Commit 98538c51 authored by Nicolas Bellot's avatar Nicolas Bellot Committed by hhakim
wrapper matlab resolution bug demo speed_up_hadamard
parent bff69e68
...@@ -102,10 +102,11 @@ classdef Faust ...@@ -102,10 +102,11 @@ classdef Faust
% delete(F) % delete(F)
% See also Faust % See also Faust
if (F.isReal) if (this.isRealFlag)
%mexFaustReal('delete', F.matrix.objectHandle); mexFaustReal('delete', F.matrix.objectHandle);
delete(F.matrix); else
end mexFaustCplx('delete', F.matrix.objectHandle);
end end
...@@ -86,6 +86,7 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -86,6 +86,7 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
// New // New
if (!strcmp("new", cmd)) if (!strcmp("new", cmd))
if(nlhs!=1) if(nlhs!=1)
mexErrMsgTxt("1 output is expected."); mexErrMsgTxt("1 output is expected.");
if((nrhs<2) || (nrhs>4)) if((nrhs<2) || (nrhs>4))
...@@ -99,14 +100,19 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -99,14 +100,19 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
//old version : std::vector<Faust::MatSparse<SCALAR,Cpu> > vec_spmat; //old version : std::vector<Faust::MatSparse<SCALAR,Cpu> > vec_spmat;
std::vector<Faust::MatGeneric<SCALAR,Cpu>*> list_factor; std::vector<Faust::MatGeneric<SCALAR,Cpu>*> list_factor;
mwSize nb_element = mxGetNumberOfElements(prhs[1]); mwSize nb_element = mxGetNumberOfElements(prhs[1]);
// A MODIFIER CREER UNE FUITE //
//double* ptr_bidon = new double[100];
if (nb_element != 0) if (nb_element != 0)
mxArray * mxMat; mxArray * mxMat;
for (int i=0; i < nb_element; i++) for (int i=0; i < nb_element; i++)
mxMat=mxGetCell(prhs[1],i); mxMat=mxGetCell(prhs[1],i);
concatMatGeneric<SCALAR>(mxMat,list_factor); concatMatGeneric<SCALAR>(mxMat,list_factor);
...@@ -134,7 +140,7 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -134,7 +140,7 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
delete list_factor[i]; delete list_factor[i];
plhs[0]=convertPtr2Mat<Faust::Transform<SCALAR,Cpu> >(F); plhs[0]=convertPtr2Mat<Faust::Transform<SCALAR,Cpu> >(F);
return; return;
...@@ -280,16 +286,6 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -280,16 +286,6 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
const size_t SIZE_B2 = nbColOp; const size_t SIZE_B2 = nbColOp;
Faust::MatDense<SCALAR,Cpu> prod=core_ptr->get_product(op); Faust::MatDense<SCALAR,Cpu> prod=core_ptr->get_product(op);
const mwSize dims[2]={SIZE_B1,SIZE_B2}; const mwSize dims[2]={SIZE_B1,SIZE_B2};
/*if(sizeof(SCALAR)==sizeof(float))
plhs[0] = mxCreateNumericArray(2, dims, mxSINGLE_CLASS, mxREAL);
else if(sizeof(SCALAR)==sizeof(double))
plhs[0] = mxCreateNumericArray(2, dims, mxDOUBLE_CLASS, mxREAL);
else
mexErrMsgTxt("SCALAR type is neither double nor float");
SCALAR* ptr_out = static_cast<SCALAR*> (mxGetData(plhs[0]));
memcpy(ptr_out, prod.getData(), SIZE_B1*SIZE_B2*sizeof(SCALAR));
plhs[0] = FaustMat2mxArray(prod); plhs[0] = FaustMat2mxArray(prod);
...@@ -348,6 +344,7 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -348,6 +344,7 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
if (!strcmp("multiply", cmd)) { if (!strcmp("multiply", cmd)) {
if (nlhs > 1 || nrhs != 4) if (nlhs > 1 || nrhs != 4)
mexErrMsgTxt("Multiply: Unexpected arguments."); mexErrMsgTxt("Multiply: Unexpected arguments.");
...@@ -387,113 +384,22 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -387,113 +384,22 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
