Commit a45fb322 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
modif latex
parent dd756137
...@@ -39,7 +39,7 @@ The Figure \ref{fig:faustStructure} presents a brief structure of the FA$\mu$ST ...@@ -39,7 +39,7 @@ The Figure \ref{fig:faustStructure} presents a brief structure of the FA$\mu$ST
\label{fig:faustStructure} \label{fig:faustStructure}
\end{figure} \end{figure}
\paragraph{Known problem:} \paragraph{Known issues}
\begin{enumerate} \begin{enumerate}
\item The installation on Windows Platform using Visual Studio IDE has been tested but there is compilation problems depending on the version of your Windows and your Visual Studio. \textbf{This install configuration is not guaranteed} but you can try and report any problem and/or suggestion on install-list of FA$\mu$ST project on \url{http://lists.gforge.inria.fr/pipermail/faust-install/}. \item The installation on Windows Platform using Visual Studio IDE has been tested but there is compilation problems depending on the version of your Windows and your Visual Studio. \textbf{This install configuration is not guaranteed} but you can try and report any problem and/or suggestion on install-list of FA$\mu$ST project on \url{http://lists.gforge.inria.fr/pipermail/faust-install/}.
\item The "Factorization algorithms" module represented on Figure \ref{fig:faustStructure} is actually in progress (see Section). \item The "Factorization algorithms" module represented on Figure \ref{fig:faustStructure} is actually in progress (see Section).
...@@ -41,7 +41,7 @@ ...@@ -41,7 +41,7 @@
urlcolor=blue urlcolor=blue
\usepackage{tikz} %\usepackage{tikz}
%\usepackage{appendix} %\usepackage{appendix}
\usepackage{mathtools} \usepackage{mathtools}
