Commit a6bd57e1 authored by hhakim's avatar hhakim
Implement generator mechanism for Faust::TransformHelperPoly and add it in the pyfaust wrapper.
- Set to private Faust::TransformHelperPoly attributes.
- Use RefManager to share between TransformHelperPoly instances generated from the same parent instance the L, rR and other common attributes without copying.
parent 48adedd9
Loading
