Commit 9ef1e5a2 authored by hhakim's avatar hhakim
Add pyfaust.FaustFactory.fact_hierarchical_constends(), partially documented...
Add pyfaust.FaustFactory.fact_hierarchical_constends(), partially documented and with a test example.
parent f72509d5
...@@ -1743,6 +1743,88 @@ class FaustFactory: ...@@ -1743,6 +1743,88 @@ class FaustFactory:
"with the first factor constraint defined in p.") "with the first factor constraint defined in p.")
return p return p
@staticmethod
def fact_hierarchical_constends(M, p, A, B, ret_lambda=False, ret_params=False):
Tries to approximate M by \f$ A \prod_j S_j B \f$ using the FaustFactory.fact_hierarchical.
It needs to add one additional residuum constraint and also one factor
constraint into p relatively to the number of constraints you would
have defined if you just factorized M into prod \f$ \prod_j S_j \f$.
Examples:
from pyfaust import FaustFactory as FF
from numpy.random import rand
from pyfaust.factparams import (ParamsHierarchicalFact, ConstraintList,
StoppingCriterion)
import sys
M = rand(32,32)
A = rand(32,32)
B = rand(32,32)
stop_crit1 = StoppingCriterion(num_its=200)
stop_crit2 = StoppingCriterion(num_its=200)
fact_cons = ConstraintList('splin', 5, 32, 32, 'sp', 96, 32, 32, 'sp', 96,
32, 32,
'sp', 225, 32, 32)
res_cons = ConstraintList('normcol', 1, 32, 32,
'normcol', 1, 32, 32, 'sp', 666, 32, 32, 'sp',
333, 32, 32)
param = ParamsHierarchicalFact(fact_cons, res_cons, stop_crit1, stop_crit2)
F, _lambda = FF.fact_hierarchical_constends(M, param, A, B, ret_lambda=True)
assert(np.allclose(F.get_factor(0).toarray(), A))
assert(np.allclose(F.get_factor(5).toarray(), B))
from pyfaust.factparams import ConstraintList
from pyfaust.factparams import ParamsHierarchicalFact
A = np.asfortranarray(A)
B = np.asfortranarray(B)
consA = ConstraintList('const', A, *A.shape)
consB = ConstraintList('const', B, *B.shape)
consts = p.constraints
nconsts = len(consts)
# consts : factor constraints + residuum constraints
fac_cons = [ consts[i] for i in range(0, p.num_facts-1) ]
res_cons = [ consts[i] for i in range(p.num_facts-1, len(consts))]
assert(nconsts == len(fac_cons) + len(res_cons))
# add two CONST(ants) factor constraint: A and B to the constraints
# depending of the factorization direction we need to switch A and B
# constraint positions
if(p.is_fact_side_left):
new_fact_cons = consB + ConstraintList(*fac_cons)
new_res_cons = ConstraintList(*res_cons) + consA
else:
new_fact_cons = consA + ConstraintList(*fac_cons)
new_res_cons = ConstraintList(*res_cons) + consB
assert(nconsts == len(new_fact_cons) + len(new_res_cons) - 2)
p = ParamsHierarchicalFact(new_fact_cons, new_res_cons, *p.stop_crits,
p.is_update_way_R2L, p.init_lambda,
p.step_size, p.constant_step_size,
p.is_fact_side_left,
p.is_verbose)
F, _lambda = FaustFactory.fact_hierarchical(M, p, ret_lambda=True,
ret_params=False)
FA_lambda = F.get_factor(0)
FA = FA_lambda/_lambda
new_F_factors = [ FA ]
F_without_A = F.get_factor(range(1,F.get_num_factors()))
F_without_A = F_without_A * _lambda
new_F_factors += [ F_without_A.get_factor(i) for i in
range(0,F_without_A.get_num_factors()) ]
new_F = Faust(new_F_factors)
F = new_F
ret_list = [F]
if(ret_lambda):
ret_list += [ _lambda ]
if(ret_params):
ret_list += [ p ]
if(ret_lambda or ret_params):
return ret_list
else:
return F
@staticmethod @staticmethod
def wht(n): def wht(n):
