Commit 8c7dff8d authored by testcdash Nicolas Bellot's avatar testcdash Nicolas Bellot Committed by hhakim
BUG make for windows
parent 2539f3ec
......@@ -283,8 +283,8 @@ if (BUILD_DOCUMENTATION)
set(FAUST_DOC_BIN_DIR ${PROJECT_BINARY_DIR}/doc CACHE INTERNAL "")
endif()
#message(STATUS "FAUST_BIN_TEST_OUTPUT_DIR : ${FAUST_BIN_TEST_OUTPUT_DIR}")
file(MAKE_DIRECTORY ${FAUST_BIN_TEST_OUTPUT_DIR})
file(MAKE_DIRECTORY ${FAUST_BIN_TEST_FIG_DIR})
file(MAKE_DIRECTORY ${FAUST_BIN_TEST_TMP_DIR})
......@@ -333,19 +333,21 @@ endif(BUILD_USE_GPU)
###### FLAG for DEBUG or RELEASE TARGETS ######
if(WIN32)
if(CMAKE_BUILD_TYPE MATCHES "Debug")
set(FAUST_DEBUG_RELEASE "debug")
set(FAUST_BIN_DIR ${PROJECT_BINARY_DIR}/Debug)
set(FAUST_MATLAB_BIN_DIR ${FAUST_MATLAB_BIN_DIR}/Debug)
else()
set(FAUST_DEBUG_RELEASE "release")
set(FAUST_BIN_DIR ${PROJECT_BINARY_DIR}/Release)
set(FAUST_MATLAB_BIN_DIR ${FAUST_MATLAB_BIN_DIR}/Release)
endif()
set(FAUST_BIN_DIR ${PROJECT_BINARY_DIR})
# if(CMAKE_BUILD_TYPE MATCHES "Debug")
# set(FAUST_DEBUG_RELEASE "debug")
# set(FAUST_BIN_DIR ${PROJECT_BINARY_DIR}/Debug)
# set(FAUST_MATLAB_BIN_DIR ${FAUST_MATLAB_BIN_DIR}/Debug)
# else()
# set(FAUST_DEBUG_RELEASE "release")
# set(FAUST_BIN_DIR ${PROJECT_BINARY_DIR}/Release)
# set(FAUST_MATLAB_BIN_DIR ${FAUST_MATLAB_BIN_DIR}/Release)
# endif()
else()
endif(WIN32)
# adding compiler flags
set(CMAKE_CXX_FLAGS "")
if( (CMAKE_BUILD_TYPE MATCHES "Debug") OR (CMAKE_BUILD_TYPE MATCHES "debug") OR (CMAKE_BUILD_TYPE MATCHES "DEBUG") )
# CMakeLists used to generated ".mexa64" files.
#INCLUDE("${PROJECT_SOURCE_DIR}/CMake/define_variables.cmake")
configure_file(${FAUST_MATLAB_TOOLS_SRC_DIR}/matlab_faust.m.in ${FAUST_MATLAB_TOOLS_BIN_DIR}/matlab_faust.m COPYONLY)
install(FILES ${FAUST_MATLAB_TOOLS_BIN_DIR}/matlab_faust.m DESTINATION ${FAUST_MATLAB_TOOLS_INSTALL_DIR})
file(GLOB CPP_MEXTOOLS_FILES "${FAUST_MATLAB_TOOLS_SRC_DIR}/*.cpp")
# include directory
#{${FAUST_EXCEPTION_SRC_DIR}
include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR} ${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR} ${FAUST_MATLAB_TOOLS_SRC_DIR} ${MATLAB_INCLUDE_DIR} ${EIGEN_INC_DIR} )
......@@ -22,6 +20,7 @@ add_library(${FAUST_MEXTOOLS_TARGET} OBJECT ${CPP_MEXTOOLS_FILES})
file(GLOB CPP_MEX_FILES "${FAUST_MATLAB_MEX_SRC_DIR}/*.cpp")
## modif AL : bug pour les noms de PATH avec un point comme par exemple : ./faust_v1.10/interface_matlab/
## On va chercher les nom des target
string(REGEX REPLACE "[a-zA-Z0-9_/:.]+/([a-zA-Z0-9_]+)\\.cpp(;|$)" "\\1\\2" MEXFILE_TARGET_LIST "${CPP_MEX_FILES}")
#string(REGEX REPLACE "[a-zA-Z0-9_/:]+/([a-zA-Z0-9_]+)\\.cpp(;|$)" "\\1\\2" MEXFILE_TARGET_LIST "${CPP_MEX_FILES}")
......@@ -51,7 +50,6 @@ endif()
if(UNIX)
add_custom_target(${FAUST_MEX_TARGET} ALL DEPENDS ${MEXFILE_TARGET_LIST} ${FAUST_TARGET} ${FAUST_MEXTOOLS_TARGET} )
elseif(WIN32)
# MODIF ALALAL fonctionne pas
file(GLOB CPP_SRC_FILES "${FAUST_SRC_LINEAR_OPERATOR_DIR}/*.cpp" "${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp" "${FAUST_MATLAB_TOOLS_SRC_DIR}/*.cpp")