mexErrMsgTxt("Multiply : Wrong number of dimensions for the input vector or matrix (third argument)."); mexErrMsgTxt("Multiply : Wrong number of dimensions for the input vector or matrix (third argument).");
//check scalar type match (real/complex)
/*if ( !isScalarCompatible((*core_ptr),inMatlabMatrix) )
mexErrMsgTxt("Multiply : Wrong scalar compatibility (real/complex)");*/
SCALAR* ptr_data = NULL;
const mxClassID V_CLASS_ID = mxGetClassID(inMatlabMatrix);
const size_t NB_ELEMENTS = mxGetNumberOfElements(inMatlabMatrix);
if(V_CLASS_ID == mxDOUBLE_CLASS)
double* ptr_data_tmp = static_cast<double*> (mxGetData(inMatlabMatrix));
ptr_data = new SCALAR[NB_ELEMENTS];
for (size_t i =0 ; i<NB_ELEMENTS ; i++)
ptr_data[i] = static_cast<SCALAR> (ptr_data_tmp[i]);
else if(V_CLASS_ID == mxSINGLE_CLASS)
float* ptr_data_tmp = static_cast<float*> (mxGetData(inMatlabMatrix));
else if(V_CLASS_ID == mxINT8_CLASS)
char* ptr_data_tmp = static_cast<char*> (mxGetData(inMatlabMatrix));
else if(V_CLASS_ID == mxUINT8_CLASS)
unsigned char* ptr_data_tmp = static_cast<unsigned char*> (mxGetData(inMatlabMatrix));
else if(V_CLASS_ID == mxINT16_CLASS)
short* ptr_data_tmp = static_cast<short*> (mxGetData(inMatlabMatrix));
else if (V_CLASS_ID == mxUINT16_CLASS)
unsigned short* ptr_data_tmp = static_cast<unsigned short*> (mxGetData(inMatlabMatrix));
else if (V_CLASS_ID == mxINT32_CLASS)
int* ptr_data_tmp = static_cast<int*> (mxGetData(inMatlabMatrix));
else if (V_CLASS_ID == mxUINT32_CLASS)
unsigned int* ptr_data_tmp = static_cast<unsigned int*> (mxGetData(inMatlabMatrix));
else if (V_CLASS_ID == mxINT64_CLASS)
long long* ptr_data_tmp = static_cast<long long*> (mxGetData(inMatlabMatrix));
else if (V_CLASS_ID == mxUINT64_CLASS)
unsigned long long* ptr_data_tmp = static_cast<unsigned long long*> (mxGetData(inMatlabMatrix));
else
mexErrMsgTxt("Unknown matlab type.");
SCALAR* ptr_data = NULL; SCALAR* ptr_data = NULL;
if ((core_ptr->isReal() ) && ( mxIsComplex(inMatlabMatrix) ) ) if ((core_ptr->isReal() ) && ( mxIsComplex(inMatlabMatrix) ) )
mexErrMsgTxt("impossibility to multiply real scalar Faust with complex matrix"); mexErrMsgTxt("impossibility to multiply real scalar Faust with complex matrix");
mxArray2Ptr(inMatlabMatrix, ptr_data); mxArray2Ptr(inMatlabMatrix, ptr_data);
// Si inMatlabMatrix est un vecteur // Si inMatlabMatrix est un vecteur
if(nbColA == 1) if(nbColA == 1)
Faust::Vect<SCALAR,Cpu> A(nbRowA, ptr_data); Faust::Vect<SCALAR,Cpu> A(nbRowA, ptr_data);
Faust::Vect<SCALAR,Cpu> B(nbRowB); Faust::Vect<SCALAR,Cpu> B(nbRowB);
//NB
//B = (*core_ptr)*A;
B = (*core_ptr).multiply(A,op); B = (*core_ptr).multiply(A,op);
/*const mwSize dims[2]={nbRowB,nbColB};
else
memcpy(ptr_out, B.getData(), nbRowB*nbColB*sizeof(SCALAR));*/
plhs[0]=FaustVec2mxArray(B); plhs[0]=FaustVec2mxArray(B);
// Si inMatlabMatrix est une matrice // Si inMatlabMatrix est une matrice
...@@ -502,22 +408,16 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[]) ...@@ -502,22 +408,16 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
Faust::MatDense<SCALAR,Cpu> A(ptr_data, nbRowA, nbColA); Faust::MatDense<SCALAR,Cpu> A(ptr_data, nbRowA, nbColA);
Faust::MatDense<SCALAR,Cpu> B(nbRowB, nbColA); Faust::MatDense<SCALAR,Cpu> B(nbRowB, nbColA);
else
plhs[0]=FaustMat2mxArray(B); plhs[0]=FaustMat2mxArray(B);
if(ptr_data) {delete [] ptr_data ; ptr_data = NULL;}
return; return;
