Commit aae84ecb authored by hhakim's avatar hhakim
Add matfaust wrapper to C++ Faust::butterfly_hierarchical (for experimental pkg).
parent 5033b632
...@@ -31,7 +31,7 @@ if(BUILD_DOCUMENTATION) ...@@ -31,7 +31,7 @@ if(BUILD_DOCUMENTATION)
string(CONCAT DOXYGEN_FILE_PATTERNS "*.cpp *.hpp *.h *.cu *.hu") string(CONCAT DOXYGEN_FILE_PATTERNS "*.cpp *.hpp *.h *.cu *.hu")
endif() endif()
if(BUILD_WRAPPER_MATLAB) if(BUILD_WRAPPER_MATLAB)
string(CONCAT DOXYGEN_FILE_PATTERNS ${DOXYGEN_FILE_PATTERNS} " Faust.m FaustMulMode.m StoppingCriterion.m ConstraintGeneric.m ConstraintMat.m ConstraintReal.m ConstraintInt.m ConstraintName.m ParamsFact.m ParamsHierarchical.m ParamsPalm4MSA.m FaustFactory.m hadamard.m quickstart.m fft.m bsl.m runtimecmp.m runall.m version.m faust_fact.m ParamsHierarchicalSquareMat.m ParamsHierarchicalRectMat.m license.m omp.m wht.m dft.m eye.m rand.m eigtj.m hierarchical.m fact.m palm4msa.m fgft_givens.m fgft_palm.m svdtj.m splin.m spcol.m proj_gen.m sp.m const.m supp.m hankel.m toeplitz.m circ.m normcol.m normlin.m splincol.m blockdiag.m skperm.m enable_gpu_mod.m isFaust.m poly.m basis.m next.m expm_multiply.m FaustPoly.m MHTPParams.m palm4msa_mhtp.m hierarchical_mhtp.m ") # warning: the space on the end matters string(CONCAT DOXYGEN_FILE_PATTERNS ${DOXYGEN_FILE_PATTERNS} " Faust.m FaustMulMode.m StoppingCriterion.m ConstraintGeneric.m ConstraintMat.m ConstraintReal.m ConstraintInt.m ConstraintName.m ParamsFact.m ParamsHierarchical.m ParamsPalm4MSA.m FaustFactory.m hadamard.m quickstart.m fft.m bsl.m runtimecmp.m runall.m version.m faust_fact.m ParamsHierarchicalSquareMat.m ParamsHierarchicalRectMat.m license.m omp.m wht.m dft.m eye.m rand.m eigtj.m hierarchical.m fact.m palm4msa.m fgft_givens.m fgft_palm.m svdtj.m splin.m spcol.m proj_gen.m sp.m const.m supp.m hankel.m toeplitz.m circ.m normcol.m normlin.m splincol.m blockdiag.m skperm.m enable_gpu_mod.m isFaust.m poly.m basis.m next.m expm_multiply.m FaustPoly.m MHTPParams.m palm4msa_mhtp.m hierarchical_mhtp.m butterfly.m ") # warning: the space on the end matters
endif() endif()
if(BUILD_WRAPPER_PYTHON) if(BUILD_WRAPPER_PYTHON)
string(CONCAT DOXYGEN_FILE_PATTERNS ${DOXYGEN_FILE_PATTERNS} "__init__.py factparams.py demo.py tools.py fact.py proj.py poly.py") string(CONCAT DOXYGEN_FILE_PATTERNS ${DOXYGEN_FILE_PATTERNS} "__init__.py factparams.py demo.py tools.py fact.py proj.py poly.py")
% experimental block start
%> @brief Factorizes the matrix M according to the butterfly support.