string(REGEX REPLACE "([a-zA-Z0-9_/:]+)\\.cpp(;|$)" "\\1\\2" MEXSRC_FULL "${CPP_SRC_FILES}")
string(REGEX REPLACE "[a-zA-Z0-9_/:]+/([a-zA-Z0-9_]+)\\.cpp(;|$)" "${FAUST_TMPMEX_DIR}/\\1.${MEXOBJ_EXT}\\2" MEXOBJ_FILES "${CPP_SRC_FILES}")
......@@ -60,21 +58,30 @@ elseif(WIN32)
add_custom_target(MEXFILE_TARGET_LIST_TARGET DEPENDS ${MEXFILE_TARGET_LIST})
add_custom_target(MEXOBJ_FILES_TARGET DEPENDS ${MEXOBJ_FILES})
add_dependencies(MEXFILE_TARGET_LIST_TARGET MEXOBJ_FILES_TARGET)
######## file(GLOB CPP_SRC_FILES "${FAUST_EXCEPTION_SRC_DIR}/*.cpp" "${FAUST_MATRIX_SRC_DIR}/*.cpp" "${FAUST_FAUSTCORE_SRC_DIR}/*.cpp" "${FAUST_PALM4MSA_SRC_DIR}/*.cpp" "${FAUST_MEXINTERFACETOOLS_SRC_DIR}/*.cpp")
#message (STATUS "${FAUST_MEX_TARGET}")
endif()
if(WIN32)
foreach( mex_src ${MEXSRC_FULL})
string(REGEX REPLACE "[a-zA-Z0-9_/:]+/([a-zA-Z0-9_]+)" "\\1" mexsrc_short "${mex_src}")
add_custom_command(OUTPUT ${FAUST_TMPMEX_DIR}/${mexsrc_short}.${MEXOBJ_EXT}
COMMAND ${MATLAB_ROOT}/bin/mex
ARGS "-v" "-c" "-largeArrayDims" ${mex_src}.cpp ${CMAKE_CXX_FLAGS_LIST} "-outdir" "${FAUST_TMPMEX_DIR}" "OBJEXT=.${MEXOBJ_EXT}"
COMMENT "Compiling ${mex_src}.cpp for mex usage")
#message (STATUS "${FAUST_TMPMEX_DIR}/${mexsrc_short}.${MEXOBJ_EXT}")
endforeach()
endif()
foreach(mex_target ${MEXFILE_TARGET_LIST})
if(WIN32)
add_custom_target(${mex_target} DEPENDS ${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp ${mex_target}.${MEX_EXT} MEXOBJ_FILES_TARGET )
elseif(UNIX)
add_custom_target(${mex_target} DEPENDS ${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp ${mex_target}.${MEX_EXT} ${FAUST_MEXTOOLS_TARGET} ${FAUST_TARGET})
endif()
if(UNIX)
if(APPLE)
add_custom_command(OUTPUT ${mex_target}.${MEX_EXT}
......@@ -94,19 +101,18 @@ foreach(mex_target ${MEXFILE_TARGET_LIST})
COMMENT "Creating mex function ${mex_target}.${MEX_EXT}")
endif(APPLE)
elseif(WIN32)
elseif(WIN32)
#message(STATUS "${MEXOBJ_FILES} ")
file(GLOB OBJ_MEXTOOLS_FILES "${FAUST_TMPMEX_DIR}/*.${MEXOBJ_EXT}")
ARGS "-v" "-largeArrayDims" "${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp" ${OBJ_MEXTOOLS_FILES}
ARGS "-v" "-largeArrayDims" "${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp" ${OBJ_MEXTOOLS_FILES} ${MEXOBJ_FILES}
#message(STATUS "ALALALALALAAL \"${FAUST_TMPMEX_DIR}/\\*.${MEXOBJ_EXT}\" ")
#message (STATUS "${FAUST_MATLAB_MEX_SRC_DIR}/${mex_target}.cpp")
else()
message(FATAL_ERROR "Unable to compile mex functions for this platform")
endif()
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/${mex_target}.m ${FAUST_MATLAB_MEX_BIN_DIR}/${mex_target}.m COPYONLY)
......@@ -115,25 +121,7 @@ foreach(mex_target ${MEXFILE_TARGET_LIST})
endforeach()
if(WIN32)
endforeach()
endif()
# CONFIGURATION DES CHEMINS
configure_file(${FAUST_MATLAB_SRC_DIR}/setup_FAUST.m.in ${FAUST_MATLAB_BIN_DIR}/setup_FAUST.m @ONLY)
install(FILES ${FAUST_MATLAB_BIN_DIR}/setup_FAUST.m DESTINATION ${FAUST_MATLAB_INSTALL_DIR})
