Commit 9306b220 authored by hhakim's avatar hhakim
Update doc.
It's because Py3 is now available in binary packages for macOS (since dafb94aa).
parent b5c89cb4
...@@ -20,11 +20,11 @@ ...@@ -20,11 +20,11 @@
<h3>1.1 For Python</h3> <h3>1.1 For Python</h3>
<p>FAµST supports at least Python 2.7. For macOS it&rsquo;s the only version supported for now.</p> <p>FAµST supports at least Python 2.7 and is also compiled for Python 3.6.</p>
<p>FAµST is designed for the Python ecosystem which as usual relies on numpy and scipy packages. So you have to ensure these packages are installed on your system.</p> <p>If you want to use FAµST with Python 3 you must use this exact version because the FAµST Python wrapper delivered within the binary package is compiled for that version only.</p>
<p>That requirement applies also to Python 3, assuming your version of Python is matching the version FAµST is compiled for (currently 3.6).</p> <p>FAµST is designed for the Python ecosystem which as usual relies on numpy and scipy packages. So you have to ensure these packages are installed on your system.</p>
<h3>1.2 For Matlab</h3> <h3>1.2 For Matlab</h3>
...@@ -43,10 +43,10 @@ Neverthless, it could be useful to check that it really worked and set the envir ...@@ -43,10 +43,10 @@ Neverthless, it could be useful to check that it really worked and set the envir
<p>Here is how to test the FaµST Python wrapper has been setup properly from a Bash terminal:</p> <p>Here is how to test the FaµST Python wrapper has been setup properly from a Bash terminal:</p>
<pre><code> $ python2 -c "import pyfaust" &amp;&amp; echo "It worked!" <pre><code> $ python2 -c "import pyfaust" &amp;&amp; echo "It works"
</code></pre> </code></pre>
<p>Obviously, if the the wrapper is set up properly you&rsquo;ll see the message &ldquo;It worked!&rdquo; as a result from the command above.</p> <p>Obviously, if the wrapper is set up properly you&rsquo;ll see the message &ldquo;It works&rdquo; as a result from the command above.</p>
<p>If you see the following error message, then it didn&rsquo;t work:</p> <p>If you see the following error message, then it didn&rsquo;t work:</p>
...@@ -61,7 +61,7 @@ Neverthless, it could be useful to check that it really worked and set the envir ...@@ -61,7 +61,7 @@ Neverthless, it could be useful to check that it really worked and set the envir
<pre><code> $ export PYTHONPATH=@CMAKE_INSTALL_PREFIX@/python <pre><code> $ export PYTHONPATH=@CMAKE_INSTALL_PREFIX@/python
# and test again # and test again
$ python2 -c "import pyfaust" &amp;&amp; echo "It worked!" $ python2 -c "import pyfaust" &amp;&amp; echo "It works"
<p>If it fails again you are likely on a different version of Python. Returns to the Prerequisites section and check your Python versions match FAµST requirements.</p> <p>If it fails again you are likely on a different version of Python. Returns to the Prerequisites section and check your Python versions match FAµST requirements.</p>
...@@ -71,7 +71,7 @@ Neverthless, it could be useful to check that it really worked and set the envir ...@@ -71,7 +71,7 @@ Neverthless, it could be useful to check that it really worked and set the envir
<pre><code> $ matlab -nodisplay -nojvm -r "import matfaust.Faust;F = Faust.rand(1, 10, .5, 'dense', false);exit" <pre><code> $ matlab -nodisplay -nojvm -r "import matfaust.Faust;F = Faust.rand(1, 10, .5, 'dense', false);exit"
<p>It worked only if you see an output similar to:</p> <p>It works only if you see an output similar to:</p>
<pre><code> F = <pre><code> F =