...@@ -71,6 +71,8 @@ classdef FaustCore < handle ...@@ -71,6 +71,8 @@ classdef FaustCore < handle
% destructor delete the faust % destructor delete the faust
if (this.isRealFlag) if (this.isRealFlag)
mexFaustReal('delete', this.objectHandle); mexFaustReal('delete', this.objectHandle);
else
mexFaustCplx('delete', this.objectHandle);
end end
end end
...@@ -68,16 +68,6 @@ template<typename FPP> ...@@ -68,16 +68,6 @@ template<typename FPP>
bool isScalarCompatible(const Faust::LinearOperator<FPP,Cpu> & L,const mxArray * Matlab_Mat); bool isScalarCompatible(const Faust::LinearOperator<FPP,Cpu> & L,const mxArray * Matlab_Mat);
* \brief convert the matlab mxArray* into a Faust::Vect<FPP,Cpu>, no shared memory
* \param vec_array : pointer to the mxArray* (matlab format) representing a dense column Vector
* \tparam vec : Faust::Vect<FPP,Cpu>
void mxArray2FaustVec(const mxArray * vec_array,Faust::Vect<FPP,Cpu> & vec);
void mxArray2FaustVec(const mxArray * vec_array,Faust::Vect< std::complex<FPP> ,Cpu> & vec)
{mexErrMsgTxt("mxArray2FaustVec (complex scalar) not yet implemented");}
...@@ -88,8 +78,8 @@ void mxArray2FaustVec(const mxArray * vec_array,Faust::Vect< std::complex<FPP> , ...@@ -88,8 +78,8 @@ void mxArray2FaustVec(const mxArray * vec_array,Faust::Vect< std::complex<FPP> ,
template<typename FPP> template<typename FPP>
void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat); void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat);
template<typename FPP> /*template<typename FPP>
void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP>,Cpu> & Mat); void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP>,Cpu> & Mat);*/
...@@ -102,10 +92,26 @@ template<typename FPP> ...@@ -102,10 +92,26 @@ template<typename FPP>
void mxArray2FaustspMat(const mxArray* spMat_array,Faust::MatSparse<FPP,Cpu> & S); void mxArray2FaustspMat(const mxArray* spMat_array,Faust::MatSparse<FPP,Cpu> & S);
\brief convert the data (real part or imaginary part) of a mxArray* into the pointer ptr_data
\param mxMat : pointer to the mxArray (MATLAB matrix)
\tparam ptr_data : pointer of template FPP where the data of the mxArray will be stored,
\tparam mxGetDataFunc : functor to get the data of MATLAB matrix
possible value : - mxGetData (get the real scalar part of the data)
(cf https://fr.mathworks.com/help/matlab/apiref/mxgetdata.html)
- mxGetImagData (get the imaginary scalar part of the data)
(cf https://fr.mathworks.com/help/matlab/apiref/mxgetimagdata.html)
template<typename FPP,class FUNCTOR>
void mxArray2PtrBase(const mxArray* mxMat,FPP* & ptr_data,FUNCTOR & mxGetDataFunc);
// ptr_data will be allocated in this function /* \brief convert the real scalar data of a mxArray* into the pointer ptr_data
void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data); void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data);
/* \brief convert the complex scalar data of a mxArray* into the pointer ptr_data
void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data); void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data);
...@@ -70,76 +70,10 @@ bool isScalarCompatible(Faust::LinearOperator<FPP,Cpu> & L, const mxArray * Matl ...@@ -70,76 +70,10 @@ bool isScalarCompatible(Faust::LinearOperator<FPP,Cpu> & L, const mxArray * Matl
int nbRow,nbCol;
if (mxIsEmpty(vec_array))
mexErrMsgTxt("tools_mex.h:getFaustVec :input matrix is empty.");
mwSize nb_dim=mxGetNumberOfDimensions(vec_array);
if (nb_dim != 2)
