Commit 9208fb91 authored by Nicolas Bellot's avatar Nicolas Bellot Committed by hhakim
demo Brain Source Localization marche
parent 175e1ee4
......@@ -135,10 +135,13 @@ set(FAUST_CMDLINE_TYPE_FORMAT_DIR ${FAUST_CMDLINE_SRC_DIR}/type_format CACHE INT
set(FAUST_CMDLINE_TYPE_FORMAT_XML_SRC_DIR ${FAUST_CMDLINE_TYPE_FORMAT_DIR}/xml CACHE INTERNAL "")
set(FAUST_CMDLINE_TYPE_FORMAT_MAT_SRC_DIR ${FAUST_CMDLINE_TYPE_FORMAT_DIR}/mat CACHE INTERNAL "")
###### WRAPPER CMDLINE BUILD DIRECTORIES ######
set(FAUST_DEMO_BIN_DIR ${PROJECT_BINARY_DIR}/demo)
set(FAUST_CMDLINE_BIN_SRC_DIR ${FAUST_DEMO_BIN_DIR}/cmd_line/src CACHE INTERNAL "")
set(FAUST_CMDLINE_BIN_DIR ${FAUST_DEMO_BIN_DIR}/cmd_line/bin CACHE INTERNAL "")
set(FAUST_CMDLINE_BIN_DIR ${FAUST_WRAPPER_BIN_DIR}/cmd_line CACHE INTERNAL "")
set(FAUST_CMDLINE_BIN_SRC_DIR ${FAUST_WRAPPER_BIN_DIR}/cmd_line/src CACHE INTERNAL "")
set(FAUST_CMDLINE_BIN_DIR ${FAUST_WRAPPER_BIN_DIR}/cmd_line/bin CACHE INTERNAL "")
## fichier d'entrée doivent être renseigné dans l'executable
......@@ -160,7 +163,20 @@ set(FAUST_TEST_SRC_TOOL_DIR ${FAUST_TEST_SRC_DIR}/tools CACHE INTERNAL "")
set(FAUST_TESTSRC_SRC_DIR ${FAUST_TEST_SRC_DIR}/src CACHE INTERNAL "")
set(FAUST_TESTDATA_SRC_DIR ${FAUST_MISC_DIR}/data/mat CACHE INTERNAL "")
###### DEMO DIRECTORIES ######
set(FAUST_DEMO_SRC_DIR ${FAUST_MISC_DIR}/demo CACHE INTERNAL "")
set(FAUST_DEMOTOOLS_SRC_DIR ${FAUST_DEMO_SRC_DIR}/tools CACHE INTERNAL "")
#set(FAUST_DEMO_BIN_DIR ${FAUST_DEMO_SRC_DIR} CACHE INTERNAL "")
set(FAUST_DEMOTOOLS_BIN_DIR ${PROJECT_BINARY_DIR}/tools CACHE INTERNAL "")
#set(FAUST_DEMODATA_SRC_DIR ${FAUST_DEMO_SRC_DIR}/data CACHE INTERNAL "")
set(FAUST_DEMODATA_SRC_DIR ${FAUST_MISC_DIR}/data/mat/demoLuc CACHE INTERNAL "")
## examples directories including some examples of the use of the library FAuST
set(FAUST_TEST_DIR ${FAUST_DEMO_BIN_DIR}/run_test CACHE INTERNAL "")
set(FAUST_TEST_BIN_DIR ${FAUST_TEST_DIR}/bin CACHE INTERNAL "")
set(FAUST_TESTSRC_BIN_DIR ${FAUST_TEST_DIR}/src CACHE INTERNAL "")
......@@ -170,13 +186,7 @@ set(FAUST_TESTFIG_BIN_DIR ${FAUST_TEST_DIR}/fig CACHE INTERNAL "")
set(FAUST_TESTRUNCOMP_BIN_DIR ${FAUST_TEST_DIR}/runtime_comparison CACHE INTERNAL "")
set(FAUST_TESTTOOLS_BIN_DIR ${FAUST_TEST_DIR}/tools CACHE INTERNAL "")
......@@ -229,8 +239,9 @@ if (FAUST_GEN_DOC)
endif()
message(STATUS "FAUST_TESTOUTPUT_BIN_DIR : ${FAUST_TESTOUTPUT_BIN_DIR}")
file(MAKE_DIRECTORY ${FAUST_TESTOUTPUT_BIN_DIR})
file(MAKE_DIRECTORY ${FAUST_TESTFIG_BIN_DIR})
file(MAKE_DIRECTORY ${FAUST_TESTTMP_BIN_DIR})
#################### FAuST Toolbox ######################
General purpose:
The FAuST toolbox contains code implementing a general framework designed
to factorize matrices of interest into multiple sparse factors.
The FAuST toolbox contains a C++ code implementing a general framework
designed to factorize matrices of interest into multiple sparse factors.
It contains a template CPU/GPU C++ code and a Matlab wrapper.
The algorithms implemented here are described in details in [1]- Le Magoarou
For more information on the FAuST Project, please visit the website of the
project: <http://faust.gforge.inria.fr>
......@@ -50,6 +53,10 @@ Install:
Main tools :
The main functions offered by the FAuST toolbox are implemented in two files
No preview for this file type
File moved
......@@ -8,7 +8,7 @@ file(GLOB MATLAB_SCRIPTS "*.m")
if(FAUST_USE_MEX)
foreach(matlab_script localize_src.m figure_localize_src.m)
foreach(matlab_script Brain_source_localization.m figure_localize_src.m)
configure_file(${FAUST_DEMO_SRC_DIR}/${matlab_script} ${FAUST_DEMO_BIN_DIR}/${matlab_script} COPYONLY)
endforeach()
configure_file(${FAUST_DEMO_SRC_DIR}/set_path.m.in ${FAUST_DEMO_BIN_DIR}/set_path.m @ONLY)
addpath('');%% access to the mexfunction
addpath('/home/aleman/WORK/FAUST/faust/trunk/devcpp/misc/demo/tools');%% access to the tools.m function (sparsify toolbox, figure toolbox ...)
addpath('/home/aleman/WORK/FAUST/faust/trunk/devcpp/misc/data/mat/demoLuc');%% access to the data
addpath('');%% access to matlab_faust.m (interface betwwen faust_core C++ class and matlab class)
addpath('@FAUST_MEXINTERFACE_BIN_DIR@');%% access to the mexfunction
addpath('@FAUST_MATLABMEX_BIN_DIR@');%% access to the mexfunction
addpath('@FAUST_DEMOTOOLS_SRC_DIR@');%% access to the tools.m function (sparsify toolbox, figure toolbox ...)
addpath('@FAUST_DEMODATA_SRC_DIR@');%% access to the data
addpath('@FAUST_MEXINTERFACETOOLS_BIN_DIR@');%% access to matlab_faust.m (interface betwwen faust_core C++ class and matlab class)
addpath('@FAUST_MATLABTOOLS_BIN_DIR@');%% access to matlab_faust.m (interface betwwen faust_core C++ class and matlab class)
