Commit a846a996 authored by Nicolas Bellot's avatar Nicolas Bellot Committed by hhakim
license tool de la demo MATLAB
parent 2cff1ef8
Copyright (c) 1998, Regents of the University of California
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of the University of California, Berkeley nor the
names of its contributors may be used to endorse or promote products
derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND ANY
EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE REGENTS AND CONTRIBUTORS BE LIABLE FOR ANY
DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This diff is collapsed.
######## FAuST Toolbox ##########
######## Flexible Approximate Multi-Layer Sparse Transform ##########
This file lists the m files present in other library.
The following files come from the sparsify toolbox Version 0.4 and are under GNU GENERAL PUBLIC LICENSE 2.0 :
- greed_omp_chol.m
- UpdateCholesky.m
The following file comes from Matlab Central and are under BSD license :
- bplot.m
function [s, err_mse, iter_time]=hard_l0_Mterm(x,A,m,M,varargin)
% hard_l0_Mterm: Hard thresholding algorithm that keeps exactly M elements
% in each iteration.
% This algorithm has certain performance guarantees as described in [1],
% [2] and [3].
% Usage
% [s, err_mse, iter_time]=hard_l0_Mterm(x,P,m,M,'option_name','option_value')
% Input
% Mandatory:
% x Observation vector to be decomposed
% P Either:
% 1) An nxm matrix (n must be dimension of x)
% 2) A function handle (type "help function_format"
% for more information)
% Also requires specification of P_trans option.
% 3) An object handle (type "help object_format" for
% more information)
% m length of s
% M non-zero elements to keep in each iteration
% Possible additional options:
% (specify as many as you want using 'option_name','option_value' pairs)
% See below for explanation of options:
%__________________________________________________________________________
% option_name | available option_values | default
% stopTol | number (see below) | 1e-16
% P_trans | function_handle (see below) |
% maxIter | positive integer (see below) | n^2
% verbose | true, false | false
% start_val | vector of length m | zeros
% step_size | number | 0 (auto)
% stopping criteria used : (OldRMS-NewRMS)/RMS(x) < stopTol
% stopTol: Value for stopping criterion.
% P_trans: If P is a function handle, then P_trans has to be specified and
% must be a function handle.
% maxIter: Maximum number of allowed iterations.
% verbose: Logical value to allow algorithm progress to be displayed.
% start_val: Allows algorithms to start from partial solution.
% Outputs
% s Solution vector
% err_mse Vector containing mse of approximation error for each
% iteration
% iter_time Vector containing computation times for each iteration
% Description
% Implements the M-sparse algorithm described in [1], [2] and [3].
% This algorithm takes a gradient step and then thresholds to only retain
% M non-zero elements. It allows the step-size to be calculated
% automatically as described in [3] and is therefore now independent from
% a rescaling of P.
% References
% [1] T. Blumensath and M.E. Davies, "Iterative Thresholding for Sparse
% Approximations", submitted, 2007
% [2] T. Blumensath and M. Davies; "Iterative Hard Thresholding for
% Compressed Sensing" to appear Applied and Computational Harmonic
% Analysis
% [3] T. Blumensath and M. Davies; "A modified Iterative Hard
% Thresholding algorithm with guaranteed performance and stability"
% in preparation (title may change)
% See Also
% hard_l0_reg
% Copyright (c) 2007 Thomas Blumensath
% The University of Edinburgh
% Email: thomas.blumensath@ed.ac.uk
% Comments and bug reports welcome
% This file is part of sparsity Version 0.4
% Created: April 2007
% Modified January 2009
% Part of this toolbox was developed with the support of EPSRC Grant
% D000246/1
% Please read COPYRIGHT.m for terms and conditions.
% Default values and initialisation
[n1 n2]=size(x);
if n2 == 1
n=n1;
elseif n1 == 1
x=x';
n=n2;
else
error('x must be a vector.');
sigsize = x'*x/n;
oldERR = sigsize;
err_mse = [];
iter_time = [];
STOPTOL = 1e-16;
MAXITER = n^2;
verbose = false;
initial_given=0;
s_initial = zeros(m,1);
MU = 0;
if verbose
display('Initialising...')
% Output variables
switch nargout
case 3
comp_err=true;
comp_time=true;
case 2
comp_err=true;
comp_time=false;
case 1
comp_err=false;
comp_time=false;
case 0
error('Please assign output variable.')
otherwise
error('Too many output arguments specified')
% Look through options
% Put option into nice format
Options={};
OS=nargin-4;
c=1;
for i=1:OS
if isa(varargin{i},'cell')
CellSize=length(varargin{i});
ThisCell=varargin{i};
for j=1:CellSize
Options{c}=ThisCell{j};
c=c+1;
else
Options{c}=varargin{i};
c=c+1;
OS=length(Options);
if rem(OS,2)
error('Something is wrong with argument name and argument value pairs.')
