GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
bbe34f3c
bbe34f3c
9 years ago
Nicolas Bellot
Committed by
hhakim
2 years ago
Downloads
Patches
test matlab en premier
3216a58e
Branches containing commit
misc/test/CMakeLists.txt
+47
-26
47 additions, 26 deletions
47 additions
26 deletions
47
26
bbe34f3c
@@ -15,6 +15,49 @@ if(BUILD_OPENBLAS)
endif
endif
# Testing with CTest
# CTest is a testing tool distributed as a part of CMake.
# Running the differents binary created in this project
# Critical time, which fixe the limit time of the process
set
TIMEOUT_MEG 8000
set
TIMEOUT_COMP 100
# MATLAB TEST
if
BUILD_MATLAB_MEX_FILES
add_test
NAME FAUST_HIER_MEX COMMAND matlab -nojvm -r
"try;testpass=0;addpath('
FAUST_BIN_TEST_BIN_DIR
FAUST_BIN_TEST_TOOLS_DIR
');set_path;hier_fact_test('config_compared_hierarchical_fact',9402,1); catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME FAUST_MEG_MEX COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_MEG',22450,100);catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME FAUST_HADAMARD_MEX COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_HADAMARD',5941,1);catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME DEMO_MATLAB COMMAND matlab -nodesktop -r
FAUST_MATLAB_INSTALL_DIR
');setup_FAUST;run_all_demo;catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FAUST COMMAND matlab -nojvm -r
');set_path;test_matlab_faust;catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
# limit the time of the process in case of bug...
#CTEST_FULL_OUTPUT
set_tests_properties
FAUST_HIER_MEX FAUST_HADAMARD_MEX PROPERTIES TIMEOUT 100
DEMO_MATLAB PROPERTIES TIMEOUT 6000
MATLAB_FAUST PROPERTIES TIMEOUT 15
FAUST_MEG_MEX PROPERTIES TIMEOUT
TIMEOUT_MEG
endif
####### IF THE MATIO LIBRARY IS AVAILABLE ELSE WE USE TXT OR XML DATA #######
if
MATIO_LIB_FILE AND MATIO_INC_DIR AND BUILD_READ_MAT_FILE
# AND HDF5_LIB_FILE)
if
@@ -60,20 +103,14 @@ if (BUILD_MATLAB_MEX_FILES)
foreach
matlabtest hier_fact_test.m test_matlab_faust.m
foreach
configure_file
FAUST_SRC_TEST_SRC_DIR
matlabtest
matlabtest
COPY
ONLY
configure_file
matlabtest
matlabtest
ONLY
endforeach
endforeach
endif
endif
set
TIMEOUT_MEG 8000
set
TIMEOUT_COMP 100
# MATLAB input format
@@ -121,23 +158,7 @@ endif(BUILD_READ_XML_FILE)
if
add_test
add_test
add_test
add_test
add_test
#CTEST_FULL_OUTPUT
TIMEOUT_MEG
endif
This diff is collapsed.
Loading
Save comment
