Commit 9cf8cbf7 authored by hhakim's avatar hhakim
Add pyfaust.poly.expm_multiply and its doc.
parent 4df87674
...@@ -11,6 +11,10 @@ from scipy.sparse import csr_matrix ...@@ -11,6 +11,10 @@ from scipy.sparse import csr_matrix
from pyfaust import (Faust, isFaust, eye as feye, vstack as fvstack, hstack as from pyfaust import (Faust, isFaust, eye as feye, vstack as fvstack, hstack as
fhstack) fhstack)
from scipy.sparse.linalg import eigsh from scipy.sparse.linalg import eigsh
from scipy.special import ive
from scipy.sparse import eye as seye
from numpy import empty, squeeze
import threading import threading
...@@ -442,4 +446,87 @@ class FaustPoly(Faust): ...@@ -442,4 +446,87 @@ class FaustPoly(Faust):
def __next__(self): def __next__(self):
return next(self.gen) return next(self.gen)
def expm_multiply(A, B, start=None, stop=None, num=None, endpoint=None,
K=10, dev='cpu'):
Computes an approximate of the action of the matrix exponential of A on B using series of Chebyshev polynomials.
NOTE: This function is very similar to scipy.sparse.linalg.expm_multiply
with two major differences though:
1. A must be symmetric positive definite.
2. The time values must be negative.
Args:
A: the operator whose exponential is of interest (must be a
symmetric positive definite csr_matrix).
B: the matrix or vector to be multiplied by the matrix exponential of A (ndarray).
start: (scalar, optional) the starting time point of the sequence.
stop: (scalar, optional) the end time point of the sequence, unless endpoint is set to False. In that case, the sequence consists of all but the last of num + 1 evenly spaced time points, so that stop is excluded. Note that the step size changes when endpoint is False.
num: (int, optional) number of time points to use.
endpoint: (bool, optional) if True, stop is the last time point. Otherwise, it is not included.
K: (int, optional) The degree of the dominant Chebyshev polynomial (10 by default).
dev: (str, optional) the device ('cpu' or 'gpu') on which to compute (currently only cpu is supported).
Returns:
expm_A_B the result of \f$e^{t_k A} B\f$.
Example:
>>> import numpy as np
>>> from scipy.sparse import random
>>> from pyfaust.poly import expm_multiply as fexpm_multiply
>>> L = random(5, 5, .2, format='csr')
>>> L = L@L.T
>>> x = np.random.rand(L.shape[1])
>>> y = fexpm_multiply(L, x, start=-.5, stop=-0.1, num=3, endpoint=True)
>>> y
array([[0.56445788, 0.22238514, 0.34696112, 0.40463245, 0.56358572],
[0.63657575, 0.22661967, 0.40625063, 0.45271241,
0.57045306],
[0.71895162, 0.23093484, 0.47397342, 0.50650541,
0.57740409]])
if not isinstance(A, csr_matrix):
raise TypeError('A must be a csr_matrix')
# check A is PSD or at least square
if A.shape[0] != A.shape[1]:
raise ValueError('A must be symmetric positive definite.')
phi = eigsh(A, k=1, return_eigenvectors=False)[0] / 2
T = basis(A/phi-seye(*A.shape), K, 'chebyshev', dev=dev)
TB = np.squeeze(T@B)
if isinstance(start, type(None)):
start = 1
if isinstance(stop, type(None)):
stop = start
num = 1
#tau = start
points = np.linspace(start, stop, num=num, endpoint=endpoint)
m = B.shape[0]
if len(B.shape) == 1:
n = 1
else:
n = B.shape[1]
npts = len(points)
Y = empty((npts, m, n))
for i,tau in enumerate(points):
if tau >= 0:
raise ValueError('pyfaust.poly.expm_multiply handles only positive '
'time points.')
# Compute the K+1 Chebychev coefficients
coeff = np.empty((K+1,), dtype=np.float)
coeff[-1] = 2 * ive(K, tau * phi)
coeff[-2] = 2 * ive(K-1, tau * phi)
for j in range(K - 2, -1, -1):
coeff[j] = coeff[j+2] - (2 * j + 2) / (-tau * phi) * coeff[j+1]
coeff[0] /= 2
if n == 1:
Y[i,:,0] = poly(coeff, TB, A, dev=dev)
else:
Y[i,:,:] = poly(coeff, TB, A, dev=dev)
if B.ndim == 1:
return np.squeeze(Y)
else:
return Y
# experimental block end # experimental block end