mexErrMsgTxt("tools_mex.h:getFaustVec :input vector must be a 2D array.");
const mwSize *dimsMat;
dimsMat = mxGetDimensions(vec_array);
nbRow = (int) dimsMat[0];
nbCol = (int) dimsMat[1];
if ((nbRow == 0) || (nbCol == 0))
mexErrMsgIdAndTxt("tools_mex.h:getFaustVec", "empty vector");
if ((nbCol) > 1)
mexErrMsgTxt("getFaustVec : input must be a column-vector");
if (mxIsSparse(vec_array))
//mexErrMsgTxt("sparse matrix entry instead of dense matrix");
mexErrMsgIdAndTxt("a","a sparse matrix entry instead of dense vector");
const mxClassID V_CLASS_ID = mxGetClassID(vec_array);
FPP* MatPtr;
if (((V_CLASS_ID == mxDOUBLE_CLASS) && (sizeof(double) == sizeof(FPP))) || ((V_CLASS_ID == mxSINGLE_CLASS) && (sizeof(float) == sizeof(FPP))))
MatPtr = (FPP*) mxGetPr(vec_array);
}else
if (V_CLASS_ID == mxDOUBLE_CLASS)
MatPtr = (FPP*) mxCalloc(nbRow,sizeof(FPP));
double* MatPtrDouble =(double*) mxGetPr(vec_array);
for (int i=0;i<nbRow*nbCol;i++)
MatPtr[i] = (FPP) MatPtrDouble[i];
else if (V_CLASS_ID == mxSINGLE_CLASS)
MatPtr = (FPP*) mxCalloc(nbRow*nbCol,sizeof(FPP));
float* MatPtrSingle= (float*) (mxGetData(vec_array));
MatPtr[i] = (FPP) MatPtrSingle[i];
}else
mexErrMsgTxt("getFaustVec :input vector format must be single or double");
vec.resize(nbRow);
memcpy(vec.getData(),MatPtr,nbRow*sizeof(FPP));
if (((V_CLASS_ID == mxDOUBLE_CLASS) && (sizeof(double) != sizeof(FPP))) || ((V_CLASS_ID == mxSINGLE_CLASS) && (sizeof(float) != sizeof(FPP))))
mxFree(MatPtr);
void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat) void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat)
...@@ -214,13 +148,13 @@ void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat) ...@@ -214,13 +148,13 @@ void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat)
void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP>,Cpu> & Mat) void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<FPP,Cpu> & Mat)
int nbRow,nbCol; int nbRow,nbCol;
if (mxIsEmpty(Mat_array)) if (mxIsEmpty(Mat_array))
...@@ -247,9 +181,9 @@ void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP> ...@@ -247,9 +181,9 @@ void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP>
Mat.resize(nbRow,nbCol); Mat.resize(nbRow,nbCol);
std::complex<FPP>* MatPtr; FPP* MatPtr;
mxArray2Ptr(Mat_array,MatPtr); mxArray2Ptr(Mat_array,MatPtr);
memcpy(Mat.getData(),MatPtr,nbRow*nbCol*sizeof(std::complex<FPP>)); memcpy(Mat.getData(),MatPtr,nbRow*nbCol*sizeof(FPP));
if(MatPtr) {delete [] MatPtr ; MatPtr = NULL;} if(MatPtr) {delete [] MatPtr ; MatPtr = NULL;}
...@@ -265,6 +199,7 @@ void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP> ...@@ -265,6 +199,7 @@ void mxArray2FaustMat(const mxArray* Mat_array,Faust::MatDense<std::complex<FPP>
void mxArray2FaustspMat(const mxArray* spMat_array,Faust::MatSparse<FPP,Cpu> & S) void mxArray2FaustspMat(const mxArray* spMat_array,Faust::MatSparse<FPP,Cpu> & S)
if (!mxIsSparse(spMat_array)) if (!mxIsSparse(spMat_array))
mexErrMsgIdAndTxt("tools_mex.h:mxArray2FaustspMat", mexErrMsgIdAndTxt("tools_mex.h:mxArray2FaustspMat",
...@@ -285,36 +220,48 @@ void mxArray2FaustspMat(const mxArray* spMat_array,Faust::MatSparse<FPP,Cpu> & S ...@@ -285,36 +220,48 @@ void mxArray2FaustspMat(const mxArray* spMat_array,Faust::MatSparse<FPP,Cpu> & S
//ir = (size_t *) mxCalloc(nnzMax,sizeof(size_t)); //ir = (size_t *) mxCalloc(nnzMax,sizeof(size_t));
ir = (size_t *) mxGetIr(spMat_array); ir = (size_t *) mxGetIr(spMat_array);