for i=1:2:OS
switch Options{i}
case {'stopTol'}
if isa(Options{i+1},'numeric') ; STOPTOL = Options{i+1};
else error('stopTol must be number. Exiting.'); end
case {'P_trans'}
if isa(Options{i+1},'function_handle'); Pt = Options{i+1};
else error('P_trans must be function _handle. Exiting.'); end
case {'maxIter'}
if isa(Options{i+1},'numeric'); MAXITER = Options{i+1};
else error('maxIter must be a number. Exiting.'); end
case {'verbose'}
if isa(Options{i+1},'logical'); verbose = Options{i+1};
else error('verbose must be a logical. Exiting.'); end
case {'start_val'}
if isa(Options{i+1},'numeric') && length(Options{i+1}) == m ;
s_initial = Options{i+1};
initial_given=1;
else error('start_val must be a vector of length m. Exiting.'); end
case {'step_size'}
if isa(Options{i+1},'numeric') && (Options{i+1}) > 0 ;
MU = Options{i+1};
else error('Stepsize must be between a positive number. Exiting.'); end
otherwise
error('Unrecognised option. Exiting.')
if nargout >=2
err_mse = zeros(MAXITER,1);
if nargout ==3
iter_time = zeros(MAXITER,1);
% Make P and Pt functions
if isa(A,'float') P =@(z) A*z; Pt =@(z) A'*z;
elseif isobject(A) P =@(z) A*z; Pt =@(z) A'*z;
elseif isa(A,'function_handle')
try
if isa(Pt,'function_handle'); P=A;
else error('If P is a function handle, Pt also needs to be a function handle. Exiting.'); end
catch error('If P is a function handle, Pt needs to be specified. Exiting.'); end
else error('P is of unsupported type. Use matrix, function_handle or object. Exiting.'); end
% Do we start from zero or not?
if initial_given ==1;
if length(find(s_initial)) > M
display('Initial vector has more than M non-zero elements. Keeping only M largest.')
s = s_initial;
[ssort sortind] = sort(abs(s),'descend');
s(sortind(M+1:end)) = 0;
Ps = P(s);
Residual = x-Ps;
oldERR = Residual'*Residual/n;
else
Residual = x;
s = s_initial;
Ps = zeros(n,1);
oldERR = sigsize;
% Random Check to see if dictionary norm is below 1
x_test=randn(m,1);
x_test=x_test/norm(x_test);
nP=norm(P(x_test));
if abs(MU*nP)>1;
display('WARNING! Algorithm likely to become unstable.')
display('Use smaller step-size or || P ||_2 < 1.')
% Main algorithm
if verbose
display('Main iterations...')
tic
t=0;
done = 0;
iter=1;
while ~done
if MU == 0
%Calculate optimal step size and do line search
olds = s;
oldPs = Ps;
IND = s~=0;
d = Pt(Residual);
% If the current vector is zero, we take the largest elements in d
if sum(IND)==0
[dsort sortdind] = sort(abs(d),'descend');
IND(sortdind(1:M)) = 1;
id = (IND.*d);
Pd = P(id);
mu = id'*id/(Pd'*Pd);
s = olds + mu * d;
Ps = P(s);
% Calculate step-size requirement
omega = (norm(s-olds)/norm(Ps-oldPs))^2;
% As long as the support changes and mu > omega, we decrease mu
while mu > (0.99)*omega && sum(xor(IND,s~=0))~=0 && sum(IND)~=0
% display(['decreasing mu'])
% We use a simple line search, halving mu in each step
mu = mu/2;
s = olds + mu * d;
Ps = P(s);
else
% Use fixed step size
s = s + MU * Pt(Residual);
Ps = P(s);
Residual = x-Ps;
ERR=Residual'*Residual/n;
if comp_err
err_mse(iter)=ERR;
if comp_time
iter_time(iter)=toc;
% Are we done yet?
if comp_err && iter >=2
if ((err_mse(iter-1)-err_mse(iter))/sigsize<STOPTOL);
if verbose
display(['Stopping. Approximation error changed less than ' num2str(STOPTOL)])
done = 1;
elseif verbose && toc-t>10
display(sprintf('Iteration %i. --- %i mse change',iter ,(err_mse(iter-1)-err_mse(iter))/sigsize))
t=toc;
else
if ((oldERR - ERR)/sigsize < STOPTOL) && iter >=2;
if verbose
done = 1;
display(sprintf('Iteration %i. --- %i mse change',iter ,(oldERR - ERR)/sigsize))
t=toc;
% Also stop if residual gets too small or maxIter reached
if comp_err
if err_mse(iter)<1e-16
display('Stopping. Exact signal representation found!')
done=1;
elseif iter>1
if ERR<1e-16
done=1;
if iter >= MAXITER
display('Stopping. Maximum number of iterations reached!')
done = 1;
% If not done, take another round
if ~done
iter=iter+1;
oldERR=ERR;
% Only return as many elements as iterations
if nargout >=2
err_mse = err_mse(1:iter);
if nargout ==3
iter_time = iter_time(1:iter);
if verbose
display('Done')
