Commit a74ae436 authored by hhakim's avatar hhakim
Bind into matfaust the prox operators from cpp core.
The matlab function ConstraintGeneric.project() is the way to call a prox (through instance of sub-class ConstraintInt, ConstraintMat, ConstraintReal).
It's the same architecture in the core cpp (project() member function).
parent 903047b2
......@@ -26,5 +26,13 @@ classdef ConstraintGeneric
% child classes verify the param type
constraint.param = param;
function pM = project(this, M)
if(isreal(M))
pM = mexFaustReal('prox', M, this.name.name, this.param);
else
mexFaustCplx('prox', M, this.name.name, this.param);
......@@ -144,7 +144,7 @@ void save(Faust::TransformHelper<SCALAR,Cpu>* core_ptr, int nargs, const mxArray
return;
//TODO: hadamard, fourier, and proxs must be in there own mex function (one for hadamard and fourier, another for the prox)
if(!strcmp("hadamard", cmd)){
if(nlhs!=1)
mexErrMsgTxt("hadamard(): 1 variable result is expected.");
......@@ -186,6 +186,80 @@ void save(Faust::TransformHelper<SCALAR,Cpu>* core_ptr, int nargs, const mxArray
return;
if(!strcmp("prox", cmd))
if(nlhs!=1)
mexErrMsgTxt("prox(): 1 output variable is expected.");
if(nrhs < 4)
mexErrMsgTxt("prox(): wrong number of arguments (must be 4)");
unsigned int constraint_type = (unsigned int) mxGetScalar(prhs[2]);
bool const is_param_scalar = (1u == mxGetNumberOfElements(prhs[3]));
double scal_param;
const mxArray* mxMat_in = prhs[1];
const size_t nrows_mat = mxGetM(mxMat_in);
const size_t ncols_mat = mxGetN(mxMat_in);
SCALAR* mat_data = NULL;
mxArray2Ptr(mxMat_in, mat_data);
Faust::MatDense<SCALAR, Cpu> mat(mat_data, nrows_mat, ncols_mat);
Faust::MatDense<SCALAR, Cpu>* mat_param = nullptr;
if(is_param_scalar)
scal_param = mxGetScalar(prhs[3]);
else
mxArray2Ptr(prhs[3], mat_data);
// constraint matrix has normally same dim as constrainted matrix (TODO: must be checked from matlab code)
mat_param = new Faust::MatDense<SCALAR, Cpu>(mat_data, nrows_mat, ncols_mat);
cout << "mex prox, scal_param: " << scal_param << " constraint id: " << constraint_type << endl;
switch(constraint_type)
case CONSTRAINT_NAME_SP: /*!< fixed number of non zero elements, INT (frobenius norm 1) */
Faust::prox_sp(mat, (faust_unsigned_int) scal_param);
break;
case CONSTRAINT_NAME_SPCOL: /*!< fixed number of non zero elements per column INT (frobenius norm 1) */
Faust::prox_spcol(mat, (faust_unsigned_int) scal_param);
break;
case CONSTRAINT_NAME_SPLIN: /*!< fixed number of non zero elements per line INT (frobenius norm 1) */
Faust::prox_splin(mat, (faust_unsigned_int) scal_param);
break;
case CONSTRAINT_NAME_SPLINCOL:
Faust::prox_splincol(mat, (faust_unsigned_int) scal_param);
break;
case CONSTRAINT_NAME_SP_POS:/**< fixed number of non zeros coefficients: INT (frobenius norm 1) */
Faust::prox_sp_pos(mat, (faust_unsigned_int) scal_param);
break;
case CONSTRAINT_NAME_NORMLIN:/**< 2nd norm of the lines of matrix A ; REAL */
Faust::prox_normlin(mat, scal_param);
break;
case CONSTRAINT_NAME_NORMCOL:/*!< 2nd norm of the colons of A REAL */
Faust::prox_normcol(mat, scal_param);
break;
case CONSTRAINT_NAME_CONST: /**< Matrix equal to A ; MAT */
// nothing to do, same mat returned
break ;
case CONSTRAINT_NAME_BLKDIAG:
//not impl. yet in cpp core
break;
case CONSTRAINT_NAME_SUPP: /**< Matrix which support is equal to A ; MAT ; (frobenius norm 1)*/
Faust::prox_supp(mat, *mat_param);
break;
plhs[0] = FaustMat2mxArray(mat);
if(mat_param != nullptr)
delete mat_param;
return;
// New
if (!strcmp("new", cmd))
......@@ -502,7 +576,7 @@ void save(Faust::TransformHelper<SCALAR,Cpu>* core_ptr, int nargs, const mxArray
SCALAR* ptr_data = NULL;
if ((core_ptr->isReal() ) && ( mxIsComplex(inMatlabMatrix) ) )
mexErrMsgTxt("impossibility to multiply real scalar Faust with complex matrix");
mexErrMsgTxt("impossibility to multiply a real Faust with complex matrix");
mxArray2Ptr(inMatlabMatrix, ptr_data);