function F = butterfly(M)
import matfaust.Faust
if(isreal(M))
core_obj = mexButterflyReal(M);
else
core_obj = mexButterflyCplx(M);
F = Faust(core_obj, isreal(M));
% experimental block end
...@@ -121,6 +121,7 @@ foreach(SCALAR_AND_FSUFFIX double:Real std::complex<double>:Cplx) # TODO: float ...@@ -121,6 +121,7 @@ foreach(SCALAR_AND_FSUFFIX double:Real std::complex<double>:Cplx) # TODO: float
endif() endif()
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexPalm4MSA.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexPalm4MSA${FSUFFIX}.cpp @ONLY) configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexPalm4MSA.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexPalm4MSA${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical_fact.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical_fact${FSUFFIX}.cpp @ONLY) configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical_fact.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical_fact${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexButterfly.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexButterfly${FSUFFIX}.cpp @ONLY)
# Givens FGFT is only for double and float scalars # Givens FGFT is only for double and float scalars
if(NOT ${FAUST_SCALAR} MATCHES "complex") if(NOT ${FAUST_SCALAR} MATCHES "complex")
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexfgftgivens.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexfgftgivens${FSUFFIX}.cpp @ONLY) configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexfgftgivens.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexfgftgivens${FSUFFIX}.cpp @ONLY)
...@@ -142,6 +143,7 @@ foreach(SCALAR_AND_FSUFFIX double:Real std::complex<double>:Cplx) # TODO: float ...@@ -142,6 +143,7 @@ foreach(SCALAR_AND_FSUFFIX double:Real std::complex<double>:Cplx) # TODO: float
# copy the *.m for factorization now, because we have the FSUFFIX in hands # copy the *.m for factorization now, because we have the FSUFFIX in hands
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical_fact.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical_fact${FSUFFIX}.m COPYONLY) configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical_fact.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical_fact${FSUFFIX}.m COPYONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexPalm4MSA.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexPalm4MSA${FSUFFIX}.m COPYONLY) configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexPalm4MSA.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexPalm4MSA${FSUFFIX}.m COPYONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexButterfly.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexButterfly${FSUFFIX}.m @ONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexfgftgivens.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexfgftgivens${FSUFFIX}.m COPYONLY) configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexfgftgivens.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexfgftgivens${FSUFFIX}.m COPYONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexsvdtj.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexsvdtj${FSUFFIX}.m COPYONLY) configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexsvdtj.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexsvdtj${FSUFFIX}.m COPYONLY)
/* Description: */
/* For more information on the FAuST Project, please visit the website */
/* of the project : <http://faust.inria.fr> */
/* License: */
/* Copyright (2021): Hakim HADJ-DJILANI */
/* Nicolas Bellot, Adrien Leman, Thomas Gautrais, */
/* Luc Le Magoarou, Remi Gribonval */
/* INRIA Rennes, FRANCE */
/* http://www.inria.fr/ */
/* The FAuST Toolbox is distributed under the terms of the GNU Affero */
/* General Public License. */
/* This program is free software: you can redistribute it and/or modify */
/* it under the terms of the GNU Affero General Public License as */
/* published by the Free Software Foundation. */
/* This program is distributed in the hope that it will be useful, but */
/* WITHOUT ANY WARRANTY; without even the implied warranty of */
/* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. */
/* See the GNU Affero General Public License for more details. */
/* You should have received a copy of the GNU Affero General Public */
/* License along with this program. */
/* If not, see <http://www.gnu.org/licenses/>. */
/* Contacts: */
/* Nicolas Bellot : nicolas.bellot@inria.fr */
/* Adrien Leman : adrien.leman@inria.fr */
/* Thomas Gautrais : thomas.gautrais@inria.fr */
/* Luc Le Magoarou : luc.le-magoarou@inria.fr */
/* Remi Gribonval : remi.gribonval@inria.fr */
/* References: */
/* [1] Le Magoarou L. and Gribonval R., "Flexible multi-layer sparse */
/* approximations of matrices and applications", Journal of Selected */
/* Topics in Signal Processing, 2016. */
/* <https://hal.archives-ouvertes.fr/hal-01167948v1> */
#include "mex.h"
//#include "mexutils.h"
#include "faust_MatDense.h"
#include <vector>
#include <stdexcept>
#include "mx2Faust.h"
#include "faust2Mx.h"
#include "faust_TransformHelper.h"
#include "class_handle.hpp"
#include "faust_butterfly.h"
using namespace Faust;
typedef @FAUST_SCALAR@ SCALAR;
typedef @FACT_FPP@ FPP2;
void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
#ifdef FAUST_VERBOSE
if (typeid(SCALAR) == typeid(float))
std::cout<<"SCALAR == float"<<std::endl;
if (typeid(SCALAR) == typeid(double))
std::cout<<"SCALAR == double"<<std::endl;
system("sleep 7");
#endif
if (nrhs < 1)
mexErrMsgTxt("Bad Number of inputs arguments (must be 1)");
try
TransformHelper<SCALAR, Cpu>* F = nullptr;
Faust::MatDense<SCALAR,Cpu> matrix;
mxArray2FaustMat(prhs[0],matrix);
F = Faust::butterfly_hierarchical(matrix);
F->display();
plhs[0] = convertPtr2Mat<Faust::TransformHelper<SCALAR, Cpu>>(F);
catch (const std::exception& e)
plhs[0] = nullptr;
mexErrMsgTxt(e.what());