//pr = (double *) mxCalloc(nnzMax,sizeof(double)); //pr = (double *) mxCalloc(nnzMax,sizeof(double));
mxArray2Ptr(spMat_array,ptr_data);
S.set(nnzMax,nbRow,nbCol,ptr_data,ir,jc); S.set(nnzMax,nbRow,nbCol,ptr_data,ir,jc);
if(ptr_data) {delete [] ptr_data ; ptr_data = NULL;} if(ptr_data) {delete [] ptr_data ; ptr_data = NULL;}
//mxFree(jc);
//mxFree(ir);
//mxFree(pr);
/*Faust::MatDense A=S;
mxArray* mxA=FaustMat2mxArray(A);
mexPrintf("INSIDE\n");
mexCallMATLAB(0,NULL,1,&mxA,"disp");*/
void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) template<typename FPP,class FUNCTOR>
void mxArray2PtrBase(const mxArray* mxMat, FPP* & ptr_data,FUNCTOR & mxGetDataFunc)
if ((mxGetDataFunc != mxGetData) && (mxGetDataFunc != mxGetImagData))
mexErrMsgTxt("mxArrayPtr(mxArray*,FPP* &, FUNCTOR) : invalid functor passed to mxArrayPtr(mxArray*,FPP* &, FUNCTOR &) must be mxGetData or mxGetImagData");
if ((mxGetDataFunc == mxGetImagData) && (!mxIsComplex(mxMat)) )
mexErrMsgTxt("mxArrayPtr(mxArray*,FPP* &, FUNCTOR) : can't get imaginary part of a real matrix ");
const mxClassID V_CLASS_ID = mxGetClassID(mxMat); const mxClassID V_CLASS_ID = mxGetClassID(mxMat);
const size_t NB_ELEMENTS = mxGetNumberOfElements(mxMat); size_t nb_element_tmp;
if (mxIsSparse(mxMat))
nb_element_tmp = mxGetNzmax(mxMat);
else
nb_element_tmp = mxGetNumberOfElements(mxMat);
const size_t NB_ELEMENTS = nb_element_tmp;
if(V_CLASS_ID == mxDOUBLE_CLASS) if(V_CLASS_ID == mxDOUBLE_CLASS)
double* ptr_data_tmp = static_cast<double*> (mxGetData(mxMat)); double* ptr_data_tmp = static_cast<double*> (mxGetDataFunc(mxMat));
ptr_data = new FPP[NB_ELEMENTS]; ptr_data = new FPP[NB_ELEMENTS];
for (size_t i =0 ; i<NB_ELEMENTS ; i++) for (size_t i =0 ; i<NB_ELEMENTS ; i++)
ptr_data[i] = static_cast<FPP> (ptr_data_tmp[i]); ptr_data[i] = static_cast<FPP> (ptr_data_tmp[i]);
...@@ -325,7 +272,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) ...@@ -325,7 +272,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data)
float* ptr_data_tmp = static_cast<float*> (mxGetData(mxMat)); float* ptr_data_tmp = static_cast<float*> (mxGetDataFunc(mxMat));
...@@ -336,7 +283,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) ...@@ -336,7 +283,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data)
char* ptr_data_tmp = static_cast<char*> (mxGetData(mxMat)); char* ptr_data_tmp = static_cast<char*> (mxGetDataFunc(mxMat));
...@@ -347,7 +294,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) ...@@ -347,7 +294,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data)
unsigned char* ptr_data_tmp = static_cast<unsigned char*> (mxGetData(mxMat)); unsigned char* ptr_data_tmp = static_cast<unsigned char*> (mxGetDataFunc(mxMat));
...@@ -358,7 +305,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) ...@@ -358,7 +305,7 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data)
short* ptr_data_tmp = static_cast<short*> (mxGetData(mxMat)); short* ptr_data_tmp = static_cast<short*> (mxGetDataFunc(mxMat));
...@@ -369,35 +316,35 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) ...@@ -369,35 +316,35 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data)
unsigned short* ptr_data_tmp = static_cast<unsigned short*> (mxGetData(mxMat)); unsigned short* ptr_data_tmp = static_cast<unsigned short*> (mxGetDataFunc(mxMat));
else if (V_CLASS_ID == mxINT32_CLASS) else if (V_CLASS_ID == mxINT32_CLASS)
