GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
a095b9ad
a095b9ad
1 year ago
hhakim
Downloads
Patches
Handle erroneous matrix size in Python butterfly() before C++'s (#331).
2b14d0d7
Branches containing commit
Tags containing commit
wrapper/python/pyfaust/fact.py
+6
-1
6 additions, 1 deletion
6 additions
1 deletion
6
a095b9ad
@@ -82,7 +82,7 @@ def svdtj2(M, nGivens, tol=0, relerr=True, nGivens_per_fac=None, verbosity=0,
:py:func:`.eigtj`
:py:func:`.eigtj`
from
scipy.sparse
import
spdiags
from
scipy.sparse
import
spdiags
from
sci
py
import
diag
from
num
py
import
diag
from
pyfaust
import
Faust
from
pyfaust
import
Faust
from
numpy
import
argsort
sign
eye
sort
from
numpy
import
argsort
sign
eye
sort
if
verbosity
if
verbosity
@@ -1801,6 +1801,11 @@ def butterfly(M, type="bbtree", perm=None, diag_opt=False, mul_perm=None):
return
P
T
nonzero
return
P
T
nonzero
is_real
np
empty
is_real
np
empty
_check_fact_mat
butterfly()
is_real
_check_fact_mat
butterfly()
is_real
m
n
shape
l2_m
l2_n
np
log2
m
n
if
l2_m
np
floor
l2_m
l2_n
np
floor
l2_n
m
n
raise
ValueError
M must be square and its dimensions must be a power
of two.
if
isinstance
perm
str
if
isinstance
perm
str
if
perm
bitrev
if
perm
bitrev
P
bitrev_perm
shape
P
bitrev_perm
shape
This diff is collapsed.
Loading
Save comment
