Commit a4c6e3b1 authored by hhakim's avatar hhakim
Fix a memory bug of Faust created from different mex shared lib than the main...
Fix a memory bug of Faust created from different mex shared lib than the main ones (mexFaustReal/Cplx/Float).
The bug occurred for butterfly and hierarchical but other wrappers might be touched.
Bug example:
matlab -nojvm -nodisplay -Dgdb -r 'setup_FAUST;import matfaust.Faust; import matfaust.fact.butterfly; import matfaust.wht; H = full(wht(32)); F = butterfly(H); F-H'
parent 566c0182
......@@ -63,6 +63,21 @@ classdef FaustCore < handle
this.isRealFlag = varargin{2};
this.dev = varargin{3};
this.dtype = varargin{4};
onGPU = startsWith(this.dev, 'gpu');
% TODO: the copy of factors shouldn't be necessary
% it's here to fix a bug when for instance calling
% matfaust.fact.hierarchical/butterfly, the returned Faust is
% ok but F-M (for example) leads to a crash
% (it's probably because of matrix reference manager that is
% duplicated in static memory of different shared
% libraries/mexs -- still to verify. All Faust object must be
% managed by mexFaustReal/Cplx/Float, hence the copy)
nf = call_mex(this, 'numfactors');
facts = cell(1, nf);
for i=1:nf
facts{i} = call_mex(this, 'factors', i);
this = FaustCore(facts, 1.0, false, this.isRealFlag, this.dev, this.dtype);
elseif(nargin >= 1)
factors = varargin{1};
scale = varargin{2};
......@@ -144,6 +159,32 @@ classdef FaustCore < handle
function varargout = call_mex(this, func_name, varargin)
if (strcmp(this.dev, 'cpu'))
if(this.isRealFlag)
if(strcmp(this.dtype, 'double'))
[varargout{1:nargout}] = mexFaustReal(func_name, this.objectHandle, varargin{:});
else % float
[varargout{1:nargout}] = mexFaustRealFloat(func_name, this.objectHandle, varargin{:});
else
[varargout{1:nargout}] = mexFaustCplx(func_name, this.objectHandle, varargin{:});
elseif(startsWith(this.dev, 'gpu'))
if(this.isRealFlag)
[varargout{1:nargout}] = mexFaustGPUReal(func_name, this.objectHandle, varargin{:});
else % float
[varargout{1:nargout}] = mexFaustGPURealFloat(func_name, this.objectHandle, varargin{:});
else
[varargout{1:nargout}] = mexFaustGPUCplx(func_name, this.objectHandle, varargin{:});
else
error('The Faust F has an invalid dev attribute (must be cpu or gpu)')