int* ptr_data_tmp = static_cast<int*> (mxGetData(mxMat)); int* ptr_data_tmp = static_cast<int*> (mxGetDataFunc(mxMat));
else if (V_CLASS_ID == mxUINT32_CLASS) else if (V_CLASS_ID == mxUINT32_CLASS)
unsigned int* ptr_data_tmp = static_cast<unsigned int*> (mxGetData(mxMat)); unsigned int* ptr_data_tmp = static_cast<unsigned int*> (mxGetDataFunc(mxMat));
else if (V_CLASS_ID == mxINT64_CLASS) else if (V_CLASS_ID == mxINT64_CLASS)
long long* ptr_data_tmp = static_cast<long long*> (mxGetData(mxMat)); long long* ptr_data_tmp = static_cast<long long*> (mxGetDataFunc(mxMat));
else if (V_CLASS_ID == mxUINT64_CLASS) else if (V_CLASS_ID == mxUINT64_CLASS)
unsigned long long* ptr_data_tmp = static_cast<unsigned long long*> (mxGetData(mxMat)); unsigned long long* ptr_data_tmp = static_cast<unsigned long long*> (mxGetDataFunc(mxMat));
...@@ -408,6 +355,21 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data) ...@@ -408,6 +355,21 @@ void mxArray2Ptr(const mxArray* mxMat, FPP* & ptr_data)
mxArray2PtrBase(mxMat,ptr_data,mxGetData);
void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data) void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data)
...@@ -435,7 +397,7 @@ void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data) ...@@ -435,7 +397,7 @@ void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data)
// Complex Matlab Matrix // Complex Matlab Matrix
// get the imaginary part of the Matlab Matrix // get the imaginary part of the Matlab Matrix
FPP* ptr_imag_part_data; FPP* ptr_imag_part_data;
mxArray2CplxPtrPart(mxMat,ptr_imag_part_data); mxArray2PtrBase(mxMat,ptr_imag_part_data,mxGetImagData);
// copy the values in the output vector // copy the values in the output vector
for (int i=0;i < NB_ELEMENTS;i++) for (int i=0;i < NB_ELEMENTS;i++)
...@@ -460,123 +422,6 @@ void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data) ...@@ -460,123 +422,6 @@ void mxArray2Ptr(const mxArray* mxMat, std::complex<FPP>* & ptr_data)
void mxArray2CplxPtrPart(const mxArray* mxMat, FPP* & ptr_data)
else
if (!mxIsComplex(mxMat))
mexErrMsgTxt("Can't get imaginary part of a real matrix");
double* ptr_data_tmp = static_cast<double*> (mxGetImagData(mxMat));
float* ptr_data_tmp = static_cast<float*> (mxGetImagData(mxMat));
char* ptr_data_tmp = static_cast<char*> (mxGetImagData(mxMat));
unsigned char* ptr_data_tmp = static_cast<unsigned char*> (mxGetImagData(mxMat));
short* ptr_data_tmp = static_cast<short*> (mxGetImagData(mxMat));
unsigned short* ptr_data_tmp = static_cast<unsigned short*> (mxGetImagData(mxMat));
int* ptr_data_tmp = static_cast<int*> (mxGetImagData(mxMat));
unsigned int* ptr_data_tmp = static_cast<unsigned int*> (mxGetImagData(mxMat));
long long* ptr_data_tmp = static_cast<long long*> (mxGetImagData(mxMat));
unsigned long long* ptr_data_tmp = static_cast<unsigned long long*> (mxGetImagData(mxMat));
else
...@@ -596,12 +441,15 @@ void concatMatGeneric(const mxArray * mxMat,std::vector<Faust::MatGeneric<FPP,Cp ...@@ -596,12 +441,15 @@ void concatMatGeneric(const mxArray * mxMat,std::vector<Faust::MatGeneric<FPP,Cp
if (!mxIsSparse(mxMat)) if (!mxIsSparse(mxMat))
Faust::MatDense<FPP,Cpu> denseM; Faust::MatDense<FPP,Cpu> denseM;
mxArray2FaustMat(mxMat,denseM); mxArray2FaustMat(mxMat,denseM);
M=denseM.Clone(); M=denseM.Clone();
}else }else
Faust::MatSparse<FPP,Cpu> spM; Faust::MatSparse<FPP,Cpu> spM;
mxArray2FaustspMat(mxMat,spM); mxArray2FaustspMat(mxMat,spM);
M=spM.Clone(); M=spM.Clone();
