Commit 8c18263b authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
test AL ctest
parent cf0cfcbc
...@@ -9,5 +9,5 @@ set(CTEST_DROP_SITE_CDASH TRUE) ...@@ -9,5 +9,5 @@ set(CTEST_DROP_SITE_CDASH TRUE)
set(CTEST_FULL_OUTPUT TRUE) set(CTEST_FULL_OUTPUT TRUE)
set(CTEST_CUSTOM_MAXIMUM_PASSED_TEST_OUTPUT_SIZE TRUE) set(CTEST_CUSTOM_MAXIMUM_PASSED_TEST_OUTPUT_SIZE TRUE)
set(CTEST_CUSTOM_MAXIMUM_FAILED_TEST_OUTPUT_SIZE TRUE) set(CTEST_CUSTOM_MAXIMUM_FAILED_TEST_OUTPUT_SIZE TRUE)
set(CTEST_USE_LAUNCHERS 1) #set(CTEST_USE_LAUNCHERS 1)
