en/latest/commands/create.html)
Please note that if you're using conda, you still need to install pyfaust (whl) package through pip. You can install pip with conda and then install pyfaust pip package as described above with a pip install command (in a conda virtual environment or not). And final point, don't forget to use the good version of python3: @PY3_VER@.x. Fore further information please rely on the documentation [here](https://docs.conda.io/en/latest/) or about the specific conda-create command please look here: [conda-create](https://docs.conda.io/projects/conda/en/latest/commands/create.html).
