Commit ae0b908e authored by hhakim's avatar hhakim
Update pure gpu splin, spcol, sp proxs tests (prog. arguments and output).
parent 51b659dc
...@@ -2,6 +2,8 @@ ...@@ -2,6 +2,8 @@
#include "faust_MatDense_gpu.h" #include "faust_MatDense_gpu.h"
#include "faust_prox_gpu.h" #include "faust_prox_gpu.h"
#include <iostream> #include <iostream>
//#include "faust_init_from_matio_params.h"
//#include "faust_init_from_matio_core.h"
/** \brief unitary test for MatDense conjugate /** \brief unitary test for MatDense conjugate
...@@ -29,10 +31,20 @@ int main(int argc, char* argv[]) ...@@ -29,10 +31,20 @@ int main(int argc, char* argv[])
faust_unsigned_int dim1 = 204; faust_unsigned_int dim1 = 204;
faust_unsigned_int dim2 = 204; faust_unsigned_int dim2 = 204;
// auto MatrixFilename = "D.mat";
// Faust::MatDense<FPP,Cpu> D;
// init_faust_mat_from_matio(D,MatrixFilename,"D");
auto num_its = 30000; auto num_its = 60;
auto k = dim1/10; auto k = 1632;
char* str_k = getenv("K");
if(str_k)
k = std::atoi(str_k);
if(argc > 1) if(argc > 1)
...@@ -47,10 +59,19 @@ int main(int argc, char* argv[]) ...@@ -47,10 +59,19 @@ int main(int argc, char* argv[])
std::cout << "M nrows: " << dim1 << std::endl;
std::cout << "M ncols: " << dim2 << std::endl;
cout << "k:" << k << endl;
std::cout << "benchmark num_its: " << num_its << std::endl;
MatDense<FPP,Cpu>* M; MatDense<FPP,Cpu>* M;
MatDense<FPP,GPU2> M1, M2; MatDense<FPP,GPU2> M1, M2;
M = MatDense<FPP,Cpu>::randMat(dim1,dim2); M = MatDense<FPP,Cpu>::randMat(dim1,dim2);
*M *= FPP(100); // M = &D;
// M->Display();
// *M *= FPP(100);
M1 = *M; M1 = *M;
M2 = *M; M2 = *M;
...@@ -61,17 +82,28 @@ int main(int argc, char* argv[]) ...@@ -61,17 +82,28 @@ int main(int argc, char* argv[])
for(int i=0; i < num_its; i++) for(int i=0; i < num_its; i++)
pure_gpu_prox_start = std::chrono::steady_clock::now(); pure_gpu_prox_start = std::chrono::steady_clock::now();
prox_sp(M1, k, /* normalized */ false, /* pos*/ false, /* pure_gpu */ true); prox_sp(M1, k, /* normalized */ true, /* pos*/ false, /* pure_gpu */ true);
pure_gpu_prox_end = std::chrono::steady_clock::now(); pure_gpu_prox_end = std::chrono::steady_clock::now();
pure_gpu_prox_dur += pure_gpu_prox_end-pure_gpu_prox_start; pure_gpu_prox_dur += pure_gpu_prox_end-pure_gpu_prox_start;
gpu_cpu_rt_prox_start = std::chrono::steady_clock::now(); gpu_cpu_rt_prox_start = std::chrono::steady_clock::now();
prox_sp(M2, k, /* normalized */ false, /* pos*/ false, /* pure_gpu */ false); prox_sp(M2, k, /* normalized */ true, /* pos*/ false, /* pure_gpu */ false);
gpu_cpu_rt_prox_end = std::chrono::steady_clock::now(); gpu_cpu_rt_prox_end = std::chrono::steady_clock::now();
gpu_cpu_rt_prox_dur += gpu_cpu_rt_prox_end-gpu_cpu_rt_prox_start; gpu_cpu_rt_prox_dur += gpu_cpu_rt_prox_end-gpu_cpu_rt_prox_start;
assert(M1.getNonZeros() == M2.getNonZeros());
M1 -= M2; M1 -= M2;
auto err = M1.norm(); auto err = M1.norm();
// cout << "err:" << err << endl; #ifdef DEBUG
if(i == 0)
cout << "M1 norm:" << M1.norm() << endl;
M1.Display();
cout << "M2 norm:" << M2.norm() << endl;
M2.Display();
#endif
assert(err < 1e-6); assert(err < 1e-6);
M1 = *M; M1 = *M;
M2 = *M; M2 = *M;
...@@ -79,6 +111,7 @@ int main(int argc, char* argv[]) ...@@ -79,6 +111,7 @@ int main(int argc, char* argv[])
cout << "pure gpu prox time:" << pure_gpu_prox_dur.count() << endl; cout << "pure gpu prox time:" << pure_gpu_prox_dur.count() << endl;
cout << "gpu2cpu round-trip prox time:" << gpu_cpu_rt_prox_dur.count() << endl; cout << "gpu2cpu round-trip prox time:" << gpu_cpu_rt_prox_dur.count() << endl;
cout << "pure gpu speedup: " << gpu_cpu_rt_prox_dur.count()/pure_gpu_prox_dur.count() << endl;
return 0; return 0;
...@@ -17,13 +17,13 @@ int main(int argc, char* argv[]) ...@@ -17,13 +17,13 @@ int main(int argc, char* argv[])
Faust::enable_gpu_mod(); Faust::enable_gpu_mod();
faust_unsigned_int dim2 = 204; faust_unsigned_int dim2 = 8193;
auto num_its = 30000; auto num_its = 270;
int32_t k = dim1/10; int32_t k = 10;
int row_or_col = 0; // row by deft int row_or_col = 1; // col by deft
...@@ -46,6 +46,11 @@ int main(int argc, char* argv[]) ...@@ -46,6 +46,11 @@ int main(int argc, char* argv[])
std::cout << (row_or_col==1?"prox_spcol":"prox_splin") << " k: " << k << std::endl;
...@@ -61,17 +66,17 @@ int main(int argc, char* argv[]) ...@@ -61,17 +66,17 @@ int main(int argc, char* argv[])
if(row_or_col) if(row_or_col)
prox_spcol(M1, k, /* normalized */ false, /* pos*/ false, /* pure_gpu */ true); prox_spcol(M1, k, /* normalized */ true, /* pos*/ false, /* pure_gpu */ true);
else else
prox_splin(M1, k, /* normalized */ false, /* pos*/ false, /* pure_gpu */ true); prox_splin(M1, k, /* normalized */ true, /* pos*/ false, /* pure_gpu */ true);
prox_spcol(M2, k, /* normalized */ false, /* pos*/ false, /* pure_gpu */ false); prox_spcol(M2, k, /* normalized */ true, /* pos*/ false, /* pure_gpu */ false);
else else
prox_splin(M2, k, /* normalized */ false, /* pos*/ false, /* pure_gpu */ false); prox_splin(M2, k, /* normalized */ true, /* pos*/ false, /* pure_gpu */ false);
M1 -= M2; M1 -= M2;
...@@ -84,6 +89,7 @@ int main(int argc, char* argv[]) ...@@ -84,6 +89,7 @@ int main(int argc, char* argv[])
return 0; return 0;
