Commit 89051fa4 authored by hhakim's avatar hhakim
Update .gitlab-ci.yml.
Setting NOPY2 to ON for macOS pip pkg, EXPERIMENTAL_PK to OFF for faust_torch, linux pip and linux raspberry-pi pip pkgs.
parent 14e1eaf1
...@@ -313,7 +313,7 @@ pages: ...@@ -313,7 +313,7 @@ pages:
pkg_macos_purepy_rev: pkg_macos_purepy_rev:
extends: .pkg_purepy_rev extends: .pkg_purepy_rev
variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", EXPERIMENTAL_PKG: "ON", BUILD_MULTITHREAD: "ON"} variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", EXPERIMENTAL_PKG: "ON", BUILD_MULTITHREAD: "ON", NOPY2: "ON"}
tags: tags:
- macos - macos
...@@ -340,30 +340,30 @@ pkg_linux_purepy_rev: ...@@ -340,30 +340,30 @@ pkg_linux_purepy_rev:
pkg_macos_purepy_release: pkg_macos_purepy_release:
extends: .pkg_purepy_release extends: .pkg_purepy_release
variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF"} variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON"}
tags: tags:
- macos - macos
pkg_macos_purepy_release_torch_linked: pkg_macos_purepy_release_torch_linked:
extends: pkg_macos_purepy_release extends: pkg_macos_purepy_release
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", FAUST_TORCH: "ON", CMAKE_PREFIX_PATH: "/opt/local/libtorch/share/cmake/Torch", BUILD_MULTITHREAD: "ON"} variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", FAUST_TORCH: "ON", CMAKE_PREFIX_PATH: "/opt/local/libtorch/share/cmake/Torch", BUILD_MULTITHREAD: "ON", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON"}
pkg_linux_purepy_release: pkg_linux_purepy_release:
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF"} variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF"}
tags: tags:
- linux - linux
- tux_packager - tux_packager
pkg_linux_purepy_release_torch_linked: pkg_linux_purepy_release_torch_linked:
extends: pkg_linux_purepy_release extends: pkg_linux_purepy_release
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", FAUST_TORCH: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "/opt/local/libtorch/share/cmake/Torch;../gpu_mod"} variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", FAUST_TORCH: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "/opt/local/libtorch/share/cmake/Torch;../gpu_mod", EXPERIMENTAL_PKG: "OFF"}
.pkg_purepy_release_rasp: .pkg_purepy_release_rasp:
variables: {MATIO_STATIC_LIB_PATH: "/opt/local/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/libhdf5.a"} variables: {MATIO_STATIC_LIB_PATH: "/opt/local/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/libhdf5.a"}
script: script:
- if [[ ! -d 'build' ]]; then mkdir build;fi; cd build - if [[ ! -d 'build' ]]; then mkdir build;fi; cd build
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=OFF -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DEXCLUDE_FAUST_LIB_INSTALL=ON -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH=$MATIO_STATIC_LIB_PATH -DZ_STATIC_LIB_PATH=$Z_STATIC_LIB_PATH -DHDF5_STATIC_LIB_PATH=$HDF5_STATIC_LIB_PATH -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" -DEXPERIMENTAL_PKG=$EXPERIMENTAL_PKG -DNOPY2=ON -DBUILD_MULTITHREAD=ON ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=OFF -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DEXCLUDE_FAUST_LIB_INSTALL=ON -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH=$MATIO_STATIC_LIB_PATH -DZ_STATIC_LIB_PATH=$Z_STATIC_LIB_PATH -DHDF5_STATIC_LIB_PATH=$HDF5_STATIC_LIB_PATH -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" -DEXPERIMENTAL_PKG=OFF -DNOPY2=ON -DBUILD_MULTITHREAD=ON ..'
- ln -s /usr/bin/clang gcc - ln -s /usr/bin/clang gcc
- export PATH=$PWD:$PATH - export PATH=$PWD:$PATH
- make - make
