Commit 908ee0b4 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
modif CMakeLists.txt
parent 4b7be292
...@@ -4,12 +4,12 @@ file(GLOB CPP_FILES "*.cpp" "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAU ...@@ -4,12 +4,12 @@ file(GLOB CPP_FILES "*.cpp" "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAU
file(GLOB HPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.hpp" "${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR}/*.hpp") file(GLOB HPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.hpp" "${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR}/*.hpp")
if(UNIX AND FAUST_USE_MKL) #if(UNIX AND FAUST_USE_MKL)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fopenmp") # set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fopenmp")
elseif(WIN32 AND FAUST_USE_MKL) #elseif(WIN32 AND FAUST_USE_MKL)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /openmp") # set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /openmp")
endif() #endif()
message(STATUS "CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
#add_definitions(-DEIGEN_MPL2_ONLY) #add_definitions(-DEIGEN_MPL2_ONLY)
if(FAUST_USE_OPENBLAS) if(FAUST_USE_OPENBLAS)
